| bosh31 |
 bosh31 L Plate Warrior
| nowhere.elysium |
 nowhere.elysium The Pork Lord
 Posted: 20:16 - 21 Jul 2010 Post subject: |
Um, the brakes won't affect the diameter/fitting points of the exhaust at all, unless there's some utterly perverse* pipe routing involved.
If there's a difference in model year, then sometimes minor changes are made. However, the easiest way to check would be to sight-compare the mounting points between your stock one and this guy's aftermarket one, and to check the pipe diameters.
What's the rush for a stainless one, anyway? Yours can't have rusted through yet, surely? I know it's a chinese bike, but that would be reality-bendingly fast corrosion, unless you keep it in a salt water tank, or something.
Keep the pipe you've got for now, unless you've got the money and the itching need to use it.
If you're worried about surface corrosion, keep it doused in ACF50 or something similar.
*i.e. including the extra four feet needed to make it interfere with the rear brake. ____________________ '10 SV650SF, '83 GS650GT (it lives!), Questionable DIY dash project, 3D Printer project, Lasercutter project |
| bosh31 |
| nowhere.elysium |
 Posted: 20:27 - 21 Jul 2010 Post subject: Re: help with exhaust sinnis apache 125 |
| bosh31 wrote: | very quick sinnis apache 125?
I've got one of the same bikes, sold as a pulse adrenaline, and there is no way it can be described as quick
For what it's worth, when searching for parts, use the term XF125-GY - it'll get you all the stock parts as well as most of the modified parts available for it, regardless of brand name - the same model is sold under many different labels.
I know for a fact that the same bike is sold as: Pulse Adrenaline, Sumo XF, Superbyke RMR and Sinnis Apache. Probably more names to add to that, but I can't be arsed to check. ____________________ '10 SV650SF, '83 GS650GT (it lives!), Questionable DIY dash project, 3D Printer project, Lasercutter project |
| nowhere.elysium |
 Posted: 20:30 - 21 Jul 2010 Post subject: |
| bosh31 wrote: | there is no real rush i just think it would look sweet! lol. it hasnt rusted through yet but i doubt it will be long as its caked in it already. could i use some good old hammerite on it or will it catch fire/melt off? |
Buy some high-temperature paint, or do what some ratbikers do - sand the rust off it, and then coat it with a bit of cooking oil. Run it for a while, clean it, and then add some more cooking oil. Rinse and repeat. I'm told you'll end up with a pretty resilient finish, which smells pleasing, too.
I haven't got round to this yet, because I'm lazy as hell, and since I put a cherrybomb exhaust on, it's too loud to use regularly. ____________________ '10 SV650SF, '83 GS650GT (it lives!), Questionable DIY dash project, 3D Printer project, Lasercutter project |
| bosh31 |
 Posted: 20:33 - 21 Jul 2010 Post subject: |
ok so its not that fast. top speed of 60mph
but getting there i will kill anything in the same class
and thanks for the rust idea i will give it a shot or just try hammerite and see what happens lol.
and i will also check oput the parts for the multi named sinnis apache  ____________________ move over my sinnis apache is coming through! |
| nowhere.elysium |
 Posted: 20:37 - 21 Jul 2010 Post subject: |
You can get high-temperature paint from Halfords, or some similar car/bike shop. You should only really need the one can, if all you're spraying is the exhaust pipe.
The acceleration is pretty good compared to a cg, certainly - the gearing's much shorter. Don't misread my cynicism - I enjoy my one, purely because of it's sillybastard appeal - it feels massively inappropriate as a 125, and i love that
:edit: incidentally, it looks like I've been contradicted in your general bike chat post, so it may be worth phoning CMPO and asking if the exhaust is any different between the disc version and the drum version.
CMPO are the main importers of Chinese bikes, and they're pretty helpful - I've phoned them up in the past, and they've always been pretty good to me. ____________________ '10 SV650SF, '83 GS650GT (it lives!), Questionable DIY dash project, 3D Printer project, Lasercutter project |
The last post was made 15 years, 164 days ago. Instead of replying here, would creating a new thread be more useful? |
