Ignition barrel loose: could this mean a variety of things?
Tsopo
PostPosted: 20:16 - 22 Jul 2010    Post subject: Ignition barrel loose: could this mean a variety of things? Reply with quote
Getting my arse into gear now and seriously looking for a 125. There's a YBR that is close enough to me that it's still practical to go see it, yet far enough away that the ride back would be a bit of an adventure.
The thing is, there are two things wrong with it. First, the neutral indicator light doesn't work (a fairly simple fix I imagine). Secondly, and most worryingly (or maybe not if you know what you're talking about) is, as above, the ignition barrel is loose.
What is the most likely reason for this? What comes into my head is that it was stolen, or at least someone tried. Or is there another explanation? I'm keen to get a bike as I hate driving my car (can't wait to sell the thing).
Obviously I can do a HPI check, just wanted to know if I was being a bit paranoid.
Willson
PostPosted: 20:25 - 22 Jul 2010    Post subject: Reply with quote
Personally I'd check out it's history, go for the HPI check.
How old is it, and is the barrel itself loose or the fitting to the bike?
Benson: Wouldn't life be easier if we were all turtles?
Me: Pig on bread = The way forward.
Riding: '00 Suzuki SV650S. Previous: '99 Kawasaki ER5 - sold, '02 Suzuki GZ125 Marauder - sold
PostPosted: 21:25 - 22 Jul 2010    Post subject: Reply with quote
and the neutral light could be an easy fix, but it could also be a right pig.
Make sure the price takes this and the ignition problem into account. If it doesnt just walk away, plenty of other ybrs and the like around.
Tsopo
PostPosted: 22:41 - 22 Jul 2010    Post subject: Reply with quote
Thanks guys. It's a 2007 model. The ad says the barrel just needs bolting on. Not sure how bad it is from that description, and there's no way to tell from the pictures.
Think I'll do the check on it, to be sure.
Willson
PostPosted: 22:44 - 22 Jul 2010    Post subject: Reply with quote
(Without trying to sound like a know-it-all) could you pm me the link?
Alex A
PostPosted: 23:55 - 22 Jul 2010    Post subject: Reply with quote
Very unlikely. It's quicker to bolt something on than to write an advert saying it needs to be bolted on. If that's all it needed, the seller would have done it and not suffered the hassle of people asking about it.
Does the neutral light not work? Or does the bike not go into neutral?
Tsopo
PostPosted: 01:14 - 23 Jul 2010    Post subject: Reply with quote
The light doesn't work when it's in neutral. Apart from that (and the ignition barrel) it's supposed to be fine.
psychofox
PostPosted: 23:27 - 11 Aug 2010    Post subject: Reply with quote
Probably too late now, but I would say that is definitely an attempted theft. And as Polar Bear says, it can be a pig of a job.
Someone tried to nick my CG125 a couple of years back, ripped the ignition out, and in the process ended up knackering most of the electrics. The neutral light didn't work, and the indicators only worked intermittently. I needed to fit a new ignition barrel, and due to the theft attempt, it wouldn't fit properly into the old slot.
It's not too difficult if you know what you're doing, just double check all electrical connectors on the bike ( I didn't know what they were all for before, but I do now, so something good has come out of it.) More than likely the one for the neutral light will be disconnected, and maybe a few others as well.
Might just be a bulb though, in which case ignore everything I just said Wink Razz
Glue was the only solution I found for the loose ignition barrel.
Clanger
Stirrer
PostPosted: 09:20 - 15 Aug 2010    Post subject: Reply with quote
If you ever need help with anything technical / mechanical on your bike, write a post in the WORKSHOP section, that is where you will find the right help...from the clever people that know...you shouldn't get duff advice there. Karma
The last post was made 16 years, 79 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.10 Sec - Server Load: 2.14 - MySQL Queries: 13 - Page Size: 60.33 Kb
