| Jinkz |
 Jinkz Borekit Bruiser
 Posted: 12:15 - 05 Aug 2010 Post subject: RF600RV, no longer a rattle in chain, pics added! |
Right, so i've changed the cam chain tensioner, the one that came out was fine anyway. It still rattles at around 3k whilst standing.
I've taken the top off the engine, checked the chain, all seems good and is very taught with only a fraction of slack in the chain (moving it up and down, it doesn't hang at all).
I can't see the guides, but they are there, and look to be in place.
Any suggestions? So far i've had check compression, check bushes/bearing in the top cam.
It's really annoying, everything looks so tidy and complete, and the engine has never been opened.
The bike is a 1998 model and has done just 25k. ____________________ - Jinkz-
Bikes owned: RF600RV - 1998, NSR125R - 2001, GSX600F - 1998, Vespa - 2008 (won it! not sure what model?!)
| swanny |
 swanny Spanner Monkey
| Jinkz |
| temeluchus |
| Jinkz |
| temeluchus |
| Jinkz |
 Posted: 10:24 - 06 Aug 2010 Post subject: |
Yeah i've taken the carbs out already (sorry meant engine as a whole whatevers under the tank ), taken the top of engine too to check the chain etc, just haven't really touched cleaning them up in the past, i've got no problem stripping bits down, and I let my dad do all the technical bits, just need to know what I attack first. Thanks for the links.
I'll keep this thread updated this weekend let you know how i've got on.
One thing though if I need new needles etc. where would be the best place to pick those up from, I live in the Midlands if there's anywhere local? ____________________ - Jinkz-
Bikes owned: RF600RV - 1998, NSR125R - 2001, GSX600F - 1998, Vespa - 2008 (won it! not sure what model?!) |
| temeluchus |
| temeluchus |
| Jinkz |
 Posted: 20:29 - 08 Aug 2010 Post subject: |
Ok so i've just got back from about a 1 mile walk with the bike!
I cleaned out the carbs, floats, needles etc and put it all back together, booted it up and it sounded loads better, no rattle around the 3k or 6k mark anymore but just a slight rattle all over, so I thought i'll take it because i'd fitted a new chain tensioner and it might self adjust itself a bit.
Out on the road, it sounded horrible still, picked up a little better this time but I decided to turn around after 2 miles and take it back, I pulled into a road, and pulled it backwards and it wasn't very loose at all, really dragged, even with the clutch held in. Got about a mile away, just under a VERY steep hill and came over a bridge and heard a 'ping' noise, and a rattle, kept going for about 20 metres and pulled over and with another few horrible noises it stalled completely.
It wouldn't turn over at all, which is good because something nasty has happened! I'm going to open it up on Tuesday, but I suspect i'll find a snapped cam chain, at a minimum...
Not a happy day at all  ____________________ - Jinkz-
| Jinkz |
 Posted: 10:55 - 09 Aug 2010 Post subject: |
One thing to note, which made me think it might be the gearbox now, is before it broke down, I turned it around in the road, and when I pulled it backwards, in 1st gear with the clutch pulled in, it was really heavy and I really had to drag it backwards?
Just something someone mentioned, because it did move for another 10 metres or so after I heard the break, which sounds like the cam chain might have still been in tact at that point? ____________________ - Jinkz-
| Jinkz |
| Jinkz |
| Jinkz |
| temeluchus |
| Jinkz |
| temeluchus |
| Jinkz |
| Jinkz |
 Posted: 22:22 - 10 Aug 2010 Post subject: |
And so the fun continues.
I opened up the gearbox to have a check if any of the plates has smashed up inside, and nothing, it's all in tact, non of the teeth have snapped, nothing floating around inside, completely clean.
So I put it back together, started it, and there is like a flapping noise, which isn't constant, every 3-4 seconds, and I know this sounds weird but like a big palm leaf (i'm mad!).
So pulled the top off the engine again, reset the tensioner, and here's the big question. Rotated the engine backwards, and every 2nd turn (of about 20cm) there's a big bit of slack goes into the chain, making it really floppy at the top, but rotating it forwards (clockwise) it's completely taught. Would this have an impact when it's rotating? I know there's a lot of engine rattle with all the combustion going on etc but would it really make a difference?
One thing to note too, is I held the clutch in, and it still makes the flapping noise, which was making me again thing it's gearbox clutch related, but they seem fine?
Whats the thoughts now, and thank you everyone so far with this, I really do appreciate the comments! ____________________ - Jinkz-
| serlant |
 serlant Brolly Dolly
| Jinkz |
| Jinkz |
 Posted: 12:37 - 11 Aug 2010 Post subject: |
In the gearbox too, clutch plates 1 and 2 had what seemed to be machined off teeth, two on each play opposite each other, is this normal?
This sounds very familiar!!!
https://www.bikechatforums.com/viewtopic.php?t=127213&view=next ____________________ - Jinkz-
The last post was made 16 years, 26 days ago. Instead of replying here, would creating a new thread be more useful? |
