Damn! £20 to replace a tiny CG125 carb washer!
Ingah
PostPosted: 02:06 - 14 Aug 2010    Post subject: Damn! £20 to replace a tiny CG125 carb washer! Reply with quote
Whilse restoring my CG125 (changing the throttle cable at this particular moment), i managed to lose/drop a small washer through the cracks in the floorboard - it's 1 of the 3 pieces that make up the "jet needle assembly" (i'll attach an image from my Haynes - it's item 6 - the one in the middle). It's at the top of the carburettor anyway.
Unfortunately, yep, it only comes as a set. For £20. Not even NRP Carbs can help me (they don't do the bits for my CG apparently). I guess the needle itself looks a little worn, but that feels more like me telling myself i'm not completely chucking the £20, when inside i know that i am.
So do i just bite the bullet and take (yet another) £20 hole in my side, or does anyone know where i could get this tiny washer from?
-- Ingah
Frost
PostPosted: 02:10 - 14 Aug 2010    Post subject: Reply with quote
Most of that money is for the needle. The washer will have an internal diameter in millimeters, e.g 3mm, that would mean you would need an M3 washer. Go to a hardware store and take the other bits with you and see how which fits best. I needed some M3 washers fro my carbs once, the guy at the hardware store just gave them to me!
Odie
PostPosted: 13:06 - 14 Aug 2010    Post subject: Reply with quote
Its not a washer, its a "C" clip, go to a bike breakers or if they wont help you a fastener supplier, take the needle with you and the can measure the size required.
stirlinggaz
PostPosted: 13:13 - 14 Aug 2010    Post subject: Reply with quote
i bought a box of assorted c-clips for this very purpose.
think it was from machinemart or screwfix or somewhere similar.
was only about 6 quid,iirc.
had the tiniest clips that fit onto dellorto needles & also onto mikuni needles & had some smaller, so im pretty sure you'd get one to fit.
have a look around for a box of assorted c-clips,
cheers,
GAZ
Ingah
PostPosted: 20:57 - 14 Aug 2010    Post subject: Reply with quote
A C-clip is the other remaining part (which i haven't lost). I assure you, i lost a little round washer, and it is one of those 3 parts. Although it can't hurt to buy some C-clips, as i'm guaranteed to need them sooner or later Laughing
But thanks for all the help guys, i will be taking the needle down to get it sorted out (tried today but i was running late so only B&Q was open and they were no good, so i'll try some proper hardware shops soon).
-- Ingah
The last post was made 16 years, 22 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 0.63 - MySQL Queries: 13 - Page Size: 49.17 Kb
