| kneedown |
 kneedown Nova Slayer
| calyx |
 calyx World Chat Champion
 Posted: 13:34 - 06 Aug 2010 Post subject: |
What I remember from the metallurgy lessons is:
There are 3 types of steel. martensit, perlit, bylit. (probably misspelled) martensit is the hard one (easy to brake/snap). perlit is semi flexible, bylit is flexible.
manufacturing martensit is very easy and cheap. heat the iron, give it some coal fire, cool it down to 400 degrees and leave it.
Probably cheap bolts are manufactured by this method. That's why you should listen Kickstart
Alternatively you can get this kind of stuff:
https://www.rimmerbros.co.uk/Item--i-FTC1368?utm_source=froogle&utm_medium=feed ____________________ Boris - London |
| pinkyfloyd |
 pinkyfloyd Super Spammer
| kneedown |
| tatters |
 tatters Exxon Valdez
 Posted: 13:50 - 06 Aug 2010 Post subject: |
I,ve got a spare box of over 100 "12.9" rated disc bolts for Yamahas they are a straight swap for All YZF models l,ve used them on my YZF750 and YZF1000,
were abouts are you located as you can have as many as you need. ____________________ Past:NRG50,AF1125(x2),NSR125RR,ZZR250,CX500,VFR400,KR1S,ZZR600(x2),CB400N,YZF1000(x2),KH125,Z200,FX400R,CBR954RR(x2)GPZ500S,GT550,VFR750F(x2),RD350N,XR650R,CBR600F,CB250,KDX250,YZF750R,CRM250,400EXC,KLR650,TTR600RE,DR350S,R100GSPD,RGV250,VMAX1200,DL650,KZ750 Present:G650XC,C12,CRF450X,1190ADV |
| kneedown |
 Posted: 14:18 - 06 Aug 2010 Post subject: |
hi mate im in south london, that would be really appreciated, how much for 12 of them
cheers  |
| tatters |
 Posted: 14:50 - 06 Aug 2010 Post subject: |
Thats good l,m near south london in west molesey, surrey
You can have 12 for free, say £2 for postage or you can pick them up.
Send me a PM and let me know whats good for you.
There black high tensile steel so you might want to coat or paint the heads once there fitted as they will corrode over time being made of steel something l,ve never bothered to do on my bikes. ____________________ Past:NRG50,AF1125(x2),NSR125RR,ZZR250,CX500,VFR400,KR1S,ZZR600(x2),CB400N,YZF1000(x2),KH125,Z200,FX400R,CBR954RR(x2)GPZ500S,GT550,VFR750F(x2),RD350N,XR650R,CBR600F,CB250,KDX250,YZF750R,CRM250,400EXC,KLR650,TTR600RE,DR350S,R100GSPD,RGV250,VMAX1200,DL650,KZ750 Present:G650XC,C12,CRF450X,1190ADV |
| colin1 |
 colin1 Captain Safety
| colin1 |
 Posted: 12:03 - 07 Aug 2010 Post subject: |
Yes friction is what stops bolts coming loose which is how all bolts stay tight, but I'm talking about the friction between the disc and the wheel, not the bolt and the wheel, or the bolt and the disc.
Strictly speaking the bolts are in both shear and tensional forces combined. The bolt clamps the disc with tensile forces and the disc is held by frictional forces against the hub. If those frictional forces are overcome, shear forces will take up the remainder of the load. Copper bolts wouldn't have anything like the tensile or shear strength for either job. ____________________ a.k.a 'Geri'
| colin1 |
| The Tot |
 The Tot World Chat Champion
 Posted: 12:18 - 07 Aug 2010 Post subject: |
| calyx wrote: | What I remember from the metallurgy lessons is:
https://www.rimmerbros.co.uk/Item--i-FTC1368?utm_source=froogle&utm_medium=feed |
It's Martensite, Pearlite and Bainite. You have Austenitic and Ferritic steels too. It's all to do with the processing temperatures and alloying content. The Iron-Carbon phase diagram will help to explain how the different phases/structures are formed. In short, it has all to do with the grain structure of the steel. Martensitic steel is very hard with needle like grains. Anyway long and short of it... different phases mean different grain structures which has a direct effect on mechanical properties content (you have other factors like precipitates etc as a result of alloying composition).
Generally speaking, something that is hard isn't ductile and you'd need something with adequate tensile strength in this application.. stainless steels do not qualify for high tensile bolts otherwise they'd be using them in some of the environments I see at the power station.
Yeah, it sucks to be a metallurgist by qualification! ____________________ The Tot 2019 Z1000SX - 2007 R1
Never argue with autism |
| MaybeGuy |
 MaybeGuy Super Spammer
 Posted: 12:20 - 07 Aug 2010 Post subject: |
i wouldnt feel that unsafe using standard 8.8 grade plated steel bolts or something.
If theres 12 of them per disc then i doubt theyd ever shear.
All i would do is maybe use countersunk bolts to properly centralise the disc. Not that it matters too much. ____________________ Blue_SV650S wrote: it was a sh1te wheelie, but it proves that he can get it up in 3rd and can do angles. In summery, mattsprattuk is a gobby little sh1tebag, dopehead tw4t, but sadly for all of us, he probably isn't THAT full of sh1te!!
 Posted: 12:28 - 07 Aug 2010 Post subject: |
Actually, having given it some thought on most discs runout is controlled by locating the ID of the carrier on the hub. ____________________ a.k.a 'Geri'
| calyx |
| hamed |
 hamed L Plate Warrior
The last post was made 16 years, 21 days ago. Instead of replying here, would creating a new thread be more useful? |
