Where do I mount my camera
odemode
PostPosted: 13:33 - 01 Sep 2010    Post subject: Where do I mount my camera Reply with quote
I've got one of those MD80 cameras on order (£20) but I don't know where I should mount it when it comes.
Had some advice regarding putting on the mudguard using blu-tac and ducking tape, but I'd like it to fit neat. I have a CBR RR-5 so I was thinking of sticking it under the fairing just down from the lights but I'd have to stick it up so gravity would play some part in moving it. I've heard that the 3M Dual Lock stuff is good but is it good enough to stop the camera falling off under vibration pressure?
Any ideas
The Artist
PostPosted: 13:35 - 01 Sep 2010    Post subject: Reply with quote
Your Helmet
odemode
PostPosted: 13:46 - 01 Sep 2010    Post subject: Reply with quote
The Artist wrote:
Your Helmet
How do I mount it though
Aka Matt
PostPosted: 13:47 - 01 Sep 2010    Post subject: Reply with quote
I found inside the helmet was best. If you have a soldering iron and some lego or similar, you could knock up a bracket for it to mount to in no time at all. I'll attach a photo shortly of what I done.
https://sphotos.ak.fbcdn.net/hphotos-ak-ash2/hs152.ash2/40929_476145710800_529440800_7070228_3435557_n.jpg
https://sphotos.ak.fbcdn.net/hphotos-ak-snc4/hs385.snc4/44831_476145935800_529440800_7070229_3685003_n.jpg
(Mouted it upside down as the pinlock visor sits right across the lens)
Current bike(s): 2016 Tuono 1100 Factory, 1998 Hornet 600
Previous: 1998 YZF600R Thundercat, 2001 Bandit 600, 2002 GSX-R 600 K2, 2011 Tuono R, 2013 Z1000SX
PostPosted: 13:48 - 01 Sep 2010    Post subject: Reply with quote
Well, if I was going to mount a camera, I guess I'd mount it from behind...
PostPosted: 14:21 - 01 Sep 2010    Post subject: Reply with quote
To hell with brackets gaffer tape is the best it si the most secure way of mounting them I have found
I mounted mine on the TDM here.
https://img.photobucket.com/albums/v295/chris-red/2002-TDM900-02TDM900_35PS01big_tcm7.jpg
Here is an example of the type of shot you get
https://www.youtube.com/watch?v=mvIC71MJkoo
And this from gaffer tape to your helmet.
https://www.youtube.com/watch?v=XQKlGF_YANM
odemode
PostPosted: 15:41 - 01 Sep 2010    Post subject: Reply with quote
So you can sit the camera anyway you want and the picture will be upright all times?
PostPosted: 15:58 - 01 Sep 2010    Post subject: Reply with quote
No like all cameras you have to point it at want you want to see.
odemode
PostPosted: 17:16 - 01 Sep 2010    Post subject: Reply with quote
I mean can you lay the camera horizontal does this mean it'll stick the footage on the side or will it just be widescreen.
A bit like a camera works. If you spin it the picture become widescreen, ya get me?
Aka Matt
PostPosted: 18:29 - 01 Sep 2010    Post subject: Reply with quote
This isn't the case with these cameras but you can simply rotate the videos using windows movie maker if you do position it upside down or horizontally.
Bloke
PostPosted: 19:10 - 01 Sep 2010    Post subject: Reply with quote
Got one of these coming too (£12.99 free p+p uk seller) I'm going to just try and shove it in my helmet in front of my nose if I can. Failing that i'll use black gaffa tape and stick it to the chin bar.
2008 VFR800 VTEC
odemode
PostPosted: 20:58 - 01 Sep 2010    Post subject: Reply with quote
Anyone used them in a lid thats tinted?? Or would a clear visor be advised while fliming
Skudd
PostPosted: 08:27 - 02 Sep 2010    Post subject: Reply with quote
have you a link?
MaybeGuy
PostPosted: 08:29 - 02 Sep 2010    Post subject: Reply with quote
i replaced my wingmirror with one. Ill post a pic later
rob_scott92
PostPosted: 11:51 - 02 Sep 2010    Post subject: Reply with quote
have you a link?
