| radical |
 radical Spanner Monkey
| tatters |
 tatters Exxon Valdez
 Posted: 21:36 - 31 Jul 2010 Post subject: |
Eaiser to work on the gearbox is the main one, take me 30 mins to remove the one on my BMW. unit construction saves weight and space. ____________________ Past:NRG50,AF1125(x2),NSR125RR,ZZR250,CX500,VFR400,KR1S,ZZR600(x2),CB400N,YZF1000(x2),KH125,Z200,FX400R,CBR954RR(x2)GPZ500S,GT550,VFR750F(x2),RD350N,XR650R,CBR600F,CB250,KDX250,YZF750R,CRM250,400EXC,KLR650,TTR600RE,DR350S,R100GSPD,RGV250,VMAX1200,DL650,KZ750 Present:G650XC,C12,CRF450X,1190ADV |
| Blau Zedong |
 Blau Zedong Banned
| radical |
| r0b |
 r0b Renault 5 Driver
| radical |
| r0b |
| radical |
| Ariel Badger |
 Ariel Badger Super Spammer
| radical |
| Dibble |
 Dibble Scooby Slapper
| johnsmith222 |
 johnsmith222 World Chat Champion
| Teflon-Mike |
 Teflon-Mike tl;dr
 Posted: 13:44 - 02 Aug 2010 Post subject: |
Remind me again how to tension the primary drive chain on a pre-unit Triumph Trophy?
I seem to recall that apart from the small niggle of the mixed bag of imperial, metric and witworth fastners used all over the place....
There were RATHER a lot of bolts that had to be undone, major assemblies slid forwards and backwards in slotted holes in the frame and the primary drive chain case, then the final drive chain re-tensioned, and THEN bolting it all back together so it was even laughably oil tight was err.... something of a pain!
And didn't it give three oul levels to check, becouse the primary drive ran, 'wet'... as long as the oil stayed in there, of course!
From the point of view of engineering asthetics the vertically split, unit construction, with all gear drive arrangement is a LOT more elegant.
The manufacturability is hugely increased; the rigidity of the unit increased, the maintainance requirements minimised, and generally, its just a lot 'neater'.
Yes, the pre-unit construction has some minor advantages, but not many, and they are pretty much limited to 'serviceability', but where and when?
So, it MIGHT be easier to pull out a seperate gear-box to make a repair to a selector fork, IF one is so worn or damaged, but if you had a unit construction engine, how much faffing about adjusting primaries and the like would you have saved before that effort was needed?
As for gear-teeth chipping and damaging components inside the engine?
Yeah. Broken bits of metal inside a motor are not good. But if you have an engine that has been that abused or neglected or just that worn out... I think that there may be bigger issues to worry about, and IF that shard got past both the oil filter and the strainer, to actually do some damage, I think that it would pretty much be a message from Thor, the god of metal work, it was time to strip your engine and give it some tender loving care, and some new bearings! ____________________ My Webby'Tef's-tQ, loads of stuff about my bikes, my Land-Rovers, and the stuff I do with them!
The last post was made 16 years, 83 days ago. Instead of replying here, would creating a new thread be more useful? |
