BT, naff broadband speeds?
Whosthedaddy
PostPosted: 06:50 - 01 Aug 2010    Post subject: BT, naff broadband speeds? Reply with quote
Recently moved and it would appear that although BT (our previous provider) promised 13mb broadband, it has been painfully slow when downloading or trying to watch vids online.
Never had a problem before, did a quick check to see what BT say and the following seemed quite interesting:
Your exchange is ADSL enabled, and our initial test on your line indicates that your line should be able to have an ADSL broadband service that provides a fixed line speed up to 2Mbps.
Our test also indicates that your line currently supports an estimated ADSL Max broadband line speed of 7Mbps.
Our test also indicates that your line currently supports an estimated ADSL2+ broadband line speed of 14Mbps. Our test also indicates that your line could support an estimated ADSL 2+ Annex-M broadband upstream line speed of 750Kbps and downstream line speed of 5.5Mbps.
How can it be this slow in this day and age?
I live quite close to the exchange (I think) and when I found a site showing a map of my street and all available broadband speeds, BT showed 1.3meg. I thought this can't be right but nope, I must have been wrong.
Th wife pays the BT stuff and we're contracted in.
Any ideas of what to do to get out of the dark ages?
Nb
PostPosted: 11:44 - 01 Aug 2010    Post subject: Reply with quote
Cant offer much in the way of help, but if you think your broadband is slow try mine....0.5mb on a GOOD day! Evil or Very Mad Crying or Very sad Crying or Very sad Like you say its a fucking joke in this day and age.
Move closer to the exchange? Laughing Neutral
doggone
PostPosted: 14:06 - 01 Aug 2010    Post subject: Reply with quote
So what speed are you actually getting?
The quoted ADSL Max expected is well above average for a non-cable ADSL connection.
Try this.
https://www.mybroadbandspeed.co.uk/
A slightly dodgy connection will really bring down the ADSL max speed as it automatically balances maximum speed against reliable connection.
You need to test ideally with the router/modem in the first entry point and better still take off the face plate and plug it inside.
This will ascertain if the house wiring is causing problems.
You need leave it in there 2 or 3 days really so the speed can stabilise.
5Mb download speed should play even HD youtube videos without pausing.
The 480 option should be OK even around 2MB
L4Isoside
PostPosted: 14:21 - 01 Aug 2010    Post subject: Reply with quote
i used to get 300kb,then it went down to 100kb...was like this for a year.
that's when i realised i had a little circuit on my house wiring which was hugely throttling my connection, now i get about 5 meg.
That's with BT, any other provider ends up slowing the speeds down in the evening!
_Will_
PostPosted: 18:56 - 01 Aug 2010    Post subject: Reply with quote
Its that damn 'up to' wording again.
First i'd say change router channels, people around you might be on the same one hence the slow speed on a new move.
Second get the accelerator plate from bt, it may help.
Try these first as even 5.5 meg line should be fine with videos and the like.
{When did you get back to england, what happened to oz?}
Suffering Bike Withdrawal.
CaNsA
PostPosted: 20:50 - 01 Aug 2010    Post subject: Reply with quote
Just to rub it in.
https://www.speedtest.net/result/899662157.png
Not too bad for peak time, sunday evening.
Hazylogic
PostPosted: 20:58 - 01 Aug 2010    Post subject: Reply with quote
better be careful with BT and the package you are on. With some packages they charge if you go over your allocated allowance.
PostPosted: 21:05 - 01 Aug 2010    Post subject: Reply with quote
It's the same with most ISPs.
Whosthedaddy
PostPosted: 18:56 - 02 Aug 2010    Post subject: Reply with quote
Cheers.
The wife got homesick! Still wish I was there even after a year of being back!
Do her up the gary and cunt punt is in order me thinks?
_Will_
PostPosted: 12:38 - 03 Aug 2010    Post subject: Reply with quote
Ah, Women you need say no more Laughing
What was it then?
PostPosted: 10:16 - 04 Aug 2010    Post subject: Reply with quote
https://img.photobucket.com/albums/v295/chris-red/test.jpg
_Will_
PostPosted: 15:46 - 04 Aug 2010    Post subject: Reply with quote
Git.
The last post was made 16 years, 29 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 0.36 - MySQL Queries: 13 - Page Size: 82.19 Kb
