Knocking when braking?
Wabby
PostPosted: 11:53 - 17 Aug 2010    Post subject: Knocking when braking? Reply with quote
Hi Guys,
Rode a mates bike last night and noticed that when you either:
a) Brake very hard on the front
b) Shift alot of weight up front
their is a 'knock' coming from the front end?
Checked pads/discs/wheels and they ok.
Checked suspension and that seems fine.
No play in head bearings etc
And it passed an MOT last week.
Any ideas? Or nowt to worry about?
Holds a straight line well, corners well, and stops well, so can't see it being 'too' serious?
What restriction?
Wabby
PostPosted: 11:59 - 17 Aug 2010    Post subject: Reply with quote
Only happens under braking when braking hard AND going slow.
If going warp speed and braking hard for a sharp corner, then no knocking (or at least that can be heard)
What restriction?
Ed Case
PostPosted: 12:06 - 17 Aug 2010    Post subject: Reply with quote
You've eliminated pretty much all it could be but I'd suggest a further check on the head bearings, when you bang the brake on there's tremendous force going through the headstock. Something else you might check on is the state of the top and bottom fork yokes, I've had a top one crack on me in the past. Well worth a look. Best of luck.
The Artist
PostPosted: 12:22 - 17 Aug 2010    Post subject: Reply with quote
Get front wheel off the ground and pull and push on the front axle very hard.
Mine did the same and I tightened the head bearings and it was fine.
The last post was made 16 years, 31 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 4.2 - MySQL Queries: 13 - Page Size: 38.62 Kb
