| Ingah |
 Ingah World Chat Champion
 Posted: 16:25 - 23 Jul 2010 Post subject: Removing a CG125 centre stand |
Need to remove and replace the "pivot pin" that the centre stand and rear brake pedal attach to (as it's causing lots of freeplay on the rear brake pedal due to wear). I've already removed the rear brake pedal having fought the split pin off, but the Haynes manual doesn't seem to tell you how to take the centre stand off. Clearly it'll need to be slid off / the pivot pin needs knocking through it, but there is the complication of the (strong) centre stand spring in the way (i suspect it needs unhooking, but i certainly can't do it with my fingers!), along with this bigish flat piece of metal associated with the centre stand.
Hopefully someone who's done it before can clarify, cheers  ____________________ -- Ingah |
| The Shaggy D.A. |
 The Shaggy D.A. Super Spammer
 Posted: 16:36 - 23 Jul 2010 Post subject: |
https://evergreen-rentals.com/images/sledgehammer.jpg ____________________ Chances are quite high you are not in my Monkeysphere, and I don't care about you. Don't take it personally.
| N cee thirty |
 N cee thirty Banned
 . Renault 5 Driver
| stonesie |
 stonesie World Chat Champion
 Posted: 20:16 - 23 Jul 2010 Post subject: |
When the big hammer method just belled the end of the pivot shaft my MK2 solution involved the angle grinder and dremel, the stand, spring, C clip and shaft were all replaced with new so the condition of the old parts was "whatever it takes to get them out"  |
| cb1rocket |
 cb1rocket World Chat Champion
The last post was made 15 years, 198 days ago. Instead of replying here, would creating a new thread be more useful? |
