| Ol |
 Ol World Chat Champion
 Posted: 10:21 - 23 Aug 2010 Post subject: The SHED Thread !! - UPDATE : Finally finished ! |
Well the Mrs decided she wanted a small shed to keep her work stuff in… we found a 14ft x 8ft shed for a reasonable price – so thought that’ll do, and as a bonus it came with free fitting, all that was required was a base – easy!
Where we wanted to put the shed is prone to flooding, after a couple of hours rain there will normally be a puddle a couple of inches deep… so the shed needed to be raised, There’s no way we can afford to build a concrete base, or even build it up and flag stone it – so I initially thought I’ll raise it with breeze blocks.. they’re big, cheap and relatively easy to move about on my own.
I Spoke to the place we’d bought the shed from and explained what I was planning to do, and to find out which way the joists ran under the shed, how far apart they are etc, so I know where to position my blocks… the bloke on the phone was very indecisive, and not overly helpful, but I he told me that the joists are 1ft apart and run lengthways, so armed with (what I thought was) the correct info, off to B&Q I went, plastic friend in hand.
Then came the job of putting all the breeze blocks in place, digging them down and levelling them, this was actually a bit harder than I expected it to be.. Specially when being watched by “The Boss” !!
https://i1016.photobucket.com/albums/af282/Oliver7978/01082010503.jpg
https://i1016.photobucket.com/albums/af282/Oliver7978/07082010509.jpg
We phoned to see when the shed would be delivered – when on the phone to them, only then did they think it wise to tell me the base comes in 3x equal sections sections, making my previous hard work completely void, I was not amused. The chap on the phone explained that the sections are 14ftx8ft divided equally into 3 (i.e 56”x96” each). Fine I thought, will just make a metal frame (well, dad will make a metal frame), that will sit on top of my blocks, that will support every side of all 3 sections.. sorted.
https://i1016.photobucket.com/albums/af282/Oliver7978/12082010557.jpg
https://i1016.photobucket.com/albums/af282/Oliver7978/16082010583.jpg
So – D-Day comes, the blokes arrive to start putting up the shed, I’m happy my base is exactly as it needs to be, as they’ve told me it should be… what could possibly go wrong??
Well, turns out the joists are actually 18" apart and not 1ft as i was origionally told (not that it matters now with the metal frame anyway) and the base isn’t actually 14ft x 8ft, but 13ft8” x 7ft8” – so the base doesn’t actually sit on all the edges of my frame, and is too small:
https://i1016.photobucket.com/albums/af282/Oliver7978/21082010587.jpg
https://i1016.photobucket.com/albums/af282/Oliver7978/21082010588.jpg
So after a quick phone call to my dad, some magical brackets turned up to sort out all my problems, well, the shed one’s anyway. The plan was to bolt the new brackets onto the inside of the frame to support the edges of the base:
https://i1016.photobucket.com/albums/af282/Oliver7978/21082010591.jpg
There were a few little problems, I’d hammered some sections of 4ft long angle into the ground and bolted them to the metal frame, just to help keep it in one place, so some of these needed attacking with the grinder:
https://i1016.photobucket.com/albums/af282/Oliver7978/21082010592.jpg
https://i1016.photobucket.com/albums/af282/Oliver7978/21082010593.jpg
Then once all the new brackets were on, we put the visqueen / damp proof sheet stuff down, plonked the floor on top, then started putting the sides up.. these went up rather quickly and with little fuss:
https://i1016.photobucket.com/albums/af282/Oliver7978/21082010594.jpg
https://i1016.photobucket.com/albums/af282/Oliver7978/21082010597.jpg
The only problem really was the screws I was using were, in places, a touch too long – but never mind, nothing the grinder cant sort out!
https://i1016.photobucket.com/albums/af282/Oliver7978/21082010595.jpg
Incidentally – I’ve had the same screwdriver bit + Extension for years and years, and even though I’ve got handfuls of new Philips / dewalt etc screwdriver bits, I still keep using the old one that’s covered in rust – because it works and seems to fit most screws nicely, and I like it !
https://i1016.photobucket.com/albums/af282/Oliver7978/21082010606.jpg
Then the roof went on, again – this was relatively easy, 2x people push one half up from one side, whilst someone on the inside guides it into place… then repeat on the other side, sorted.
Then to felt the roof, I agreed to let my mate climb onto the roof to secure the felt – as I’m such a kind chap! Then i tidied up the corners a bit, need to go over most of the roof with some proper roof tacs as I only used a staple gun!!
https://i1016.photobucket.com/albums/af282/Oliver7978/21082010600.jpg
https://i1016.photobucket.com/albums/af282/Oliver7978/21082010604.jpg
Finally the side bits went on to cover the end of the roof, put a couple of locks on the doors, fitted the glass and pretty much decided there and then that I never want to build another shed as long as I live…
The boss gave it a final check over, and decided she wanted a Chinese..
https://i1016.photobucket.com/albums/af282/Oliver7978/21082010605.jpg
So here it is, my shed, want to get some trellis or somthing to cover the breeze blocks and stop anything moving into under the shed!!
https://i1016.photobucket.com/albums/af282/Oliver7978/21082010609.jpg
Anyone else got some photo’s of their shed? ____________________ Previous: Cub50, NRG50, TS50, YB100, CB125, NSR125, ZZR600, CBF1000, SV650s, ZX6R B1H, XT250, Mito Powered Crosser, WRF450, , FZ600, VN800, GSXR600 - Currently CB1000R
| Bat |
 Bat Nova Slayer
 Posted: 10:46 - 23 Aug 2010 Post subject: |
Good effort. Hardly a small shed. Bet the Mrs has got plans for all the available space already though  |
| truslack |
 truslack World Chat Champion
| N cee thirty |
 N cee thirty Banned
| pinkyfloyd |
 pinkyfloyd Super Spammer
| _Will_ |
 _Will_ World Chat Champion
 Posted: 14:37 - 23 Aug 2010 Post subject: |
| Whosthedaddy |
 Whosthedaddy Super Spammer
| JakeyR |
 JakeyR World Chat Champion
 Posted: 16:24 - 23 Aug 2010 Post subject: |
| ZRX61 |
 ZRX61 Victor Meldrew
| MinhDinh |
 MinhDinh World Chat Champion
| colin1 |
 colin1 Captain Safety
| Paxovasa |
 Paxovasa World Chat Champion
 Posted: 20:52 - 23 Aug 2010 Post subject: |
A man needs a shed, so he can turn a big piece of wood into a small piece of wood  ____________________ Suzuki GSF600 K3 (in the fastest colour, black). |
| Howling TerrorOutOfOffice |
 Howling TerrorOutOfOffice Super Spammer
| ZRX61 |
 Posted: 21:10 - 23 Aug 2010 Post subject: |
| pinkyfloyd |
| imanupstart |
 imanupstart Traffic Copper
 Posted: 22:20 - 23 Aug 2010 Post subject: |
I was expecting the SHRED thread to be full of megadeth and slayer, damn my inability to read  |
| carlosthejack... |
 carlosthejack... World Chat Champion
| Flip |
 Flip Super Spammer
| Marmalade |
 Marmalade World Chat Champion
| Marmalade |
| Flip |
 Flip Super Spammer
| andyscooter |
 andyscooter World Chat Champion
The last post was made 16 years, 29 days ago. Instead of replying here, would creating a new thread be more useful? |
