CB250 Twofifty oil help
Welshd1k
PostPosted: 12:33 - 23 Aug 2010    Post subject: CB250 Twofifty oil help Reply with quote
What oil should i use? semi synt? 10/40? i out cb250 oil in ebay and thats what i get but is that 100% correct also where the F does the paper filter go?
DrDonnyBrago
PostPosted: 12:42 - 23 Aug 2010    Post subject: Re: CB250 Twofifty oil help Reply with quote
I thought the CB250 uses a wire mesh in the engine rather than a paper oil filter? If so then this needs to be cleaned when you do an oil change.
PostPosted: 13:05 - 23 Aug 2010    Post subject: Reply with quote
The Autodata book I have here lists it as 1.5L of 10W40 SG spec oil.
Would guess that there is a cover on the underside of the engine which holds the oil filter.
Digit
PostPosted: 13:57 - 23 Aug 2010    Post subject: Reply with quote
And when you change the filter don't throw the spring and washer away with it!
The times I've seen that happen. Laughing
Roy.
Happy daze!
jowettdriver
PostPosted: 22:07 - 23 Aug 2010    Post subject: Reply with quote
I use ordinary semi synthetic 10/40 oil from my local motor factors.
My Clymer manual states that the service interval for oil changes is 4000 miles. My 250 is used for a lot of short trips and city commuting so i change it every thousand miles or so. As keith said the correct spec is 1.5 litres of 10W/40 API SG
These bikes don't have a paper filter, just the mesh filter screen in the oil pump housing this is schedualed at every 8000 miles. To get at it you need to remove the right hand engine cover and undo the oil pump housing. If you want more information on how to do it, I can scan the appropriate page out of the manual for you.
Tim.
Bikes: 1980 Honda CX500, 2003 Honda CB250, 1980 Honda CG125
bacon
PostPosted: 16:37 - 24 Aug 2010    Post subject: Re: CB250 Twofifty oil help Reply with quote
like said above it doesnt have a disposable filter, there is a small wire "basket" that needs to be cleaned instead
just stick any old semi synthetic 10w40 motorcycle oil in and it will be fine
The last post was made 16 years, 10 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 0.32 - MySQL Queries: 13 - Page Size: 47.1 Kb
