GPZ500s... again....
dextersaurus
PostPosted: 13:04 - 26 Aug 2010    Post subject: GPZ500s... again.... Reply with quote
So i got the bike running again today, and it started getting pretty hot... near enough overheating.
So once it had cooled down and the fan had turned off and the like, i opened up the rad cap, and noticed the coolant was a rusty colour...
This mean that in the past, someone has run straight water through it, and the rad has rusted internally?
If so... a replacement radiator?
The coolant in the reservoir is pink, and it runs pink from the line to the carbs.
What should i do next? everything else is fine.
Dunc
Billing
PostPosted: 13:39 - 26 Aug 2010    Post subject: Reply with quote
drain the lot, flush through with a hose until the water turns clear, refill with fresh coolant (50/50 antifreeze i think)
PostPosted: 14:06 - 26 Aug 2010    Post subject: Reply with quote
As above. Take the rad off (with its pipes) and connect up the out hose to a hose pipe (the adjustable sprayer nozzles are tapered so easy to push into a pipe and then jubilee clip in place) and turn the tap on to flush it through.
You can get stuff to add to the coolant to break down build ups in the radiator.
Casper
PostPosted: 14:44 - 26 Aug 2010    Post subject: Reply with quote
You going to use this for college transport? Not long now so get yer finger out. Oh, i want a dark lid in XL, what you got? or does that bike shop up your way have any in cheap?
dextersaurus
PostPosted: 22:42 - 26 Aug 2010    Post subject: Reply with quote
Ahh i'll give that a go tomorrow, see what i can do.
Need to get more antifreeze then, not got any to hand.
Rolfe, yeah, hopefully for 2nd term...
I aint got any XL helmets, though eclipse should have some cheap-ish helmets. go have a look - and come pop in and see mah bike Thumbs Up
Dunc
dextersaurus
PostPosted: 22:50 - 26 Aug 2010    Post subject: Reply with quote
Any idea of a name?
Dunc
Casper
PostPosted: 23:12 - 26 Aug 2010    Post subject: Reply with quote
Dunc
All the cheap lids will be WHITE Lol. Pm me yer mobi number ill phone when next in the area and laugh at your mechanical skills.
Should have bought that other one.
dextersaurus
PostPosted: 00:03 - 27 Aug 2010    Post subject: Reply with quote
Done Thumbs Up
ahh i would have if i had the money - could have used the parts or made a decent bike out of it.
Dunc
Casper
PostPosted: 01:04 - 27 Aug 2010    Post subject: Reply with quote
Mr Dunkable wrote:
Done Thumbs Up
Dunc
Got it. Will you be offended if i chat up yer mum or sister while i am there? Very Happy
Try holds rad weld gold for the rust in yer rad. i will fix the odd hole and any rust on the inside. Thumbs Up
Later
Ingah
PostPosted: 01:05 - 27 Aug 2010    Post subject: Reply with quote
Mr Dunkable wrote:
Any idea of a name?
Dunc
Something like this?
https://www.halfords.com/webapp/wcs/stores/servlet/product_storeId_10001_catalogId_10151_productId_166188_langId_-1_categoryId_165750#dtab
-- Ingah
calyx
PostPosted: 02:10 - 27 Aug 2010    Post subject: Reply with quote
https://www.youtube.com/watch?v=TlNJDy_bZDE
Boris - London
The last post was made 16 years, 38 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.49 - MySQL Queries: 13 - Page Size: 70.9 Kb