Theres loads on ebay! Loads more even since the last time i checked Shocked
https://cgi.ebay.co.uk/New-Mini-DV-Pocket-Video-Camera-DVR-Camcorder-Cam-MD80-/160468436961?pt=UK_AudioTVElectronics_Video_Camcorders&hash=item255caa07e1
Could you let us know if the camera is good when you get it? i've heard a lot of mixed things regarding them actually working lol Laughing
Thats a really good idea of where to put the camera too, this kit i've linked comes with velcro so i think that might hold it in place without having to manufacture a bracket for it Very Happy
Rob Thumbs Up
First bike: 1982 Suzuki Gs 125 'The beast MK1' Wink > 1988 Honda Cb 350's' FOR SPORT! (Good ol' oil burner!) > 2001 Suzuki Sv 650 's' Made it out of the 80's! > 1997 Honda Cbr 600f :p
rob_scott92
PostPosted: 12:26 - 02 Sep 2010    Post subject: Reply with quote
Actually, scratch that.... I've just gone and bought one Rolling Eyes
Well its only £13 innit Laughing
Deckx
PostPosted: 13:36 - 02 Sep 2010    Post subject: Reply with quote
Don't bother using the mounting bracket and cross tie it on one of your mirror stalks using cable ties with a some dense foam backing.
Putting it in your helmet will only give you ground footage unless you keep sitting up straight Confused
defblade
PostPosted: 14:36 - 02 Sep 2010    Post subject: Reply with quote
I made a little tube to slip mine down into, with a cut-out on the back so that the teeth on clip went into the hole and held the camera in.
Then mounted that on a strip of perforated metal bent to fit around my indicator stalk and hold the whole lot upright. So your picture is straight ahead and lowish, banks with the bike.
Would like to fit it to my helmet sometime but never got around to it.
MaybeGuy
PostPosted: 21:24 - 02 Sep 2010    Post subject: Reply with quote
https://img267.imageshack.us/img267/4163/02092010025.jpg
its solid as fuck and took about 20 mins to make at work.
if you want to make your own, the thread on the bottom of cameras is 1/4 UNC
Bloke
PostPosted: 21:45 - 03 Sep 2010    Post subject: Reply with quote
Mine has just arrived. Pretty good thus far impressed with the picture going to spend tomorrow playing with mounting it and filming on my bike.
£12.99 well spent I think.
Link for those of you who wanted it: https://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&item=180545809595
Took 2 days to arrive after they posted it.
Does not come with an mini-SD card so I shoved one I had hanging around in it.
Oh and the instructions are pure comedy Smile
"Gigantic data cannot be transmitted synchronously"
"Use slim pole to press button for the reset of purposes"
"Please pay attention to protect environment, not to throw the product optionally"
It's also helped by mentioning orange, yellow, red and green lights... I have only 3 lights. 2 are blue 1 is red. Very Happy
2008 VFR800 VTEC
rob_scott92
PostPosted: 23:23 - 07 Sep 2010    Post subject: Reply with quote
Mine arrived today too! Very Happy The only problems being;
1.Bike isn't working
2. I have a spare SD card but not a MICRO one Rolling Eyes
3. Theres no instructions with mine! Thinking
Looks like i'm gonna have to get a card off ebay, anyone know a particular type i should avoid etc. (Other than non micro type obviously lol Laughing )
odemode
PostPosted: 08:31 - 08 Sep 2010    Post subject: Reply with quote
Instructions bud, are on the disk as a word document. Camera will not work without a memory card.
To record press the top button once when turned on, red light will flash. To pause press again, red light will start to flash a bit faster then to stop press top button and hold or just switch off.
Mode button is for operation with PC/Lappy, and I think to enable the sound activation you turn power on then press mode quickly.
Picture isn't brilliant but enough for what you pay.
rob_scott92
PostPosted: 12:51 - 08 Sep 2010    Post subject: Reply with quote
Embarassed There was me looking for an actual paper copy lol!
Any ideas on memory card? I've seen a 4gb one on amazon, its only class 2 though. Does it HAVE to be class 6? If not, would class 2 be good enough?
Thanks Thumbs Up
dragstaar
PostPosted: 19:25 - 08 Sep 2010    Post subject: Reply with quote
Heyyy!! thats my exact commute! past tower bridge, round the bend, except i carry on towards mile end station! whitechapel road is manic. The mopeds are nuts and cut up everyone. Had my first off on whitechapel
Bloke
PostPosted: 19:55 - 08 Sep 2010    Post subject: Reply with quote
Thanks Thumbs Up
I have a 2gb one no idea what class but seems to work okay. Providing it's cheap i'd try the class 2.
2008 VFR800 VTEC
The last post was made 16 years, 69 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.06 Sec - Server Load: 0.58 - MySQL Queries: 13 - Page Size: 138.57 Kb
