Honda cg 125cc
kauto_star
PostPosted: 21:28 - 01 Aug 2010    Post subject: Honda cg 125cc Reply with quote
My Honda seems to stutter a bit when going through the gears - generally at a higher mph, seems to be losing power but then when i pull the throttle towards me - it seems to kick on again.
What can i check?
Would it be the spark plugs?
Dont know if it is any coincidence but the horn doesnt seem to work either.
Thank you in advance.
dextersaurus
PostPosted: 21:49 - 01 Aug 2010    Post subject: Reply with quote
You mean when you put on the throttle it runs better than when it's at low revs?
Mixture maybe?
Or if it's the idle you're talking about, maybe the idle speed is too low.
Horn should work with the engine running, if not - the horn is buggered.
The indicators work when the engine is off but the ignition is on?
Dunc
kauto_star
PostPosted: 21:53 - 01 Aug 2010    Post subject: Reply with quote
Mixture maybe?
Dunc
Hi Dunc - well sometimes when i pulled the throttle right back then it levelled out again.
How would i change the idle speed?
Indicators work when the engine is off but ignition on, yes.
thank you.
dextersaurus
PostPosted: 22:23 - 01 Aug 2010    Post subject: Reply with quote
Sounds like mixture, mines did that and found it was running lean.
What model? might even be the accelerator pump needing adjusted.
Idle speed is changed by the wee screw through the black cover on the carb, leave the engine running till it's warm and adjust it till it sounds right.
Since the indicators are working, that means the battery is fine, and the fuses are fine - means your horn needs replaced.... Get it for the MOT, that's a failure.
Dunc
The last post was made 16 years, 41 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.11 Sec - Server Load: 1.39 - MySQL Queries: 13 - Page Size: 40.14 Kb
