Yamaha YQ problem
Stealthy
PostPosted: 14:37 - 04 Aug 2010    Post subject: Yamaha YQ problem Reply with quote
Hi all newbie here, have a small problem,Just got a yamaha yq100 as a cheap run about apart from the odd scratches all in fine.But when i use the indicators they just turn on and not blink any idea as to what the problem might be as i do not want to pay for a new wire loom.
Thanks in advance.
PostPosted: 15:09 - 04 Aug 2010    Post subject: Reply with quote
Sounds like your flasher unit
Need one of these
https://www.bitzforbikes.co.uk/Flasher_Relay_With_Buzzer_2_Pin-ref-10299-4845-1227.html
truslack
PostPosted: 15:10 - 04 Aug 2010    Post subject: Reply with quote
Dead battery? Have you got the lights switched on at the same time / brake light?
Indicator relay?
Bulbs that are a higher wattage than the relay is rated for?
Redoko
PostPosted: 15:17 - 04 Aug 2010    Post subject: Reply with quote
Have you checked if they're actually connected properly?
Should be 1 pair of wires connected to another... Doesn't matter which go in which. Just make sure they're in all the way.
Make sure all your wires are connected for all indicators before considering revamping your wiring.
PostPosted: 15:23 - 04 Aug 2010    Post subject: Reply with quote
If they light up it is very doubtful there is a problem with how they are connected.
PostPosted: 15:24 - 04 Aug 2010    Post subject: Reply with quote
Indicator relay?
Good point if it is new to you they could be the wrong type of bulb fitted, does it look like the indicators have been messed with and changed from stock?
Redoko
PostPosted: 15:55 - 04 Aug 2010    Post subject: Reply with quote
In my experience if only 1 is connected then it doesn't flash, simply goes on.
Stealthy
PostPosted: 17:35 - 04 Aug 2010    Post subject: Reply with quote
Thanks for the replies all work but do not flash i will have a look in the morning could well be the flasher unit.
The last post was made 15 years, 216 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.75 - MySQL Queries: 13 - Page Size: 57.49 Kb
