CG125 "pop" and now high pitched rattle
Derivative
PostPosted: 20:05 - 14 Aug 2010    Post subject: CG125 "pop" and now high pitched rattle Reply with quote
Hello, some background history, I am a new biker, picked up the CG about 6 days ago, had 18925 miles on her. Replaced the oil and spark plug when I got her.
About 375 miles later, I was cruising about 45mph when the bike made a sort of "pop" sound and then started a high pitched rattle and lost power, down to about 30mph in top gear (was 55).
Had to ride the bike home in this condition, it's recovered a bit in power and quietened down but still sounds a lot louder than before. Any ideas what I might have to check?
Skudd
PostPosted: 20:43 - 14 Aug 2010    Post subject: Reply with quote
Sounds like not enough oil and you have fucked it.
Derivative
PostPosted: 20:47 - 14 Aug 2010    Post subject: Reply with quote
Oil level is just shy of 'max' and has been since I got the bike.
radical
PostPosted: 20:48 - 14 Aug 2010    Post subject: Reply with quote
Op, how did you check the oil level and is the bike losing any oil or smoking badly?
Derivative
PostPosted: 20:52 - 14 Aug 2010    Post subject: Reply with quote
Wiped off the dipstick and let it rest in without screwing it. There's two notches on it, one for max and for minimum, no oil above max when I do that.
Doesn't seem to be losing oil, it's been 100 miles on that amount. No visible smoke while it's in neutral ticking over.
radical
PostPosted: 20:58 - 14 Aug 2010    Post subject: Reply with quote
remove the rocker box cover from the top of the engine and check your valve clearances with the engine cold, also remove your plug and check the colour, white would indicate weak running and a sooty black plug would indicate rich running. Also check the airfilter is intact and clean.
Derivative
PostPosted: 12:30 - 15 Aug 2010    Post subject: Reply with quote
Off to pick up a feeler gauge so I can check the clearances today, cheers for the help rad I'll post on here with how it goes
Skudd
PostPosted: 13:20 - 15 Aug 2010    Post subject: Reply with quote
You may find that oil isn't getting around all of the engine. I had a bike that the oil feeder was blocked with crap and so buggered everything.
Derivative
PostPosted: 14:14 - 15 Aug 2010    Post subject: Reply with quote
Picture of the spark plug
Derivative
PostPosted: 18:48 - 15 Aug 2010    Post subject: Reply with quote
Valve clearances are both fine, one was about 0.10 but i've tightened it up to 0.08
The air filter's not overly dirty either. :/
Quote Me Happy
PostPosted: 18:53 - 15 Aug 2010    Post subject: Reply with quote
I'd be tempted to take the cover off the top of the engine to get access to the piston and barrel and peek inside.
Derivative
PostPosted: 20:06 - 15 Aug 2010    Post subject: Reply with quote
Am I right in saying 'tappets' are the valves I just adjusted? There's more than enough oil in there, nice and clean as well
If I open up the engine, what would I be looking for?
Derivative
PostPosted: 20:32 - 15 Aug 2010    Post subject: Reply with quote
Daft question then, what bolts are you referring to, if I show you a picture.
I'm kind of confused what you mean by the "head" of the engine, the top cover has three bolts and the rest is attached to the exhaust etc I'd have to remove
robocog
PostPosted: 20:58 - 15 Aug 2010    Post subject: Reply with quote
Broken down ....
Needs a bigger garage...
The last post was made 16 years, 24 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.52 - MySQL Queries: 13 - Page Size: 84.7 Kb
