Scottoiler
fraseb01
PostPosted: 22:06 - 19 Aug 2010    Post subject: Scottoiler Reply with quote
Hi All,I recently got my new bike which has a scottoiler,i have never used one before,how do i refill and where is good place to purchase refill oil? cheers in advance guys
Bike - GSXR 600 K3
flumpy7
PostPosted: 22:48 - 19 Aug 2010    Post subject: Reply with quote
You can buy refill scottoil at any good motorcycle parts store. To refill there should be a chamber somewhere. Its often located under the seat or cable tied to the frame. Just follow the tubing from the application nozzle at the rear wheel to trace it back. There is a rubber filler plug connected to the chamber which can be removed to fill it up. Usually the refill bottles come with a tube attached and a little adapter at the end of the tube to fit into the chamber.
I love scottoilers, wouldnt be without one now. Play around with the rate so you dont get too much spray on the rear wheel, there is dial on the chamber. I find a drip every 10-15 seconds works well. Good luck.
yen_powell
PostPosted: 07:13 - 20 Aug 2010    Post subject: Reply with quote
I've used clean engine oil in scottoilers with no problems. Mind you I had a 5 litre container of Halfords car stuff lying about idle, so it had to be put to work somehow.
XT1200Z and a DR350 in bits
fraseb01
PostPosted: 14:37 - 20 Aug 2010    Post subject: Reply with quote
Thanks Guys,Will have a look this weekend,not a lot of oil lying around on arm or wheel but chain looks good,must be set perfect. Very Happy
Bike - GSXR 600 K3
defblade
PostPosted: 15:37 - 20 Aug 2010    Post subject: Reply with quote
Watch out tho - the thickness of the oil varies with temperature so you'll need a higher flow rate set when it's cold and the oil is thicker and slower.
Worth turning it up a bit if you're riding in rain a lot, too.
fraseb01
PostPosted: 16:23 - 20 Aug 2010    Post subject: Reply with quote
nose got better of me,just been out to garage,scottoiler nearly empty,set on number 2,i filled it up with some chain oil i had, this will do till i order the real deal,i had a look on ebay they all seem to be around 10 quid inc delivery for 500ml. Very Happy
Bike - GSXR 600 K3
LeeR
PostPosted: 19:57 - 20 Aug 2010    Post subject: Reply with quote
Check out the Scottoiler website there's a wealth of information there on, fitting, filling, priming and other stuff, and realistically 500ml should only cost around £7 from the likes of Hein Gericke or your local dealership.
My claim to fame: Austin Vince nicked my pen...
fraseb01
PostPosted: 23:09 - 20 Aug 2010    Post subject: Reply with quote
will have a look at dealers this weekend,if weather good will be out for a blast. Thumbs Up
Bike - GSXR 600 K3
The last post was made 16 years, 29 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 1.55 - MySQL Queries: 13 - Page Size: 56.45 Kb
