| Stowelly |
 Stowelly Traffic Copper
| mistergixer |
 mistergixer World Chat Champion
 Posted: 20:19 - 01 Sep 2010 Post subject: |
Brakes.
They're fucking shit on the SRADs.
 ____________________ Space Monkey #7
Mistergixer's videos on YouTube |
| Blau Zedong |
 Blau Zedong Banned
| Stowelly |
| MaybeGuy |
 MaybeGuy Super Spammer
 Posted: 21:19 - 01 Sep 2010 Post subject: |
headlight mounts.
all screws should be present, and all lugs and rubber grommets.
if even one is missing things WILL go wrong, involving your ram air tubes popping out every 5 seconds and your headlight wobbling around like a cerebral palsy jogger that is fat and on ketamine, as well as snapping your spider frame.
engines are pretty good on them. if it rattles, walk away. you sound like a ''mechanics'' wet dream. ____________________ Blue_SV650S wrote: it was a sh1te wheelie, but it proves that he can get it up in 3rd and can do angles. In summery, mattsprattuk is a gobby little sh1tebag, dopehead tw4t, but sadly for all of us, he probably isn't THAT full of sh1te!!
| Blau Zedong |
 Blau Zedong Banned
| D O G |
 D O G World Chat Champion
 Posted: 23:02 - 01 Sep 2010 Post subject: |
| mistergixer wrote: | Brakes.
Only the rear in my experience - the pins which hold the pads in place corrode into the caliper body, and cannot be removed without (at a minimum) splitting the caliper. Chances are that this has happened if the pads are really thin and have never been replaced - ask the owner if this has been done.
Never had any probs with the front brakes at all, including trackdays - not that I'm that fast tho.
CCT does go, but is an easy fix - around £50 for a manual CCT, but that does tend to need regular adjustment, which is not that difficult. Easy to spot if the CCT is gone - the timing chain rattles/ticks on the right hand side of the engine, which will vary with revs, blip it on idle and listen for any change in the rattle noise.
Biggest problem IMO is chavvy, shit mods like aftermarket 'shotgun light' undertrays and small, shitty indicators. Can lead to poor wiring and associated issues - I should know, I did it to mine. Yellow screens have also been fitted to some poor bikes over the years, which is an appalling state of affairs.
Oh, the fasteners are generally made of cheese, and fork bottoms corrode on the front at the top - just below the dust seals.
| mattsprattuk wrote: | headlight mounts.
all screws should be present, and all lugs and rubber grommets. |
Better check I still have mine..... |
| evoboy |
 evoboy World Chat Champion
| MaybeGuy |
 Posted: 07:48 - 02 Sep 2010 Post subject: |
| evoboy wrote: | | mistergixer wrote: | Brakes.
Tokico 6pots in general, are prone to seizing up.
So if theres a load of travel at the lever and the brakes are very grabby, itll want a full caliper overhaul, including seals most likely... |
750 has 6 pots. 6 only has 4, and theyre not anywhere near as bad as people say, theyre just usually un maintained, and getting on 13 years old or so on original seals. ____________________ Blue_SV650S wrote: it was a sh1te wheelie, but it proves that he can get it up in 3rd and can do angles. In summery, mattsprattuk is a gobby little sh1tebag, dopehead tw4t, but sadly for all of us, he probably isn't THAT full of sh1te!!
| T1z3R |
 T1z3R World Chat Champion
| TUG |
 TUG World Chat Champion
| Stowelly |
 Posted: 21:57 - 02 Sep 2010 Post subject: |
well i got it! everything mentioned seems fine, only noticable problems are the battery is fucked and the choke seems to stick, but they are all easily rectifiable! worked out at just over a grand, and after a few hundred quid for service and other little bits it should be perfect!  |
| Davie_G71 |
 Davie_G71 World Chat Champion
| Mellow Matt |
 Mellow Matt Scooby Slapper
 Posted: 15:29 - 03 Sep 2010 Post subject: |
Fun bike Beware it jumping out of gear like mine did though, total PITA ____________________ 1999 GSX-R 600, 1999 TL1000R |
| Davie_G71 |
| Davie_G71 |
| D O G |
| Tristan. |
 Tristan. World Chat Champion
| Mellow Matt |
| Redoko |
 Redoko World Chat Champion
 Posted: 12:48 - 04 Sep 2010 Post subject: |
Not bad at all, enjoy her.
Welcome to the SRAD group.
https://i1003.photobucket.com/albums/af159/Redoko1992/Photo0137.jpg ____________________ "Let's face it, this is not the worst thing you've caught me doing."
Sudika Sportsman SK50QT > Gilera DNA50 > Honda CBR125 RW7 > Kawasaki Zephyr750 > Suzuki GSXR600 > Honda Hornet CB600F '51 |
| Stowelly |
| D O G |
 Posted: 11:39 - 17 Sep 2010 Post subject: |
| Stowelly wrote: |
dont know why thats unreasonable?
30 quid for some irridium plugs
30-40 for oil and filter, plus the tool i need to change the oil filter
tenner for some coolant
however much an air filter is?
and to clean / balance the carb, check the valve shims, and buy some new ones if necessary a garage is gonna charge at least 200 quid really arent they? |
Iridium plugs are a waste of money.
The only tool I've ever used to change a filter is my hand, and sometimes a piece of sandpaper to get a good grip.
Don't see much point in changing the coolant, unless it is overheating. Personal pref tho.
Carbs won't need cleaning, balancing is a fairly quick job, but again, I would only have this done if it was running poorly.
As for the clearances, that isn't a huge job, again I'd probably sack it off unless it sounded like a bag of bolts and had high miles. What is the milage?
You spend your money how you please - I really don't care, but I'm just pointing out some potential savings for petrol money = riding fun. |
| Stowelly |
 Posted: 11:53 - 17 Sep 2010 Post subject: |
| D O G wrote: | | Stowelly wrote: |
nah i appreciate your input, there is some slight niggly running, that was suggested to me a carb balance was sorted...... is it really not worth checking the clearances? heard that it can sieze the engine up if their not right.... mileage is 19k.
fair enough can skip the irridium plugs, figured they would be worthwhile as they made a noticable difference on my NSR125
figured the filter would need a tool, as they sell them, didnt realise it was easy enough to sort by hand.
also figured coolant needed regular changing, dont think it over heats, i mean after long running through slow traffic it does get to 100 degrees, but ive been told this is normal for gixxers.
im all for extra petrol money! would rather buy a new set of tyres, and a couple of bits of fairing to be fair if i didnt need to! |
| D O G |
| DrDonnyBrago |
 DrDonnyBrago World Chat Champion
The last post was made 15 years, 109 days ago. Instead of replying here, would creating a new thread be more useful? |
