"holding back"
rdlccrazy
PostPosted: 20:08 - 02 Aug 2010    Post subject: "holding back" Reply with quote
Hello, I have just replaced one of the carbs on my RD LC YPVS as it was leaking from the overflow pipe. I have replaced the float and the bike is back running but now seems to be "holding back" on a run until I put the choke back on. It then runs ok for a while and then loses power again - any suggestions please?
Frost
PostPosted: 20:44 - 02 Aug 2010    Post subject: Reply with quote
Carb sync, or mixture settings probably. might be worth checking it is seated onto the engine and airbox correctly.
rdlccrazy
PostPosted: 20:57 - 02 Aug 2010    Post subject: Reply with quote
Cheers for that - will check the seating. Is a pofessional needed to sync the carbs?
Frost
PostPosted: 21:35 - 02 Aug 2010    Post subject: Reply with quote
A set of vacuum gauges and a screwdriver usually. Either borrow some off a mate, buy a set or get a garage to do it.
Ichy
PostPosted: 21:36 - 02 Aug 2010    Post subject: Reply with quote
Might also be a bit of crud in one of the main jets. Synching the carbs is pretty easy, assuming you have the tools.
rdlccrazy
PostPosted: 13:59 - 03 Aug 2010    Post subject: Reply with quote
Thanks all. It seemed better today when I took it out. I called at the local bike shop and he has told me how to do it - just need the tools to get to one of the carbs. Looks like I'm on the cadge now - off to the mates!!!!
temeluchus
PostPosted: 14:02 - 03 Aug 2010    Post subject: Reply with quote
Float height ok? Correct mainjets? are you running an aftermarket pipe/air filter/pod filters and is it jetted to suit?
maha22 This post is not being displayed because the poster is banned. Unhide this post / all posts.
The last post was made 15 years, 191 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.05 Sec - Server Load: 1.86 - MySQL Queries: 13 - Page Size: 53.66 Kb
