RS125 overheating
pits
PostPosted: 15:20 - 16 Aug 2010    Post subject: RS125 overheating Reply with quote
Not familiar with bikes at all, to be fair not even ridden this yet, as I haven't done my CBT.
Brother has an Aprilia RS125, even before he bought it I told him it will probably cost him a small fortune, just had it rebuilt and essentially running it in now, guy who rebuilt it is well recommended by most I have spoken to, I am only seeing this as a third party type of view here, but it the bike has been back forth, it has done more miles in the back of a van than on the road.
Problems I can find so far or know off
Clutch, with the bike turned off, put it into first gear, pull the clutch in and you can feel the clutch isn't fully disengaged, you can move the bike back and forth but you can feel the compression.
Starting, takes about 30 seconds of cranking before it splutters into life, and you have to keep it going for the first 30 seconds or it will cut out, and you have to repeat the process.
Riding on the road, apparently it gets hot temperature wise, then cuts out and wont restart till it cools down, I don't know on that as I can't ride it.
Now with my CBT coming up one Wednesday I wouldn't mind getting it insured in my name and using it, but I don't fancy breaking down all the time, can anyone provide me with some tips or something to look for? I really have no idea with bikes
PostPosted: 17:18 - 16 Aug 2010    Post subject: Reply with quote
They can be a bit grumpy starting. However if just rebuilt I assume it is being run in which doesn't give it a chance to clear its throat and gives the spark plug a hard time (especially if it has a colder plug intended for a full power one).
On the over heating thing, first thing to do is check that the cooling system is bled through. There is a screw to allow you to bleed the cooling system on the pipe near the battery and header tank.
If that doesn't fix it then it could be that the thermostat has failed (they seem pretty reliable though normally) or the water pump has failed (possible, but would expect it to over heat very quickly).
Other possibility is that the coolant is too much anti freeze and too little water. If so the resulting mix is too thick and the pump struggles to push it round at a decent rate.
MinhDinh
PostPosted: 17:27 - 16 Aug 2010    Post subject: Reply with quote
70-80 is normal.
I had my bike go to 125 celcius on me.
Basically my bike had grey kinda smoke and went to 100 and started flashing.
I sent it to the mechanics and they used a gauge outside and it was normal. He looked inside and said the cap of the radiator needs changing so I bought a new one.
Rode home and it went to 100 again so I took it back. He said it should be OK and water was on the cap and bike's temp gauge. He checked the outside again.
So I rode home and it hit 125 Celcius and the bike cut fof and lcoekd up. Luckily no car was on the right side or I would have been fucked.
I told him to check again and he found out the wheel for the water/coolant was broken.
Hit the G spot. Wink
pits
PostPosted: 18:17 - 16 Aug 2010    Post subject: Reply with quote
Thanks guys, will start doing some basic checks on the bike, be nice if I had my CBT so I could actually go out and ride it to see for myself what is happening and trying to bleed the system whilst out
pits
PostPosted: 13:15 - 19 Aug 2010    Post subject: Reply with quote
I will be taking the bike out either tonight or tomorrow, but a bit more light on the problem.
Bike gets to 78 on temp and is fine, then you stop at a junction, pull off and then it cuts out and wont restart for 30 secconds then it's fine.
I will report back my proper findings when I have ridden it
Acemastr
PostPosted: 12:13 - 20 Aug 2010    Post subject: Reply with quote
but im 12 Wink
and that post was mainly to show that im part of a massive hacking community Smile
as a pose to bcf where questions take weeks for an answer Smile
Who the fuck cares.... is that intimidation or are you acting 12?
2016 Toyota Tacoma Limited
PostPosted: 12:15 - 20 Aug 2010    Post subject: Reply with quote
So someone who doesn't get a reply within seconds of posting and instead decides to rant at people then tries to threaten us as they are a member of a hacker forum just because someone takes them to task when they post hearsay about a bike they have never had.
TQ
PostPosted: 12:26 - 20 Aug 2010    Post subject: Reply with quote
You're an idiot.
First Bike :Gilera DNA 50 | Second: Imported 1989 NSR125
Third: 1998 Yamaha XJ600N | Currently: 1999 Yamaha FZS600
Acemastr
PostPosted: 12:32 - 20 Aug 2010    Post subject: Reply with quote
not threatening at all.
stating that im part of a much bigger community so bcf is nothing to me
and hear say.
yes it pretty much is because ill i ever hear is "oh my rs 125 blew up"
as always
Please kindly flounce, you won't be missed Smile
PostPosted: 12:42 - 20 Aug 2010    Post subject: Reply with quote
Whoopie do. Either it is irrelevant boasting or a threat.
hahadumball wrote:
and hear say.
Try buying one and find out how quick they are. They are quick little bikes that handle very well. Maintain them well and they are reliable.
pits
PostPosted: 21:50 - 20 Aug 2010    Post subject: Reply with quote
Right back in from my first ride out on the bike, 350 or so miles covered in 6 hours, mixed riding, alot of country road that I know, mixed with a fair bit of town and traffic riding.
It cut out once on me and instantly restarted, the problem my brother is having didn't really show its head, although I did stall it 3 times with clutch in, but started fine when I put it into neutral.
Left the bike for around an hour, started it, and it cut out, bogged down, restarted it and had to feather the throttle as it had overfuelled by the looks of it, so a few quick blips cleared it and it was fine.
Problem getting second gear when cold, I assume it is wet clutch? And down to the fluid not being hot? Cars do similar.
The problem I was getting though was a misfire or stutter
On the flat it was fine, it would have a quick stutter then clear through it and take off.
Downhill, no stutter at all
Uphill or underload,slightly wrong gear and it would stutter a fair bit between 4000rpm and 5000rpm, but when you get past that area it would again clear up and go.
As for BCF not really being browsed and taking "for ever" to get an answer, meh so what, least there are people willing to spend there time to actually help, so what if it takes 30 seconds or 30 days, at least someone is actually helping Thumbs Up
PostPosted: 21:57 - 20 Aug 2010    Post subject: Reply with quote
If it is bogging down from 5000 to 6000rpm (rather than 4000 to 5000) then this is probably the environmental dip - a deliberate flat spot engineered in and which the cdi unit can be modified to remove (there is a massive amount of ignition retard in that rev range).
c_dug
PostPosted: 22:01 - 20 Aug 2010    Post subject: Reply with quote
A bit off topic but I love the fact that Kickstart writes a post like the above and still signs off with:
c_dug
Acemastr
PostPosted: 22:16 - 20 Aug 2010    Post subject: Reply with quote
Little off topic, cars have dry clutches, the reason for it being slightly difficult is the gearbox oil isn't warm.
All bikes are clunky changing gear when cold.
pits
PostPosted: 23:12 - 20 Aug 2010    Post subject: Reply with quote
Sadly it is between 4-5krpm, it doesn't feel like an engineered flat spot, it feels and sounds more like a miss fire, if you nail the throttle from start off, it will still jerk and bog down.
pits
PostPosted: 18:53 - 22 Aug 2010    Post subject: Reply with quote
Right I have taken all the info on board, and I have done some extensive testing today in the sunshine Mr. Green Thumbs Up basically, it gets to 75, and then the carb just floods the engine and bogs it down, bit of a pain, but a set up on the carb and it should be good to go,
Thanks to those who actually helped Thumbs Up
The last post was made 16 years, 18 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 0.51 - MySQL Queries: 13 - Page Size: 141.13 Kb
