First Ducati experience going as badly as expected
Oliver_FF
PostPosted: 18:50 - 03 Aug 2010    Post subject: First Ducati experience going as badly as expected Reply with quote
A few weeks ago I brought a Ducati 749 from an official Honda dealer in Kent. Schwing! It's an '07 plate with 19k miles and a fully stamped service history at 600, 6k, 10k and 15k miles.
It hadn't been serviced in a while, and going by what I've heard of ducati's, I figured it was going to need a big service so I put aside £850 to get my local garage to go over it and check everything, possibly replace a few things. Anyway I took the bike straight over there and let them have it to do their stuff. Today I got a phone call today saying "can you come take a look and we'll show you what needs doing".
I got over there, they had the thing stripped down to show me something so I went out the back and took a look. Specifically, they wanted to show me the valve clearances. 0.5cm. Yes, half a centimetre. There was so much of a gap that the cams didn't even touch the lever things (sorry, I'm no mechanic). Add to that the belts were so loose that you could twist them at the top between your thumb and first finger... They reckon the worst case scenario to get it all fixed is ~£2k. Doesn't look like the valve clearances were ever checked/adjusted at any of its previous services. The guy literally said "mate, I'm surprised you made it over here!"...
The booklet is stamped by "Motorline Ducati" Dealer code: 382897, Tel: 01233 648686.
5h1t Day.
Current bikes - 2001 CBR600F, 2007 CBR1000RR Fireblade
Previous bikes - '05 CG125, '97 CB500, '06 CBF600S, '04 ZX-6R, '07 Ducati 749
Fisty
PostPosted: 18:55 - 03 Aug 2010    Post subject: Reply with quote
Take it straight back to where you bought it and demand a refund.
Fatter and faster than Fret
pepperami
PostPosted: 18:59 - 03 Aug 2010    Post subject: Reply with quote
What Mr Fisty said Sad
Tim..
PostPosted: 19:09 - 03 Aug 2010    Post subject: Reply with quote
Sad to say its probably a fake service history, or there's something seriously wrong with it since its last service! Either way you want to be looking for a refund.
www.marshallracing.co.uk
c_dug
PostPosted: 19:13 - 03 Aug 2010    Post subject: Reply with quote
Obviously get a full write up from the mechanic first though so you have some proof of whats up Thumbs Up
Ariel Badger
PostPosted: 19:16 - 03 Aug 2010    Post subject: Reply with quote
mr_fisty wrote:
Push it straight back to where you bought it and demand a refund.
What he said but I fixed it. How did the dealer you got it from describe it?
rac3r
PostPosted: 19:31 - 03 Aug 2010    Post subject: Reply with quote
When was the stamp?
Read here: (bad rep)
https://www.ducatisti.co.uk/forum/dealers-workshops/4982-motorline-ducati-ashford.html
https://www.ducatisti.co.uk/forum/dealers-workshops/8100-your-thoughts-please-motorline-ducati.html
And more I'm afraid.
I highly recommend you take it to Ducati Proteam in Strood. Depending how far you are they do a free collection and delivery service and their prices are great.
Hope you get it sorted Thumbs Up
Chequered Flag
neatbik
PostPosted: 19:32 - 03 Aug 2010    Post subject: Reply with quote
Yep, i would want a refund too.
As said, get the mechanic to write a report, take photos, etc etc, that might grease the wheels a bit.
Also, tell the dealer you arent prepared to ride it back to them in case of severe engine failure and you want them to collect it.
Oliver_FF
PostPosted: 19:42 - 03 Aug 2010    Post subject: Reply with quote
I asked the guy if it had been serviced and he told me it had been. To be fair to them, they're a Honda garage and don't do Ducati's so they can't have known - the book IS stamped. I'm taking the documentation to where the bike is at the moment and they're going to phone up whoever stamped the book and investigate for me. I'll go to the garage (it's Kent Motorcycles on the A2) and tell them what they've sold me and either ask for a refund or get them to pay up the cost to fix it. I expect they'll tell me it's not their fault/problem.
rac3r
PostPosted: 20:03 - 03 Aug 2010    Post subject: Reply with quote
Once that is all done take it to a Ducati specialist! They have the proper knowledge and equipment to fix these bikes and indis usually end up being cheaper Laughing
For the 749 valves+belts+full service should be about £800. As said use Proteam if you are in London/Kent. Thumbs Up
Chequered Flag
colin1
Captain Safety
PostPosted: 20:19 - 03 Aug 2010    Post subject: Reply with quote
can someone explain to me why correcting valve clearances could cost £2k ?
rac3r
PostPosted: 20:22 - 03 Aug 2010    Post subject: Reply with quote
It doesn't that's my point above^^^
Chequered Flag
iooi
PostPosted: 20:29 - 03 Aug 2010    Post subject: Re: First Ducati experience going as badly as expected Reply with quote
Oliver_FF wrote:
Specifically, they wanted to show me the valve clearances. 0.5cm. Yes, half a centimetre. There was so much of a gap that the cams didn't even touch the lever things (sorry, I'm no mechanic). Add to that the belts were so loose that you could twist them at the top between your thumb and first finger....
