WHAT OIL DO I NEED? 2 STROKE..
 Topic moved: from General Bike Chat to The Workshop by Bendy (16 Aug 2010 - 15:18)
Mord
PostPosted: 16:17 - 16 Aug 2010    Post subject: Reply with quote
2T oil for 2T engine
4T oil for 4T engine
Unless you mean a gearbox oil.
PostPosted: 16:18 - 16 Aug 2010    Post subject: Reply with quote
u need 2 stroke oil for a 2 stroke machine.
it'll normally say 2T on the front.
dextersaurus
PostPosted: 16:19 - 16 Aug 2010    Post subject: Reply with quote
Normal engine oil in the sump, and in the 2 stroke oil tank, you need some 2 stroke oil Thumbs Up
What bike is it?
https://cgi.ebay.co.uk/TOTAL-OIL-2-STROKE-SEMI-SYNTHETIC-OIL-1-LTR-/370348248945?pt=UK_Home_Garden_GardenPowerTools_CA
2 stroke oil goes in the wee plastic 2 stroke oil tank
Dunc
Mord
PostPosted: 16:23 - 16 Aug 2010    Post subject: Reply with quote
hahadumball wrote:
but im confused because.
the engine oil dosent actualy go near the top end..
thats wat my 2 stroke oil tank is for.
just utter confused :/
i asshumed i could use any oil in the crank case as its the engine not the piston
Not directly.. The oil from separate tank goes to a carburettor first and from there through reed valve to a combustion chamber.
Mord
PostPosted: 16:27 - 16 Aug 2010    Post subject: Reply with quote
I just looked at your sig..
Proud owner of a 1989 yamaha sr 125 (still on L plates )
Isn't a Yamaha SR 125 a 4-stroke?
dextersaurus
PostPosted: 16:28 - 16 Aug 2010    Post subject: Reply with quote
i saw that and assumed he had another bike...
JAMSXR
PostPosted: 16:30 - 16 Aug 2010    Post subject: Reply with quote
Washing up liquid should do the job! Thumbs Up
Mungel
PostPosted: 16:34 - 16 Aug 2010    Post subject: Reply with quote
Mungel
ZZR600 (dead) - ZX9R (sold) - FZ1S
With a handful of sand.
TQ
PostPosted: 16:35 - 16 Aug 2010    Post subject: Reply with quote
You don't put oil in a two stroke engine the lubrication comes from oil mixed with the fuel (in your case it is mixed using oil from the 2T oil tank before it goes through the carb).
Do you mean gearbox oil? Exactly where on the bike do you think you need to put oil in?
First Bike :Gilera DNA 50 | Second: Imported 1989 NSR125
Third: 1998 Yamaha XJ600N | Currently: 1999 Yamaha FZS600
Mord
PostPosted: 16:39 - 16 Aug 2010    Post subject: Reply with quote
hahadumball wrote:
its a yb 100.
i have the 2 stroke oil in the 2 stroke tank obviously just wasnt sure if i could use "engine oil for 4 strokes"
in my engine. (not the 2 stroke tank)
I assume that by "engine oil" you mean a transmission oil.. usually 10W-40.
radical
PostPosted: 16:40 - 16 Aug 2010    Post subject: Re: WHAT OIL DO I NEED? 2 STROKE.. Reply with quote
hahadumball wrote:
dumb question but..
what oil do i put in my 2 stroke engine..
i have a tank for 2 stroke oil and also i need oil in my engine, what oil do i put in?
i have some mineral oil from tesco (cheap shit)
but it says for 4 strokes, does that matter or do i specificly need 2 stroke engine oil.
sorry for my dumbness
There is no such thing as 4 stroke oil and the labelling on the containers can be very confusing. The mineral oil you have bought is the correct stuff for your bikes gearbox but only use 2 stroke oil in the oil tank which mixes with the petrol via an oil pump.
PostPosted: 16:45 - 16 Aug 2010    Post subject: Reply with quote
ApriliaNutter wrote:
hahadumball wrote:
its a yb 100.
In my experience gearbox oil is much heavier than that.
PostPosted: 16:50 - 16 Aug 2010    Post subject: Reply with quote
Car gearbox oils can often have higher numbers but they are not directly equivalent to engine oil numbers. 10W40 is a pretty common oil in bike gearboxes.
Mord
PostPosted: 16:51 - 16 Aug 2010    Post subject: Reply with quote
Well.. it was recommended for my Aprilia RS125 by a dealer (and they filled my gearbox with 10W-40 when they were servicing my bike). I've never had any issues with the transmission.. But people use i.e. 75W-90 instead.
PostPosted: 16:56 - 16 Aug 2010    Post subject: Reply with quote
Gearbox and engine oil weight values appear to be different. What is marked 'Light gear oil 80w' is roughly equivalent to 10W40.
OP, you don't need to change gearbox oil very often on a two stroke, and when you do you can either go to Wemoto and buy some two stroke gearbox oil, or you can put 10W40 four stroke engine oil in there.
The engine is oiled from the two stroke tank, and the gearbox is lubricated from the gearbox oil which is where the filler cap on the side of the crankcase goes.
Now your question has been answered to your satisfaction you may leave this terrible forum where no-one answers the questions fast enough for you.
dextersaurus
PostPosted: 17:14 - 16 Aug 2010    Post subject: Reply with quote
hahadumball wrote:
im 12 how am i suposed to know what oil i need Sad
Wait, Wut?
dextersaurus
PostPosted: 17:27 - 16 Aug 2010    Post subject: Reply with quote
i'm twelve years old and what is this?
The last post was made 16 years, 24 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.11 Sec - Server Load: 0.78 - MySQL Queries: 16 - Page Size: 137.63 Kb
