| Neorion |
 Neorion World Chat Champion
| chris-red |
| Neorion |
| elky |
 elky Renault 5 Driver
| Neorion |
| chris-red |
| Digitalize |
 Digitalize Nearly there...
 Posted: 15:43 - 17 Aug 2010 Post subject: |
Either Quad Core, or go for the E7400, which i have in my Rig.
Currently sitting at a stable speed of 4.2Ghz
Cheap as chips too. ____________________ 1998 CB600F Hornet |
| The Artist |
 The Artist Super Spammer
| Neorion |
| chris-red |
| Welshd1k |
 Welshd1k World Chat Champion
| Hetzer |
 Hetzer Super Spammer
| Welshd1k |
| JonB |
 JonB Afraid of Mileage
 Posted: 20:30 - 17 Aug 2010 Post subject: |
I had my E6750 @ 3.8 Ghz for a while, but it was running way too hot for my liking. Ended up having it @ 3.2-3.6 depending on the ambient temperature.  ____________________ Be careful whose advice you buy, but, be patient with those who supply it. Advice is a form of nostalgia, dispensing it is a way of fishing the past from the disposal, wiping it off, painting over the ugly parts and recycling it for more than it?s worth. |
| Neorion |
 Posted: 21:25 - 17 Aug 2010 Post subject: |
| Welshd1k |
| Hetzer |
 Posted: 14:20 - 18 Aug 2010 Post subject: |
Scratch what I said about mine running at 71-degrees under load. It went to 77-degrees on the last test and bells started ringing. After some research it turned out the program I was using to monitor the temps (Coretemp) had the wrong TjMax value inputted (and couldn't be changed). After getting Realtemp (which is what I usually use, I was using Coretemp only so I could run a desktop gadget) and inputting the correct TjMax value my temps are actually 10-degrees lower.  ____________________ "There's the horizon! Ride hard, ride fast and cut down all who stand in your way!" |
| chris-red |
 Posted: 17:09 - 18 Aug 2010 Post subject: |
I had that q6600, underwater at idle it was 17deg it never went above 23 under load the temp inside the case was 21 deg.
I had it OC'd at 3 ghz for a while, still it didn't get much above 40 under load. Water cooling for the win, my new i7 is a hot fecker though, that was running at 40 degrees stock under water.
It's amazing the difference decent thermal paste makes, my 8800gts was running at about 80-90 deg under load, I took it apart and replaced all the shitty thermal paste 'sticker things' they use with Artic silver now it runs at 53 under load. ____________________ Well, you know what they say. If you want to save the world, you have to push a few old ladies down the stairs.
| Hetzer |
 Posted: 15:13 - 19 Aug 2010 Post subject: |
| chris-red wrote: | I had that q6600, underwater at idle it was 17deg it never went above 23 under load  the temp inside the case was 21 deg.
It's amazing the difference decent thermal paste makes, my 8800gts was running at about 80-90 deg under load, I took it apart and replaced all the shitty thermal paste 'sticker things' they use with Artic silver now it runs at 53 under load. |
Arctic Silver FTW, I've been using it for years. Can't do much about the shite they use on chipset heatsinks though. I had an MSI NForce board and the stuff on the MOSFETs might as well have been a duvet. Then they wonder why they're shite boards for overclocking.
I've had to give up on 3.6ghz, for some reason it won't run stable in Prime95 (used to be fine). I've lowered the multiplyer to x8 400FSB and it's superb now at 3.2ghz. 25-degrees at idle (20 if just out of sleep mode) and just on 60 in Prime95. ____________________ "There's the horizon! Ride hard, ride fast and cut down all who stand in your way!" |
The last post was made 16 years, 26 days ago. Instead of replying here, would creating a new thread be more useful? |
