Need some advice so lost :(
Dragon_Phantom
PostPosted: 12:30 - 02 Sep 2010    Post subject: Need some advice so lost :( Reply with quote
Hi guys but new here and in a bit of a bind not too sure what to do.
So my GSXR 400 Has been standing for a while after some nut job pulled out in front of me a few years back then drove off !
Decided to get it all fixed up got insurance sent it to the shop to get it all sorted.
Sunk a little over 750 in to it to fix it plus insurance tax etc ( i know possibly stupid but just wanted her back up and running)
Full M.O.T, Service the stinger was the labour (8hours @ 40 quid :’()because the carbs had to be completely stripped and rebuilt plus parts etc and needed a new casing and bought new wing mirrors.
So after a month in the shop me going back and forth for aaages all the tears etc and the happiness of the few hours I got riding there’s still problems!!!
Some electrical fault that they can’t figure out apparently it’s likely to be the cdi unit and not all cylinders fire up at times.
It still rides but the choke has to be on and the idle is up ridiculously high! Not safe riding scariest thing ever driving it back from the shop
I had to stop there didn’t think it was worth sinking any more money in to it.
Now I am stumped what to do! Should I sell after sticking so much in to it do I plough on?
I do also have an aprillia sr50 moped in my back garden so im thinking sell up both and get another bike........ any ideas?
Sad
flumpy7
PostPosted: 12:48 - 02 Sep 2010    Post subject: Reply with quote
Not much of a mechanic myself, but for what its worth youre not gonna sell it for much if its that eratic, need to get it sorted first.
2012 Sinnis apache
evoboy
PostPosted: 13:03 - 02 Sep 2010    Post subject: Reply with quote
They cant figure it out....yet its likely to be the cdi unit?
What work did they actually do in 8hours?! I reckon i could completely strip a bike down to the frame in that time!
Im not an employed mechanic, but i would NEVER let a bike i had been working on out of my garage in an unrideable state.
APT Motorcycles
Casper
PostPosted: 14:21 - 02 Sep 2010    Post subject: Reply with quote
Sounds like you got stung mate. Get a s/hand cdi to try.
Digit
PostPosted: 15:44 - 02 Sep 2010    Post subject: Reply with quote
If pulling the choke sorts it I'd say it was running weak on some cylinders.
Air leak, useless garage?
Roy.
Happy daze!
evoboy
PostPosted: 16:02 - 02 Sep 2010    Post subject: Reply with quote
Id go along the lines of the 'rebuilt' carbs.
A torn diaphram could cause issues, incorrectly set pilot screws, torn intake manifolds?
This kinda thing makes my blood boil.
APT Motorcycles
Digit
PostPosted: 16:21 - 02 Sep 2010    Post subject: Reply with quote
I'd agree, I'd also suggest that you buy a set of gauges and balance the carbs, even if they are are correct the guages will save you money, and garage cock-ups, in the future.
Roy.
Happy daze!
Robby
Dirty Old Man
PostPosted: 16:51 - 02 Sep 2010    Post subject: Reply with quote
Before you go tearing into the carbs, has it had a new battery? If it has been standing for a few years then the battery could be knackered (will start the bike and seem ok, but has very little capacity left) which can cause all manner of running problems.
After that I would suspect a fuelling problem, a torn diaphragm or inlet rubber, mixture screws set wrong, water in the carbs.
Dragon_Phantom
PostPosted: 12:45 - 04 Sep 2010    Post subject: Reply with quote
I did think at first they were messing m about but they said they had to strip the cards and completly rebuild them im no mechanic but that seemed like a big job to me. 8 hours work 40 quid an hour raher miffed right now. Any body suggest anyone in london that could help?
Robby yea with the sservice battery was put in.
Arbo
PostPosted: 14:53 - 04 Sep 2010    Post subject: Reply with quote
If you can get it to Stevenage I will help?
Arbo
evoboy
PostPosted: 23:29 - 04 Sep 2010    Post subject: Reply with quote
Id take it back to them and tell them it doesnt run right, even after a 'service' by them.
It doesnt take an hour to strip and rebuild a bank of 4 carbs...
Im guessing this isnt a main dealership?
APT Motorcycles
ZRX61
Victor Meldrew
PostPosted: 00:24 - 05 Sep 2010    Post subject: Reply with quote
Problem appears to be the useless twat that fucked with the carbs doesn't know his ass from a hole in the ground.
Dragon_Phantom
PostPosted: 20:18 - 05 Sep 2010    Post subject: ITS GOT WORSE Reply with quote
OMG I think its just not meant to be!
MORE bad news
So i took it out for a bit of a ride it broke down had to be towed back home Sad
ON TOP OF THAT The left fork seal must have gone cos its leaking!
So for some reason the ignition fuse keeps blowing and it seems like it something to do with the indicator/ indicator relay its really weird im baffeled!
I did notice that while riding when i switched on the lights all my dials would go nuts! So now i just need to find the electrical fault but no idea how to start!
Arbo i may have to take you up on that now that it wont even start ill get even less for it if i sell!
ZRX61 yea your probably right and it seems they must of rewired it up wrong now that this has happend! i dont get why the indicators would have any connection to the ignition wiring.
iooi
PostPosted: 21:22 - 05 Sep 2010    Post subject: Re: ITS GOT WORSE Reply with quote
Just about everything is wired through the ignition.... Other wise it would work without the ignition turned on.... Embarassed
Could be a poor earth. But without knowing exactly what was done that made the fuse blow its very hard.
woll
PostPosted: 21:26 - 05 Sep 2010    Post subject: Reply with quote
If the dash is playing silly buggers when the main lights are turned on it could be that the battery is knakered, and it's not got enough power from the charging system to work the lights, dash and try to charge the battery. O just thought maybe reg/rec is knakered and overloading the ignition circuit ergo blowing the fuse.
radical
PostPosted: 21:35 - 05 Sep 2010    Post subject: Reply with quote
Op, to check for leakage in the wiring loom and reg/rec, bottom cnils there is a simple test. first turn the ignition OFF and remove the keys,then disconnect the positive battery lead from the battery, get an indicator lamp and holder or similar and connect one wire to the postive battery lead and the second lead to the postive battery terminal. if the lamp lights then you have a leakage, disconnect the re/reg unit and if the light goes out then you have a faulty reg/rec. If the light stays on then its a process of elimination until the lamp goes out, then you have found the leak/fault.
pepperami
PostPosted: 21:41 - 05 Sep 2010    Post subject: Reply with quote
You say your bike was standing for a long time .... where was it standing ?... in a garage or outside?
if it has been standing where it can get damp and has been there for a long time, some electrical connections made be corroded and that may be making the problem worse.
Dragon_Phantom
PostPosted: 21:42 - 05 Sep 2010    Post subject: Re: ITS GOT WORSE Reply with quote
FAIL on my part see i know nothing about electrics ha!
Thanks radical im gonna try it out when i get back from work tomorow !
Dragon_Phantom
PostPosted: 21:44 - 05 Sep 2010    Post subject: Reply with quote
Yea has been standing for a while Sad was covered up but unfortunately i have no garage Sad
The last post was made 16 years, 45 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.10 Sec - Server Load: 0.82 - MySQL Queries: 13 - Page Size: 101.31 Kb
