how to raise a car (for oil change?)
steppen22
PostPosted: 11:06 - 22 Aug 2010    Post subject: how to raise a car (for oil change?) Reply with quote
I'm new to cars, and I'd like to change the oil. Problem: how to get to the drain bolt? (mondeo, mk2)
I've looked into having the car serviced but it seems you don't really get much for your money - topping up windscreen washer, etc.
no regrets, no retreat, no apology.
I've made mistakes in the past, and I apologise for FUCK ALL.
PostPosted: 11:09 - 22 Aug 2010    Post subject: Reply with quote
https://www2.hiren.info/funny/pictures/little-strong-baby-lifting-car.jpg
PostPosted: 11:11 - 22 Aug 2010    Post subject: Reply with quote
I borrowed some ramps. (will buy some soon)
Happens to be a nice slope outside my house so even when up the ramps the oil flowed out fine.
Pat
Don't forget to chock the rear
There are four possible ways:
Arrow Jack it up then use axle stands.
Arrow Use ramps
Arrow Use a hydraulic car lift
Arrow Use a mechanics pit.
Hetzer
PostPosted: 11:13 - 22 Aug 2010    Post subject: Reply with quote
Just slide under it ffs. But try not to get the oil all over yourself like what I did (not much room to dodge under a Mondeo). Embarassed Laughing
PostPosted: 11:19 - 22 Aug 2010    Post subject: Reply with quote
^^^Which is difficult as i found out. And no leverage to unscrew the old filter.
Another el-cheapo way is get 2 housebricks...find a very high kerb and use the bricks as a stepped ramp. Perch the wheels onto the kerb and gain alittle bit more scabbling space. Smile
For 30-50 quid get some ramps. Thumbs Up
PostPosted: 11:24 - 22 Aug 2010    Post subject: Reply with quote
Safety first. Thumbs Up
https://www.stedotcom.com/stuff/P2270069.jpg
https://www.stedotcom.com/stuff/P2270072.jpg
PostPosted: 11:37 - 22 Aug 2010    Post subject: Reply with quote
Tut Tut Oh-no you don't, Ste.
Phew that was close
yuri2085
PostPosted: 11:46 - 22 Aug 2010    Post subject: Reply with quote
Phew that was close
I risked it in incognito windows. Those pics are actually work safe!
PostPosted: 11:58 - 22 Aug 2010    Post subject: Reply with quote
Yes, it surprised me too Laughing
Sam_Y_93
PostPosted: 13:03 - 22 Aug 2010    Post subject: Reply with quote
Get a set of axle stands, can get them for around £20-£30 and they will come in handy at other times as well Thumbs Up
PostPosted: 13:12 - 22 Aug 2010    Post subject: Reply with quote
A well-built tower but fail for having the load-bearing wheels outboard of the last 2x2 Smile
0ddball
PostPosted: 13:47 - 22 Aug 2010    Post subject: Reply with quote
A standard Mondeo rides high enough to be able to do it without jacking it up at all.
Stelmer
PostPosted: 14:08 - 22 Aug 2010    Post subject: Reply with quote
Get your mate to unscrew the drain plug so you don't get oil going up your sleeve. Don't forget to take off the oil filler cap when he's undoing the bolt....Twisted Evil
WildGoose
White Van Man
PostPosted: 14:33 - 22 Aug 2010    Post subject: Reply with quote
Safety first indeed. If there is enough room, do it without jacking it, as is possible on my van. Can't be done on my civic without jacking it.
If you have to jack it, dont support it on bricks/slabs, as these can crumble and fail, doesn't mean that they will, but I would never trust them.
Also never crawl under a car that is only supported by a jack, doesn't matter which type. Support it on stands before you do anything, and use common sense as to where to support it i.e. main bodywork members, somewhere that will take the weight.
Shaun
Likes 'em bent
PostPosted: 14:47 - 22 Aug 2010    Post subject: Reply with quote
I disagree with this, it's important to get practise in to ensure longevity.
arry
PostPosted: 15:22 - 22 Aug 2010    Post subject: Reply with quote
Yup, just park one side of the car up on the kerb.
SoND
PostPosted: 15:38 - 22 Aug 2010    Post subject: Reply with quote
Get a ton of fireworks and tie them all to the tow hook. If you used enough it will lift the car high enough for you, can't say you would have much time to waste while working at it so you better get under it quick!
steppen22
PostPosted: 16:26 - 22 Aug 2010    Post subject: Reply with quote
but then the oil wouldnt drain fully???
arry
PostPosted: 16:34 - 22 Aug 2010    Post subject: Reply with quote
Mostly on the contrary - it'll drain better. You'll usually find the drain plug is one one side or the other of the sump; raise the side it isn't on in order to get the drain plug to be the lowest point.
Phoenix
Twisted Firestarter
PostPosted: 18:55 - 22 Aug 2010    Post subject: Reply with quote
Take it to Kwik Fit or Tyre Sales, £25 for an oil and filter, semi synthetic Mobil 1, can't even buy the oil for that price. Cost me the same to get the oil on my 530 changed, all 6.5 litres of it...
Misc
PostPosted: 18:59 - 22 Aug 2010    Post subject: Reply with quote
I did this with a Golf. Didn't even have to get underneath really as i could just about reach the sump bolt.
I also parked the car on the curbed to change the starter motor. I get very paranoid when under a car so a curb for the most part makes me feel a bit better then a jack, or anything mechanical really. Laughing
Robby
Dirty Old Man
PostPosted: 19:26 - 22 Aug 2010    Post subject: Reply with quote
As said, you can probably get under without jacking it up enough to do an oil change. If you have a jack but don't want to get under then you can probably access the sump plug safely by removing one of the front wheels. May make filter access easier too, depending on location.
For draining the oil, nothing works better than a washing up bowl. Whenever I use a proper drain can I end up with oil splashing out of it and going everywhere.
andyscooter
PostPosted: 21:01 - 24 Aug 2010    Post subject: Reply with quote
20 quid bromsgrove motor factors Laughing Laughing
The last post was made 15 years, 308 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.18 Sec - Server Load: 4.74 - MySQL Queries: 13 - Page Size: 132.17 Kb
