Which 125cc to get
kingley
PostPosted: 20:13 - 01 Aug 2010    Post subject: Which 125cc to get Reply with quote
Hi everyone,
I'm new here and new to biking, planning to do my CBT soon. I plan on buying a 125 and to use it for commuting to and from work, also for generally running around on shortish (probably less than 100 miles ) trips.
I've been looking at a few bikes online and in dealers.
My friends say I should buy a new 125 as there are a lot of dodgy secondhand ones out there that superficially look great, but a few months in can become very problematic. I reckon that I could buy a good secondhand one for the same cash (I have £1500 to spend). Although obviously I'm not too sure of what dangers too look for when buying secondhand being a newbie.
The new ones I have checked out are Kymco Pulsar and the Keeway Speed. The secondhand ones I have seen are YBR125, CG 125 and the Suzuki RV 125 Van Van. In your opinions what would be the best route to go for, new or used?
Thanks for any help you can offer.
PS: Sorry about the long post
imanupstart
PostPosted: 20:33 - 01 Aug 2010    Post subject: Reply with quote
cg125, 99% of folks on here will reccomend you get one Wink
Benson_JV
PostPosted: 20:55 - 01 Aug 2010    Post subject: Reply with quote
CG125!
Although I did my CBT on a YBR, not bad little bikes tbf!
Mord
PostPosted: 21:42 - 01 Aug 2010    Post subject: Reply with quote
CG Thumbs Up Laughing
Digitalize
PostPosted: 22:07 - 01 Aug 2010    Post subject: Reply with quote
CG Thumbs Up
1998 CB600F Hornet
L4Isoside
PostPosted: 23:19 - 01 Aug 2010    Post subject: Reply with quote
YBR
cuz i did Cool
Scythe
PostPosted: 01:00 - 02 Aug 2010    Post subject: Reply with quote
YBR, I preferred it over the CG. Just looked more stylish and modern to me, although the newest YBR's aren't as nice in my opinion. I prefer the 2009 YBR, and for that reason I bought one.
Not an obviously push here or anything, but my 2009 YBR is for sale for £1500 but no worries Mr. Green Razz
Adrian
PostPosted: 16:30 - 02 Aug 2010    Post subject: Reply with quote
CG Very Happy
DAS 18/06/09 Off The Kerb Motorcycle Training. Proud owner of a Honda CG125 & a Honda Hornet
PostPosted: 17:13 - 02 Aug 2010    Post subject: Reply with quote
i'd go for a cg. at the end of the day its only a means to an end. you will eventually want to get your full license and then want a bigger bike.
points to remember for all those wanting to join the biking comunity on a 125. a cbt costs around 100 quid and is only valid for 2 years. that gives you a choice. spend a tun every 2 years or pass your test. most people would go for their test.
when passed you can buy any bike you want and test result depending you can either ride it right away (DAS course) or have it restricted to 33bhp for 2 years, bearing in mind you can restrict an R1.
so theres no point in splashing out on a brand new bike and then selling it on for half its value. might as well buy a decent second hand and sell it on for almost the same price when you pass your test
rob_scott92
PostPosted: 17:16 - 02 Aug 2010    Post subject: Reply with quote
Hate to go against the grain here but a Gs will be as good as a cg and possibly cheaper/better in my opinion Laughing
Mines 28 years old and the only problems i have had have been with the wiring, but i'm sure if you found a newer one (post 2000) you shouldn't have much trouble. You would definately get one for way below your budget too.
Failing that, the ybrs are good/ Might be tricky getting one for less than £1500 for one of the newer ones at least.
Rob Thumbs Up
First bike: 1982 Suzuki Gs 125 'The beast MK1' Wink > 1988 Honda Cb 350's' FOR SPORT! (Good ol' oil burner!) > 2001 Suzuki Sv 650 's' Made it out of the 80's! > 1997 Honda Cbr 600f :p
C-Pk
PostPosted: 17:32 - 02 Aug 2010    Post subject: Reply with quote
CG is my suggestion also. You should be able to get a good condition, low mileage, second hand cg for around that sorta money. They are good, reliable bikes.
