ZX6R rear fairing on an ER-5?
twiggeeukjnr
PostPosted: 23:48 - 06 Sep 2010    Post subject: ZX6R rear fairing on an ER-5? Reply with quote
I have a 2004 er5 and i like the street fighter look, would the rear end off a ZX6r go on? any info, please help!
Thought i saw your name on a loaf of bread today,
then i realised it said "Thick Cut"
Frost
PostPosted: 00:17 - 07 Sep 2010    Post subject: Reply with quote
It's a motorbike, not Lego.
PostPosted: 10:32 - 07 Sep 2010    Post subject: Reply with quote
Oi, thats my line. Razz
PostPosted: 10:33 - 07 Sep 2010    Post subject: Re: ZX6R rear fairing on an ER-5? Reply with quote
Theres only 1 way to find out Wink
DrDonnyBrago
PostPosted: 11:09 - 07 Sep 2010    Post subject: Re: ZX6R rear fairing on an ER-5? Reply with quote
FIGHT!!!
Billing
PostPosted: 11:32 - 07 Sep 2010    Post subject: Reply with quote
I reciprocate the need for a fight! Wink
Anything can be made to fit anything, it's just a case of how much time, money, fibreglass and filler you have.
First you need to see how far out the new rear end is (bearing in mind the ZXR uses a separate subframe whereas the ER-5 is part of the main frame IIRC) which will almost certainly require the plastics to be cut to fit (remove some material to clear the suspension units, front tips moved in as the ER-5 is amlost certainly thinner etc etc) You need to figure out how to mount the seats aswell as the ER has a one piece double unit, the ZXR has 2 single units.
Then you need to make some brackets for the mounting points as these are unlikely to be in the same place. After that it's the rear light, the wiring plug on the light unit is probably different to the one on the bike's loom. As long as there's the same amount of wires and you know what each one does (i.e 4 wires on each, you need to know what wire on the loom powers which light bulb)
It won't be easy, look at the ballache you get when trying to put a later Hornet tail on an early bike, and thats on the same model of bike!
Asimo
PostPosted: 17:09 - 07 Sep 2010    Post subject: Reply with quote
Sounds like it'd be less work cutting the er5s subframe off and mounting the zx6r's instead.
Frost
PostPosted: 17:52 - 07 Sep 2010    Post subject: Reply with quote
That assumes that the distance between the left mounts and the right are the same as the ER5's. It also assumes the distance between the top and bottom mount on each side are the same, and that the tail will be at the right angle when fitted. None of these will be the case. It can of course be fitted but will require accurate bending, cutting and welding to a quality to which you would trust your life, as thats exactly what you'd be doing.
twiggeeukjnr
PostPosted: 21:34 - 07 Sep 2010    Post subject: Reply with quote
Thanks for da help guys, i have plenty of time and elbow grease, unfortunately my pot of money does hav a bottom but i fink i will giv it ago.
hopefully it will look as good as the picture in my head!
mite hav it done for nxt summer! Laughing
Will get sum pics on wen the job is done.
PostPosted: 21:55 - 07 Sep 2010    Post subject: Reply with quote
Or, you could sell the ER5 and buy a ZX6R?
Carvel
PostPosted: 22:00 - 07 Sep 2010    Post subject: Reply with quote
This.
Just take the fairings off, job done.
The last post was made 16 years, 4 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 0.98 - MySQL Queries: 13 - Page Size: 69.86 Kb