Sorry but if the cam is not touching the valves, then they do not open.....
Ergo the bike will not run at all, as no fuel mix is getting to the engine.
I wonder just what this garage you have taken it to, has done in stripping it down.
Twisting a belt in that fashion, is a way of finding out how tight it is. I would contact a Ducati dealer and find what the spec is.... You may be surprised that it is OK.
If it was so bad then even though it was a Honda dealer you bought it from their guys would have spotted a major problem.
calyx
PostPosted: 20:29 - 03 Aug 2010    Post subject: Reply with quote
+2 then.
Boris - London
Ariel Badger
PostPosted: 20:31 - 03 Aug 2010    Post subject: Reply with quote
If it is shimmed then with 5mm clearance they could have dropped out and found their way down the motor. I do not see how that much clearance has come about unless a component has failed though so it could be a wrecked camshaft or cam bearings.
Oliver_FF
PostPosted: 20:38 - 03 Aug 2010    Post subject: Re: First Ducati experience going as badly as expected Reply with quote
The guys over there where as surprised as you that it was still running and made it to the garage. They were literally lost for words as they showed me the air gaps. They also mentioned it was probably the engine compression alone that was operating the valve(s). Referring to this picture (https://www.madducracing.com/images/749rrebuild/rscams.JPG) the two things that get bigger+smaller in the middle weren't touching the levers next to them when they were at their fattest point.
I'm going back tomorrow morning to show them the stamped booklet, I'll grab some photos Thumbs Up
Oliver_FF
PostPosted: 20:40 - 03 Aug 2010    Post subject: Reply with quote
calyx wrote:
+2 then.
£2k is a worst case figure for the major service, new belts, *new clutch*, and stripping it down to sort out the valves and anything else they might find.
Oliver_FF
PostPosted: 20:42 - 03 Aug 2010    Post subject: Reply with quote
When the cam is at it's fattest there is a tiny tiny air gap between the cam and the lever, barely a millimetre but enough to see light between them. When the cam is at its smallest the gap is like 5mm apparently.
Photos tomorrow to show you
woll
PostPosted: 20:50 - 03 Aug 2010    Post subject: Reply with quote
hmmmm just a thought, have you used this garage before? Just wondering if while they we're stripping it they decided to alter a few things to make themselves some pocket money?
Ariel Badger
PostPosted: 20:51 - 03 Aug 2010    Post subject: Reply with quote
How well was it running? I imagine with what effectively was an atmospheric inlet valve it had about as much go as a 12HP Ped.
rac3r
PostPosted: 21:02 - 03 Aug 2010    Post subject: Reply with quote
+1
How did it feel when you were riding it before the garage said 'OMG!!!' ? Laughing
Chequered Flag
swiftb
PostPosted: 21:53 - 03 Aug 2010    Post subject: Reply with quote
Damn, another thing thats putting me off buying a 749. Me being a suspicious chap and all I would be worried incase the garage who stripped it have either a) fecked somthing up in the process, or b) are trying to make a quick buck.
How recent were the belts and valves changed/checked according to the service book? Maybe some comeback from the garage who did that. Good Luck!
neatbik
PostPosted: 22:01 - 03 Aug 2010    Post subject: Reply with quote
The thing that i find funny is that Ducatis arent hard to work on, yet people pay a fortune to have work done on them!
Belts and valve clearences are easy and not particularly time consuming, and the rest of the servicing work is routine stuff as on any other bike.
I reckon im going to specialise in them, that way i'll be able to afford that Aero 8...
PostPosted: 22:13 - 03 Aug 2010    Post subject: Reply with quote
A 5mm valve clearance is ludicrous. I would suspect that would only happen if one of the shims had been spat out. The valve gear should have an easy life as nothing is having to push against heavy valve springs.
Ariel Badger
PostPosted: 22:27 - 03 Aug 2010    Post subject: Reply with quote
Keith....Two things
1. A 5mm shim seems rather thick even for a low precision Italian machine
2. Have you lost a blob?
The last post was made 16 years, 65 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 0.92 - MySQL Queries: 13 - Page Size: 133.75 Kb
