| Ol |
 Ol World Chat Champion
 Posted: 08:16 - 06 Sep 2010 Post subject: SV Stalled then instant flat battery?? |
My problem:
On saturday i went to pump up my tyres using a 12v pump connected to a fag lighter under my seat, went to start the bike first but the battery was flat as a fart. so put the battery on charge and left it overnight, yesterday i went out for a ride, all seemed ok.. did about 60 miles then stopped off for a coffee and then set off for a run down to squires, i went to go through a tunnel and remembered i'd turned my lights off on sat, so flicked them back on. About 2 miles later the bike cut out at some traffic lights, and when i went to thumb the starter there was nothing, very feint lights on the dash and not enough power to turn the bike over.
When the recovery truck arrived, we jumped the bike into life and put a meter across the battery, started off at 11.7 (ish) volts, and slowly crept up to 12.5 (ish) when revving the bike. my instant thought was that it's the Reg Rec that's gone?? not sure how accurate this is?? when charged the battery seems to hold it's charge ok, and yesterday started the bike 6 or so times before giving up, so i'm pretty sure the battery is ok, but just not getting charged.
does the reg rec sound like the source of the problem??
if so, am i right in thinking i can put pretty much any regulater on the bike, as long as it's got 5 wires (3x input from stator + 2x to battery) as there's no way i can afford £60 for a new one ??
Many thanks...
Ol  ____________________ Previous: Cub50, NRG50, TS50, YB100, CB125, NSR125, ZZR600, CBF1000, SV650s, ZX6R B1H, XT250, Mito Powered Crosser, WRF450, , FZ600, VN800, GSXR600 - Currently CB1000R |
| MarJay |
 MarJay But it's British!
 Posted: 08:52 - 06 Sep 2010 Post subject: Re: SV Stalled then instant flat battery?? |
| Ol wrote: | My problem:
Many thanks...
Ol  |
If it was the Reg/Rec then I'd expect the voltage to spike when revving the bike. It should spike much higher than 12v. It sounds to me like your alternator is on the way out... However, I'd start with the cheap stuff first and replace the battery in case that is knackered. Charge it up and see if you get 14+ volts across the terminals. If you get less than that then its probably shagged. ____________________ British beauty: Triumph Street Triple R; Loony stroker: KR1S; Track fun: GSXR750 L1; Commuter Missile: GSX-S1000F; Cheap project: CBR900RR FireBlade
Remember kids, bikes aren't like lego. You can't easily take a part from one bike and then fit it to another. |
| Serendipity |
 Serendipity World Chat Champion
 Posted: 09:17 - 06 Sep 2010 Post subject: |
Exactly the same symptoms on my Blade turned out to be failed insulation on the stator.
I'd already fitted a new battery and Fleabayed a replacement genuine reg/rec, but it was only once I replaced the stator that the charging went back to normal.
Mine could just about maintain the battery if I didn't use the lights, but long journeys at night were out of the question. Much better now. ____________________ 2007 CBF1000 & 2016 CBF1000F - Commuter heaven | 1994 CBR600FR - Awaiting defibrillation |
| Kickstart |
 Kickstart The Oracle
 Posted: 10:16 - 06 Sep 2010 Post subject: |
Battery might not be OK now having run that flat. Overcharging a battery can cook them (but no idea what charger you used to know is that is likely).
Regulator / rectifier units often fail totally, and you will get no charge from them at all (or possibly if the regulator side fails you will get a silly high voltage).
We did have a similar problem with Charlottes GPZ500 years ago which was caused by a magnet breaking off from the flywheel and cutting one of the wires on the stator. I would assume you have 3 wires from the stator. With a multimeter check the resistance between each possible combination of a pair of those 3 wires. If one is quite different then I expect that to be your issue.
| beast rider |
 beast rider Could Be A Chat Bot
| L4Isoside |
 L4Isoside World Chat Champion
| Blue_SV650S |
 Blue_SV650S World Chat Champion
 Posted: 18:45 - 06 Sep 2010 Post subject: |
They are common problems/symptoms of the SV Reg/Rec - barely enough power when the lights are off, turn them on and it can't sustain them.
It COULD be the alternator, but my is on the reg/rec
The 'curvy' SVs regulator was inadequte.
I replaced mine with a GSXR750 one (K5 IIRC) - couple of wires swapped about - job done -
Fits under the rear cowling (just) and is much more robust than the carp SV one!!
edit:
This one should see you right! (you just need to nick the plug off your old one and make sure all the wires match up correctly!)
https://cgi.ebay.co.uk/SUZUKI-GSXR750-GSXR-750-K4-REG-REC-REGULATOR-RECTIFIER-/370376941335?pt=UK_Motorcycle_Parts&hash=item563c2f9f17 ____________________ The purpose of life is to fight maturity. |
The last post was made 16 years, 11 days ago. Instead of replying here, would creating a new thread be more useful? |
