RXS 100 allspeed exhaust
vmax12
PostPosted: 22:04 - 22 Jul 2010    Post subject: RXS 100 allspeed exhaust Reply with quote
hi folks, got this project not so long ago and rode for the first tie today....the problem is excelleration....not to good at all...seems to struggle to get to 50mph. Had new piston n rings engine starts and ticks over nicely. all standard apart from the allspeed, could it be this? needle in the carb was on the second notch down which i moved to the middle it improved the excelleration a bit but still not good enough. what do yous think? would a KnN sort things out? would prefure a standard pipe to swap if theres any about......the pipes in grt condition. ta for any help
temeluchus
PostPosted: 22:16 - 22 Jul 2010    Post subject: Reply with quote
if moving the clip down (therefore moing the needle UP) improved things, then you will most lilkely need a bigger mainjet.
Find out the size you have at the moment and buy maybe the next four sizes up and give them a try.
evoboy
PostPosted: 01:24 - 23 Jul 2010    Post subject: Reply with quote
+1.
Try moving the clip down another notch.
If its on the standard main jet, then it will most likely need to have a bigger one installed to compensate for the expansion pipe.
APT Motorcycles
27cows
PostPosted: 06:53 - 23 Jul 2010    Post subject: Reply with quote
Odds on it's the pipe at fault. Or rather the fact that the jetting doesn't match the pipe. RXS motors don't like non-standard exhausts at all.
Finding a good standard item is difficult as they tend to rust through round the (entirely unnecessary) bracket at the front of the pipe. Having said that, you can quite easily bodge this (with Jubilee clips/Gun Gum and/or aluminium tape).
pepperami
PostPosted: 07:47 - 23 Jul 2010    Post subject: Re: RXS 100 allspeed exhaust Reply with quote
Photos and updates please Thumbs Up with plenty of detail Thumbs Up
i`ve just stuck a deal on one of these and have to get it from London to Suffolk.
When i get it back i will be looking at all the threads about RXS`s Smile .
vmax12
PostPosted: 20:46 - 24 Jul 2010    Post subject: gearbox oil Reply with quote
evnin all...got brain freeze...just done oil change... oil measure with dipstick screwed in or out?.....im the dipstick i know...forget things that are soo obvious Rolling Eyes also as well, when ignition switch on is there spose to be both oil and nutrel lights on? if no oil light why? bulb maybe but if not where else do i look? cheers, hope your all avin as gud night as me Wink do tend to go completely brainless on a friday night... thanks a lot for any elp
PostPosted: 21:17 - 24 Jul 2010    Post subject: Reply with quote
Dipstick should be unscrewed Thumbs Up
vmax12
PostPosted: 21:28 - 24 Jul 2010    Post subject: Reply with quote
thanks....added another question Wink <<goin to finish oil change
The last post was made 15 years, 198 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 0.83 - MySQL Queries: 13 - Page Size: 57.07 Kb
