computer not switching on :(
Bike Chat Forums Index -> The Geek Zone Goto page 1, 2, 3, 4, 5  Next
TQ
PostPosted: 21:36 - 06 Aug 2010    Post subject: Reply with quote
You need to try a replacement power supply.
The problem is that it could be either the PS or the motherboard. Personally I'd try a new PS and if that didnt work would assume it was the board. The thing is that I have access to spare power supplies.
If you can get a mates PC or something you just need to try the 24 and 4 pin power connectors on the motherboard, if it boots then buy a new PS if it doesn't then it's (and I use the technical term) fucked.
First Bike :Gilera DNA 50 | Second: Imported 1989 NSR125
Third: 1998 Yamaha XJ600N | Currently: 1999 Yamaha FZS600
arry
PostPosted: 21:41 - 06 Aug 2010    Post subject: Reply with quote
Yup, I'd go with that. PSU or mobo. Let's hope it's the former.
Frost
PostPosted: 22:15 - 06 Aug 2010    Post subject: Reply with quote
PSU is fucked, most had a fuse in them that will blow. You could try replacing it, but chances are its blown for a reason. Buy a new PSU and hope the motherboard isn't toast.
Carl_steveo
PostPosted: 22:57 - 06 Aug 2010    Post subject: Reply with quote
If your computer is fucked how did you post this. Shocked Shocked
WITCH BURN HIMMMMMMMMMMMMMMMM!! Twisted Evil Twisted Evil
Current: Honda Nsr 125
Live: Sunderland
doggone
PostPosted: 23:22 - 06 Aug 2010    Post subject: Reply with quote
You might source a similar used power supply from ebay for about a fiver.
panrider_uk
PostPosted: 03:46 - 07 Aug 2010    Post subject: Reply with quote
Only £20 for a new PSU
Mark
CaNsA
PostPosted: 11:01 - 07 Aug 2010    Post subject: Reply with quote
In addition to what the pan man said,
Its not much different from changing the battery and fuse box on yer bike.
Frost
PostPosted: 13:53 - 07 Aug 2010    Post subject: Reply with quote
Take the side of your PC case off and you will see how many watts the PSU is rated for as it's written on the side. either go buy one of the same wattage, or take the PSU out and take it to any PC show (PC world will do) and ask for another.
The PSU is held in with 4 screws at the back, 1 or 2 connections to the motherboard, a connection to each hard disk and CD / DVD drive.
I changed mine about a week ago, it was done in under 5 minutes.
TQ
PostPosted: 14:22 - 07 Aug 2010    Post subject: Reply with quote
Just buy a 3 or 4 hundred watt PSU and you'll be fine.
Frost
PostPosted: 16:40 - 07 Aug 2010    Post subject: Reply with quote
Nope. Razz A good quality PSU can cost hundreds, but £15 might almost get you one that will work.
450W £15.26 + delivery. They can be quite heavy so you might be better off spending £20 on one from a local PC shop.
Ingah
PostPosted: 01:09 - 08 Aug 2010    Post subject: Reply with quote
Be careful not to buy a PSU with a lower 12V rail ampage than the existing supply. 12A rail supplies the motherboard, CPU and graphics (i.e. the important bits).
You see, i had a 300W Bestec (cheap and nasty) unit that died, so i went and assumed a 350W FSP unit would be fine (as it's a better brand, although still low-end). It wasn't, it didn't work. Managed to return it under the DSR as i'd bought it online (i claimed it was dead on arrival, and genuinely believed so at the time). So went and bought a 400W Octigen PSU. And that didn't work either (and i can't return it either now, so it's a paperweight) Whilst the whole time a PSU i'd nabbed from my old gaming machine (noteably a cheap 460W supply with 30A on the 12V rail), worked perfectly!
In the end, i worked out it was the 12V rail ampage preventing these new supplies working because the original supply was 19A, and i read a technical manual for my machine, and it said the machine needs 18A or more on that rail. I didn't check the amps of the FSP supply, but the Octigen was only 12A!!
Another word of warning - when (especially cheap) PSUs die they often take out other expensive components... And the MTBF (Mean Time Before Fail) of these low-end supplies is often only 10,000 hours (just over a year of continuous running) - and by that point 50% of the supplies have failed! For a few extra quid (often as few as 5), you can get supplies with 100,000 hours. Much more reassuring, although of course not quite as assuring as a premium brand and a 5 year warranty Wink
-- Ingah
Frost
PostPosted: 01:30 - 08 Aug 2010    Post subject: Reply with quote
I bought a £90 PSU, lasted 2 years. Bought a £20 lasted 2 years, current PSU is a £17 one, it will probably last the same 2 years. It came with a HORRIBLE fan that made a right racket when the case was level, but silent when tilted forwards. I bought an akasa silent fan and have put it in there connected to the hard drive prower supply with the speed control wire cut to run it on full speed constantly. A week in and it's still running Shocked Wink
I justify it to myself by claiming to be a official mad scientist... lets see how that turns out.
panrider_uk
PostPosted: 08:59 - 08 Aug 2010    Post subject: Reply with quote
Some thing like the ColorsIT Gold range are cheap (£20ish) and fairly quiet.
We get through lots of power supplies at work due to carbon fibre dust in the air which gets sucked into the pcs. Very seldom does a blown PSU take out anything else.
Mark
Frost
PostPosted: 16:51 - 08 Aug 2010    Post subject: Reply with quote
M.T.B.F. 10,000 Hours
10,000 / 24 = 416days average time to failure.
Casper
PostPosted: 22:38 - 08 Aug 2010    Post subject: Reply with quote
If running windows 7 it recommends a 400 watt minimum psu but having said that mine is only 350 and runs fine. Only thing if your hard disk and cd rom are sata you might need an adapter as the one you chose has only 1 sata connection.
Frost
PostPosted: 23:33 - 08 Aug 2010    Post subject: Reply with quote
PSU requirements depends on the hardware not the operating system. I'm pretty sure a windows 7 netbook won't need 400w Wink
The last post was made 16 years, 36 days ago. Instead of replying here, would creating a new thread be more useful?
Page 1 of 5
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.14 Sec - Server Load: 0.83 - MySQL Queries: 13 - Page Size: 131.02 Kb
