At witts end with a weird acceleration problem...
Damon
PostPosted: 19:28 - 08 Sep 2010    Post subject: At witts end with a weird acceleration problem... Reply with quote
Hi all, Got a bit of a problem.
Ever since I have had my R1 there has been a problem with it "jumping" under full load. It happens in first, second and sometimes third gear, but only when the throttle is pretty much to the stop and under hard acceleration.
It feels like the bike actually kicks underneath me and then feels fine. It kicks everytime the throttle is pinned at about 6 - 9 thousand RPM.
At first I thought it was the clutch, but I have replaced the plates and it was no better. I have also replaced the chain and sprockets, plugs and it gets new oil + filter every few months.
It's getting to the point now that after every corner I have to wait for it to kick before I can really settle down attack the next corner.
Does anyone have any idea? I will be more than greatful and am willing to send over some beer money to say thanks. It's stopping me from enjoying the bike. It really kicks sometimes and coming out of corners when it kicks is a nightmare...
Thanks,
Damon
instigator
PostPosted: 19:40 - 08 Sep 2010    Post subject: Reply with quote
Gearboxes are a weakness on early R1's, precisely why I've always avoided them. Let's hope I'm wrong.
It's jumping out of gear under heavy load and only in the first three gears, I'd hazard a guess that all three cogs have been butchered.
Benson_JV
PostPosted: 19:59 - 08 Sep 2010    Post subject: Reply with quote
Could it be the 'powerband'?
PostPosted: 20:05 - 08 Sep 2010    Post subject: Reply with quote
Not if it keeps repeating. Once they snap, they snap forever.
Benson_JV
PostPosted: 20:38 - 08 Sep 2010    Post subject: Reply with quote
Oh har har. Wink
Damon
PostPosted: 20:40 - 08 Sep 2010    Post subject: Reply with quote
Its only done 8,000 miles Neutral It doesn't jump out of gear as such. it just sort of kicks and then is fine. It never hits false neutrals or jumps out of gear. You could be right though. I hope not Thumbs Down
Acemastr
PostPosted: 20:52 - 08 Sep 2010    Post subject: Reply with quote
if it's carbs it could be overfuelling at certain revs with the throtttle pinned and then clears and is fine. someone will correct me though
2016 Toyota Tacoma Limited
L4Isoside
PostPosted: 21:04 - 08 Sep 2010    Post subject: Reply with quote
Thats what i though, tried balancing, adjusting and cleaning them?
Damon
PostPosted: 21:09 - 08 Sep 2010    Post subject: Reply with quote
They have been cleaned and balanced. Haven't adjusted anything however as fueling "feels" spot on everywhere. It doesn't bog down and feels fairly crisp for a carbed bike.
Karma
0l0dom0l0
PostPosted: 21:51 - 08 Sep 2010    Post subject: Reply with quote
when was the last time you replaced the air filter? if you havent done so, change it for a k&n one.
if it has been replaced recently, i would just go over and make sure it all looks ok. but if it doesnt have a k&n, fit one. they are very good at removing these kind of problems!
finpos
PostPosted: 22:32 - 08 Sep 2010    Post subject: Reply with quote
If it feels exactly like the chain is jumping a tooth, and it's happening more and more frequently over time, then it's the dogs on your gears starting to round off. Under load, the rounded dogs slip off each other, the gear now spins freely until some dogs line up again which smash into each other with great force and take up the drive again. You can imagine how much good that does it.
Nothing much to be done about it short of rebuild the gearbox if that's the problem. Never cheap.
f.
L4Isoside
PostPosted: 22:58 - 08 Sep 2010    Post subject: Reply with quote
f.
I was thought it could be the gears slipping, but then thought, once its in gear it couldnt just slip but would jump out?
danjameswhitt
PostPosted: 23:05 - 08 Sep 2010    Post subject: Reply with quote
So what is the procedure for your dogs slipping off each other, possibly some kind of adhesive Laughing
Fortuna
PostPosted: 23:35 - 08 Sep 2010    Post subject: Reply with quote
Before I jump the gun and say effed gearbox, it's worth checking the regulator/rectifier first.
