Very odd low compression issue
mr-inteligent
PostPosted: 16:55 - 27 Aug 2010    Post subject: Very odd low compression issue Reply with quote
My bandit 400 was running sweet as a nut and then the starter motor stopped working.
Since changing this small part the bike has run like shit and will not idle. So either its a very odd coincidence that the bike now runs like shit or its something I have done when I replaced the starter motor.
its important to stress the bike literally went from running very well to running like shit in the space of 1 hours time while I put on the new starer motor.
The mechanic has just told me the bike has bad compression on 3 cylinders. He wants to start looking inside the engine for possible causes but before I give the go ahead I want to ask here if there is anything I could of missed?
To replace the SM I removed the carbs and also the cam chain adjustment, could this of caused the issue?
mr-inteligent
PostPosted: 17:09 - 27 Aug 2010    Post subject: Reply with quote
I agree mate but I have checked and re checked everything.
Why would the bike suddenly lose compression just from me changing the SM?
Should I of put some sort of sealant around the cam chain adjustment part when replacing?
rob yarrr wrote:
maybe the cam chain needs adjusting properly
i wouldn't take it to the mechanics,they will charge you a bomb for just looking at it,never mind fixing it
A poorly adjusted chain chain wouldn't make it run shit it would just be noisy. It may have skipped a tooth but I doubt it, also that wouldn't cause low compression on 3 cylinders. Hows does the mechanic know it has LC on 3 cyclinders?
People pay mechanics because usually they know what they are talking about.
mr-inteligent
PostPosted: 17:24 - 27 Aug 2010    Post subject: Reply with quote
He has checked the valves and says they are ok, he has done a compression check and says they are low on 3.
lowest being 75 but this is a 20year old bike.
When I say "running shit" I mean not idling and slowly comeing down from 4k revs making a whirling noise.
loply
PostPosted: 20:08 - 27 Aug 2010    Post subject: Reply with quote
The starter motor isn't somehow staying 'connected' is it?
So the engine is spinning the starter motor over?
Might be completely impossible as I only know how the starter engager works on a Mille, no idea how it is on other bikes.
Yamaha SZR660 Caution to the wind, the throttle pinned!
mr-inteligent
PostPosted: 20:35 - 27 Aug 2010    Post subject: Reply with quote
I havent thought of that.. and its worth checking tomorrow when I get the bike back.. I cant let the mechanic go into the engine as it will cost more than the bike.
The last post was made 16 years, 54 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.10 Sec - Server Load: 1.77 - MySQL Queries: 13 - Page Size: 53.03 Kb