Passed Mod 2 - 6th August 2010
First and Current Bike - 2008 Suzuki SV650SK8
EUMP
PostPosted: 18:04 - 02 Aug 2010    Post subject: Reply with quote
CG Wink
C.B.T - Expired
MOD1 04/08/10
MOD2 10/08/10
Digitalize
PostPosted: 19:19 - 02 Aug 2010    Post subject: Reply with quote
Friends got a 79 CG125, no problems at all, just gotta find a good one, kick start only but its easy as anything to get going, even cold.
1998 CB600F Hornet
el_oso
PostPosted: 09:33 - 04 Aug 2010    Post subject: Reply with quote
if you are willing to spend a bit more money why not go for something a bit more exciting and get something like an xr125 or a hyosung gt125?
Duke 390
Car: Jeep Wrangler 4.0L
Louis101993
PostPosted: 11:04 - 04 Aug 2010    Post subject: Reply with quote
Cg, you can't go wrong (Y)
A2 License Acquired 18/05/2011
Daelim E5 '08 ->Honda CG '99 -> Kawasaki ZXR 400 RR '96 -> Suzuki SV650 '00 (Naked) -> Yamaha Fazer '99
PostPosted: 11:06 - 04 Aug 2010    Post subject: Reply with quote
NSR125
It'll be more fun than a CG.
Ingah
PostPosted: 11:26 - 04 Aug 2010    Post subject: Reply with quote
Ste wrote:
NSR125
True.
However, you'll need to ensure you don't buy a chav-owned, trashed example. And you'll want to rebuild the engine. DIY unless you want to waste hundreds. And be sure to keep it topped up with 2 stroke! And be aware that when you have your first drop you're likely to crack the shiny plastics up somewhat (and they're not cheap to replace), so don't get too attached to them!
If the above hasn't put the OP off already, then they're obviously braver than i was when i started riding.
Personally i often tend to see YBRs going at far better condition/mileage for less money than CGs. The CG is clearly the better quality choice out of the 2 - but as everyone knows this (and prices accordingly) sometimes your money is better spent elsewhere so you get a better bike for your buck Wink
My opinion is to get a first bike you can afford to run, insure, and more importantly drop (something without plastics is more likely to meet this requirement) and/or write off (something cheap is more likely to meet this requirement).
As an aside, the brands of 2 new bikes you were looking at aren't very reassuring as a choice for a first bike. IMO, stick to Japanese if you want it reliable so that you can get to work on time every time.
-- Ingah
RussG
PostPosted: 13:03 - 04 Aug 2010    Post subject: Reply with quote
en125's look better than CG's in my opinion, and are around 3 years old, and you'll pick one up for loads less than a grand
Geek, father, biker
27cows
PostPosted: 13:24 - 04 Aug 2010    Post subject: Reply with quote
CGs are very overrated. The YBR125, RXS100 and GS/EN125 are vastly superior. If you're after a bit of fun, the DT125R is a good choice.
Don't get a CG unless fuel consumption is your only concern - it's the one and only thing the CG125 does better than any other bike of the same size.
kingley
PostPosted: 13:54 - 04 Aug 2010    Post subject: Reply with quote
I don't like the NSR style of bike at all. It's way too boy racer for me. I prefer something with more classic styling like the YBR, CG, EN style or the GN, SR style as I feel more comfortable on them having tried on few in local bike shops.
I'm doing my CBT on sunday so I'll be getting my first bike in the next couple of weeks Smile
lewis198
PostPosted: 15:03 - 04 Aug 2010    Post subject: Reply with quote
get a rieju r2s 125, i have 1 for sale, 2009, under 1700 miles, pit bike exhause and some little extras. £1500
Digitalize
PostPosted: 15:15 - 04 Aug 2010    Post subject: Reply with quote
These are brilliant bikes, but its a boring 4 stroke, and i doubt the pit bike exhausts sound that good. Its 'NSR' (Sports btw) style though.
1998 CB600F Hornet
Frost
PostPosted: 15:30 - 04 Aug 2010    Post subject: Reply with quote
CG's are amazing in the amount of abuse they put up with off ignorant learners and just keep going. They are very simple, easy to ride and economical. They are not fun or desireable. So it's a question of what you want really. NSR would be an awesome bike provided you budget for the top end rebuilds when they are due.
PostPosted: 15:43 - 04 Aug 2010    Post subject: Reply with quote
CG, YBR or RXS.
The last post was made 16 years, 61 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 0.67 - MySQL Queries: 13 - Page Size: 125.5 Kb
