Where has my speed gone?
wisebeuy
PostPosted: 17:51 - 23 Jul 2004    Post subject: Where has my speed gone? Reply with quote
Have got a Honda XLR 125R, and i usually get about 60-65 when cruising, and can usually get up any hill in 4th gear, but for the past 100 mile or so have noticed that the power seems to have dropped a lot, and am having trouble hitting 60, and am having to drop to 3rd on quite gentle hills, any idea what might be causing this?
Thanks Thumbs Up
Wisebeuy
badlydamaged
PostPosted: 19:08 - 23 Jul 2004    Post subject: Reply with quote
Hey there, well first question is what mileage is the engine. It could be that the rings are worn beyond servicability and need replacing. A check for this would be a compression test (ask any garage, they'd charge you a fiver if anything). Compression should be 156-198psi . Other than that im not sure, have you over filled the engine oil? That could possible cause a lack of power. Also so could large dents in the exhaust (once had a field car that went over some rocks and kicked the exhaust, causing it to loose a heck of a lot of power), could possbily if it's been used off road. Another thing is tyre presures, if they are under inflated performance can suffer due to the increased rolling resistance. The airfillter could be choked up restricting power, choke may be sticking or other possbile carbueration faults. Just a few ideas that may be worth checking. Good luck, hope it's an easy fix Thumbs Up .
My bike: 1988 Kawasaki KH100 Status: Polluting Devon with two stroke smog and noise pollution!
"Its not your engine size that matters!, It's what you do with it that counts" Very Happy
Add me to MSN if you want! [email protected].
wisebeuy
PostPosted: 20:43 - 26 Jul 2004    Post subject: Reply with quote
bloddy hell, a lot of things to bear in mind there! The engine has certainly done a fair distance 19k+ in its 3 years, but i don't know how much, if any of the engine has been replaced. I did however slacken the chain a bit yesterday, and this seemed to get it going a bit faster, think i must have tightened it too much when putting wheel back on after repairing puncture. Just hoping its not too slack now.
Thanks again
Andrew
Frost
PostPosted: 22:04 - 26 Jul 2004    Post subject: Reply with quote
Plugs:
check the spark, make sure its fat, bright, regular, check it when the engine is hot and when it is cold.
Seals: check your piston rings, make sure they are not worn or damaged, this will result in lower compression and poor performance
zzr_peak
PostPosted: 21:55 - 30 Jul 2004    Post subject: Reply with quote
clean out your exhaust
bikedudextrm
PostPosted: 03:02 - 31 Jul 2004    Post subject: Reply with quote
My top speed fell off and went down the drain the other day Laughing .
Ignore me, i'm in a weird funny (ish Rolling Eyes ) mood,
Police Tut Tut
https://www.bikepics.com/members/bikedudextrm/
PostPosted: 04:03 - 31 Jul 2004    Post subject: Reply with quote
Don't worry, just add a bit of sugar to the petrol tank and it'll go faster again. The more you add the faster it will then go. Very Happy Thumbs Up
Try if it you want, but don't blame me if it goes too fast, or won't go at all.
wisebeuy
PostPosted: 12:26 - 04 Aug 2004    Post subject: Reply with quote
I tried your sugar thing, but it doesn't seem to have worked, the bike started spluttering and now it won't start, do I have to do something else?
lol Very Happy Very Happy Very Happy
The last post was made 22 years, 62 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.94 - MySQL Queries: 13 - Page Size: 56.63 Kb
