Anyone know if I can tap into 12v DC? - KTM 250 EXC
Bike Chat Forums Index -> Offroad & Supermoto Goto page 1, 2  Next
Blue_SV650S
PostPosted: 11:07 - 31 Jul 2010    Post subject: Anyone know if I can tap into 12v DC? - KTM 250 EXC Reply with quote
Not really sure if the bike runs AC or DC. I can see it has a voltage regulator, but not a rectifier ... so I am thinking it is probably AC ... however, the horn must be DC right?!?!!? Confused
Basically I want to wire up a sat-nav to my 2000 KTM 250 EXC 2t and I need regulated 12v DC to tap into ...
drzsta
PostPosted: 11:33 - 31 Jul 2010    Post subject: Reply with quote
This maybe your solution https://trailtech.net/media/instructions/lights/stators/010-ELV-45.pdf
Blue_SV650S
PostPosted: 12:17 - 31 Jul 2010    Post subject: Reply with quote
drzsta wrote:
So from that, is it safe to conclude that the standard setup is AC???
monty
PostPosted: 21:15 - 01 Aug 2010    Post subject: Reply with quote
does it have a battery if so fit a car fag lighter to the battery and power it that way.
all bikes are a/c as the power is different depending on revs
Gilera Nexus 500
Its a scooter get over it!!!
Blue_SV650S
PostPosted: 21:21 - 01 Aug 2010    Post subject: Reply with quote
I am not sure where exactly to start correcting what you just said!!! Laughing
PostPosted: 09:40 - 02 Aug 2010    Post subject: Reply with quote
Pretty sure it is AC, got a feeling you can get DC kits from place like baja designs or something maybe, but doubt yours would have one.
No reason you can't have a horn AC, being a very simple 'buzzer' it's probably even easier to make in AC!
oldpink
PostPosted: 12:23 - 02 Aug 2010    Post subject: Reply with quote
Hmm there must be DC at some point as you can't charge a bettery (DC) from an AC source
PostPosted: 12:28 - 02 Aug 2010    Post subject: Reply with quote
But only if you have a battery Smile.
oldpink
PostPosted: 13:07 - 02 Aug 2010    Post subject: Reply with quote
yes a battery would be req
anything eletrical outside the engine on a bike, lights etc req DC
so there would be a rectifier and a regulator
PostPosted: 13:35 - 02 Aug 2010    Post subject: Reply with quote
You do not require a battery for a 'bike'* to run.
As witnessed by home illuminations, lights can work off AC too Wink.
* Of course many do, ie many with just electrical start, with fancy electronics and FI etc.
Blue_SV650S
PostPosted: 18:28 - 02 Aug 2010    Post subject: Reply with quote
The wiring diagram states the horn as DC ... it also has a 'capacitor' in the circuit ... wonder if I could tap DC off the capacitor!!? Thinking
Charlie
PostPosted: 18:58 - 02 Aug 2010    Post subject: Reply with quote
A capacitor becomes almost like a block at high frequency IIRC. A singular diode and a capacitor could be used to make a half wave rectifier... which could provide DC with a massive ripply voltage...
Charlie
PostPosted: 19:08 - 02 Aug 2010    Post subject: Reply with quote
If you can give me a copy of the circuit diagram I could have a look and see what I can make of it. I am not that good at electronic circuits though.
Blue_SV650S
PostPosted: 19:12 - 02 Aug 2010    Post subject: Reply with quote
Fill ya boots!! Very Happy
KTM 250,300,380 SX,MXC,EXC Owners Manual GER
https://www.megaupload.com/?d=DEINYWZ3
KTM 125,200 99-03 Engine Repair Manual ENG https://www.megaupload.com/?d=UTORMP65
Charlie
PostPosted: 19:38 - 02 Aug 2010    Post subject: Reply with quote
The english version doesn't work... not as much detail as I was hoping in the german one.
Blue_SV650S
PostPosted: 20:09 - 02 Aug 2010    Post subject: Reply with quote
good 'innit Laughing
Charlie
PostPosted: 20:24 - 02 Aug 2010    Post subject: Reply with quote
The english link doesn't work though, says the file in not available... might be more help.
You need an oscilloscope! Could probe the horns supply and see how DC it is...
Blue_SV650S
PostPosted: 20:30 - 02 Aug 2010    Post subject: Reply with quote
ah right. well, you will have to google it then. .. the bike is a 2000 ktm 250 exc 2t
I don't have a 'scope I am araid Sad
oldpink
PostPosted: 21:03 - 02 Aug 2010    Post subject: Reply with quote
my german is shit but on page 11-5 there is an eletrical chart code to accompany the wiring diagrams
according to that the 99 250/380 has a rectifier and the diagram shows DC
and I'm assuming if it still has a horn there will be 12v DC wiring for the lights etc
a cheap test meter will tell you if you have AC or DC and the voltage
and if you know how to use the meter measure the current (Amps)
as you may need to have a certain rating to run your satnav without damaging it or not
delivering enough current for it to work
this may help its a link to a 2003 250exc with the full wiring diagram
and good info on the other eletrical system
https://www.mediafire.com/?o3nrd04oiyj
I know that house lights use AC but as far as I'm aware all modern bikes / cars run DC for the lights etc
and as his bike is the EXC unless its been stripped it should have a battery
Blue_SV650S
PostPosted: 21:12 - 02 Aug 2010    Post subject: Reply with quote
Thanks for the effort, but that is for the wrong model bike, mine is a 2000 2-stroke.
My bike has no battery or electric start. The lights ARE AC, it is only fitted with a regulator (not reg/rec) ... oh and the capacitor ...
oldpink
PostPosted: 21:22 - 02 Aug 2010    Post subject: Reply with quote
I stand corrected, yes your model does have AC
found a 1999 - 2003 manual in english
https://moto.tt.free.fr/explorer/KTM_Manual_engine_250_380_1999_2003_english.pdf
the wire diagrams are there
PostPosted: 21:26 - 02 Aug 2010    Post subject: Reply with quote
As above, poke a multimeter around the place.
As above - I'm pretty sure the non-electric start (very recent 300s do have electric boot and can be retrofitted to 250) 2 strokes do not have batteries. My 2004 200 EXC definitely does not.
I'm also pretty sure the lighting circuits DO run AC as Blue says (I don't have lights on mine, but the wires are around.)
Remember, we're talking competition enduro bikes that can come road registered, not a daily get-to-work bike, nor even a 4 stroke electric booted fuel injected enduro bike - a very basic design kept simple for light weight.
Saying that, the 2001 C90 I recently sorted for MOT also has SOME of the lights working on AC (very confusing when you don't realise!) - think it was just the head light and maybe tail light, but not break light, just to be REALLY confusing!
Blue_SV650S
PostPosted: 21:29 - 02 Aug 2010    Post subject: Reply with quote
Yep, that is the one I was working from (had downloaded it before). You can see it is AC Wink
oldpink
PostPosted: 21:40 - 02 Aug 2010    Post subject: Reply with quote
I think your model is the diagram on page 11-7
if so It looks like its all AC as you say theres no rectifier so one would be req to get your satnav to work
PostPosted: 21:44 - 02 Aug 2010    Post subject: Reply with quote
Might it not be worth just getting an extra battery to cover that?
As I said the other day, was going to make something, maybe with 10x AA batteries in a little holder to power it for the push bike. May be a load less hassle - think I've got all the needed stuff, so may give it a go this week, though as I said, think I may have blown my 12v road angel adaptor Rolling Eyes.
The last post was made 16 years, 39 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.18 Sec - Server Load: 0.49 - MySQL Queries: 13 - Page Size: 130.94 Kb
