Rear axle nut - CBF125
Killer Rat
PostPosted: 20:30 - 09 Sep 2010    Post subject: Rear axle nut - CBF125 Reply with quote
Need a replacement nut, size 14mm.
I can't seem to find a genuine honda replacement nut so is it possible to use any 14mm nut that is sturdy enough for the job?
Cheers.
Quote Me Happy
PostPosted: 20:33 - 09 Sep 2010    Post subject: Reply with quote
Did you try a Honda dealer or David Silver's?
Killer Rat
PostPosted: 21:19 - 09 Sep 2010    Post subject: Reply with quote
Not yet, will try them in the morning though. I will begrudge paying £5-£10 though for it.
Quote Me Happy
PostPosted: 21:21 - 09 Sep 2010    Post subject: Reply with quote
I'd begrudge my wheel falling off more.
What happened to the old one?
Killer Rat
PostPosted: 21:25 - 09 Sep 2010    Post subject: Reply with quote
The old nut is still there but is virtually rounded off, so i must get that off and replace to be able to adjust the chain regularly.
Quote Me Happy
PostPosted: 21:29 - 09 Sep 2010    Post subject: Reply with quote
Get a decent correct size socket as well to stop it rounding off again.
Ed Case
PostPosted: 21:39 - 09 Sep 2010    Post subject: Reply with quote
The brief answer is, No, you cant just stick any 14mm nut on there as there are at least two different thread pitches. Usually for that application it's a metric fine, 14 x 1.25 pitch. Get the correct one from David Silver and you'll be doing it right, and while you're at it if you haven't got a spanner of the right size, unless of course the previous owner was responsible for effing your nut up, go get one. Even a 'cheapie' one is better than a pair of 'grips'.
neil.
PostPosted: 07:00 - 10 Sep 2010    Post subject: Reply with quote
Good luck getting the old nut off, axle nuts are often torqued to oblivion. Invest in these, they've saved my bacon many times!
https://www.screwfix.com/prods/96028/Van-Car-Accessories/Sockets-Hex/Irwin-5-Piece-Bolt-Grip-Nut-Remover-Set?cm_mmc=GoogleBase-_-Datafeed-_-Van%20and%20Car%20Accessories-_-Irwin%205%20Piece%20Bolt%20Grip%20Nut%20Remover%20Set
The last post was made 15 years, 358 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 0.59 - MySQL Queries: 13 - Page Size: 53.25 Kb