Here's how I rebuilt mine Smile Clicky
Damon
PostPosted: 00:14 - 09 Sep 2010    Post subject: Reply with quote
It has a K&N filter which has been checked and is all clean. Thanks for the link fortuna. I have rebuilt gearboxes on smaller bikes before but haven't touched the R1 internally. Wink
Would having worn dogs make it "kick" like it does. It almost feels like the back is spinning up and then it grips and all is back to normal again. As soon as It kicks it feels more powerful, but thats more than likely due to the fact its at a higher RPM and making more power.
Not too sure what peak power is on th 4xv r1 Chris.
Thanks for the comments
Damon
PostPosted: 00:30 - 09 Sep 2010    Post subject: Reply with quote
Yeah I have tried that. It only happens once when I am accelerating from a slow speed to a high speed. For example, I will pin it from a stand still in first. It will kick once at around 60mph and then won't kick again in second, third etc until I slow down again.
If I short shift into second and then pin it, it will kick at about 80 - 100mph and not kick in 3rd or again until I slow again (braking for a corner etc)
Karma
danjameswhitt
PostPosted: 01:45 - 09 Sep 2010    Post subject: Reply with quote
Now it would appear I was trying a little too hard to be funny, and over looked the fact I have no clue what the heck i'm going on about when it come to maintainance issues!
I'll get my coat and go outside and give myself a kicking for trying to be a smart arse Laughing
something called 'dogs' on a bike, who'd a thunk it!
Fortuna
PostPosted: 05:18 - 09 Sep 2010    Post subject: Reply with quote
By what you have just posted I would say worn dogs.
And yes it feels like it's kicking especially under load.
Find a steep hill and go into 2nd gear. Pin the throttle and tell us if it does it. Try a few times to be sure.
ram_doom
PostPosted: 11:19 - 09 Sep 2010    Post subject: Reply with quote
Worth checking coils/plugs and throttlebodies surely?
TL1000s, KDX200
Damon
PostPosted: 11:39 - 09 Sep 2010    Post subject: Reply with quote
It's carbed Mr. Green
I have checked the coils and changed the plugs. Still no better.
Fortuna, I'll go and have a ride up a steep hill and let you know what happens.
Thanks
PostPosted: 11:46 - 09 Sep 2010    Post subject: Reply with quote
O dear. I suggest if you know nowt about bike gearboxes not to bother trying to post "witty" comments.
The bits on the sides of the cogs that engage with the next cog are known as dogs. Yes they can get worn and start to slip.
PostPosted: 18:04 - 09 Sep 2010    Post subject: Re: At witts end with a weird acceleration problem... Reply with quote
Worn gear dogs or chain jumping teeth. My guess is it's the gear dogs. It feels like a heavy ratcheting under power. If you don't fix it you'll hammer notches in the shift drum tracks.
Damon
PostPosted: 20:45 - 09 Sep 2010    Post subject: Reply with quote
Thanks for the link. I'm gonna buy each gear new I think and go from there. The cogs posted may have the same problems as mine has currently. Hopefully it's only 1st, 2nd and 3rd that need doing Confused
That's if it is the gearbox that is.
I didn't manage to get out on it today but will try the hill sprints tomorrow if i get a chance and post back.
Thanks again for all help guys
Damon
PostPosted: 14:59 - 11 Sep 2010    Post subject: Reply with quote
Update:
I went out on the bike yesterday to see if it would jump and kick any more under hard acceleration on a steep hill. Well, instead of doing the above I found myself practicing my power wheelies with the new quick action throttle Rolling Eyes Eneded up at nandos, then more 1 wheel action and home for a cup of tea.
It wasn't until I got home I realised I hadn't done any hill work and/or anything I was supposed to.
Oh well, there is always tomorrow Laughing
The last post was made 16 years, 11 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.10 Sec - Server Load: 0.76 - MySQL Queries: 13 - Page Size: 126.86 Kb
