Project Götter Motorrad
Bike Chat Forums Index -> Show & Tell Goto page 1, 2, 3, 4, 5, 6, 7  Next
Ichy
PostPosted: 20:11 - 11 Sep 2010    Post subject: Project Götter Motorrad Reply with quote
I've taken a few risks in my life. I helped to start up booby trapped machinery in Croatia. I've driven a Veyron at over 200mph. I rode a BMW S1000RR on the Autobhan at night in the rain. I've been shot, stabbed, and electrocuted. The list carries on and despite this I've learnt nothing.
Today I brought The Artists (formerly known as Allymoss) old GS125.
I was warned by others and even Ally pointed out that it needed work but it didn't stop me. Even common sense took a nose dive and I made the decision to ride it the 25 miles back home with no tax or MOT.
It started well, being old and boring meant that insurance was free. A quick call to a friendly garage and it was 'booked' in for a MOT just in case. Roads were wet but the sun was shining so with stout shoes and prevailing optimism we left to pick it up.
I struggled to find Mossys house and I should have taken that as a sign of impending doom, even my initial attempts at contact resulted in voicemail. Unfortunately just as I was preparing to abandon the quest he called back.
Blah, blah, blah. All done and dusted and off I go with a list of known problems.
No speedo or Tacho.
Exhaust bracket broken.
No indicators.
Oil leak.
Fork seals knackered.
Erratic tickover.
Riding the bike revealed other issues.
Steering wasn't straight.
Handling was 'interesting'.
Brakes were classic 80's, they did nothing above 5mph.
Mirror tended to get bored and look at the sky.
Engine was very rattlely.
Nothing major and I arrived at my house in mainly one piece.
Let the photos speak for themselves. Sorry for the quality, the fear was still running through me when I took them.
https://i93.photobucket.com/albums/l41/marki_03/GS125/SDC10559.jpg
https://i93.photobucket.com/albums/l41/marki_03/GS125/SDC10560.jpg
Nice welding.
https://i93.photobucket.com/albums/l41/marki_03/GS125/SDC10566.jpg
Chain might need adjusting. There is as much movement sideways as there is up and down.
https://i93.photobucket.com/albums/l41/marki_03/GS125/SDC10565.jpg
Bit of an oil leak.
https://i93.photobucket.com/albums/l41/marki_03/GS125/SDC10562.jpg
Throttle cable went for the minimalist route.
https://i93.photobucket.com/albums/l41/marki_03/GS125/SDC10563.jpg
Man oh man, this is just the start. The more I looked the worse it got, so I stopped looking.
Additions to the list.
Exhaust has a big hole in it.
choke lever missing.
Blow up tyres, pressure was 17psi front and 13psi rear Laughing
Warning lights don't work.
Brake light is permanently on. Front switch doesn't work.
Lots of loose or mismatched fixings. 6mm into 8mm doesn't go.
Headlight is loose and points were it likes.
NO OIL IN ENGINE Rolling Eyes
etc etc.
This sort of sums it up for me.
https://i93.photobucket.com/albums/l41/marki_03/GS125/SDC10567.jpg
Not obvious on first looks but the speedo cable is attached to the tacho. Wink
I've spent an hour on it and given it a good clean, topped up the oil and started pulling it apart. Oil leak has been located and many new parts on order. Speedo and tacho are working, brake light fixed, and tickover sorted. Give it time and it'll be fine.
woll
PostPosted: 20:25 - 11 Sep 2010    Post subject: Reply with quote
You are one brave man Neutral or should that read daft?
Don't trust the stand, it falls over for no reason Laughing
Might want a new exhaust really lol.
In short, mossy abused it.
CHR15
Turbo nutter bastard
PostPosted: 20:30 - 11 Sep 2010    Post subject: Reply with quote
you forgot:
exhaust was run over by a merc.
throttle cable has right angle in it half way along.
the brake light flickers like a candle as you ride along.
on the plus side, the nearside pillion peg is a special 'gravity locating' item it will always point towards the centre of the earth... handy for something im sure.
and at least no one will ever nick it!!
Ichy
PostPosted: 20:35 - 11 Sep 2010    Post subject: Reply with quote
Remember Woll, one life, live it.
(Thankfully for longer than the 45 minutes it took me to get home!)
In Mossys defence he was very honest about it. I got pretty much what I expected.
Ichy
PostPosted: 20:49 - 11 Sep 2010    Post subject: Reply with quote
Chris I liked the idea of a throttle cable that you can check hasn't fallen off while riding along. Forgot to mention that the throttle adjuster hits the tank on almost full lock, sort of a pre warning that your running out of steering.
Brake light is sorted, it was due to the exhaust using the brake pedal as the only form of support. Foot peg is a little bit confusing. I assumed that it was this way around to give a good handhold when it fell over?
woll
PostPosted: 21:05 - 11 Sep 2010    Post subject: Reply with quote
Ahhh forgot about those bits chris Laughing The awesome peg that always points to the centre of the earth Laughing
Frost
PostPosted: 21:23 - 11 Sep 2010    Post subject: Reply with quote
I would be working under the assumption that every single bearing and seal was knackered and see about buying a full set from somewhere. Drum brakes were old hat even back in the 80's though they can very very cheap to fix, also quite expensive Laughing
Cosmetically it's a dog, but provided everything that would move does, everything else doesn't and nothings leaking it will be good for a fair bit.
Ichy
PostPosted: 22:28 - 11 Sep 2010    Post subject: Reply with quote
rob yarrr wrote:
man you've got some ballz
Don't you know it. I did a wheelie just past Shavington and then rode down the middle of the A500 up to the motorway island. Felt like I was 18 again.
mr.kris
PostPosted: 23:12 - 11 Sep 2010    Post subject: Reply with quote
my CG is way more win than that its made from pure fail witch translates to pure win !
TS50X---CM125---MZ150---Z250---RS125---ZXR250---BANDIT600---TRX850---TL1000S---CBF600---ZX6R---BANDIT1200S---CG125---VFR800---CBR1000F---CG125---CG125---CB900F---CB900F---CG125---TUONO1000R---KLR600---GSX1300R HAYABUSA---VFR400NC30---BANDIT1200---CG125
HAYABUSA now in use!
Carl_steveo
PostPosted: 23:12 - 11 Sep 2010    Post subject: Re: Project Götter Motorrad Reply with quote
Fuck the bike, would you care to elaborate on the above storys.
Thumbs Up Wink
Current: Honda Nsr 125
Live: Sunderland
Ichy
PostPosted: 23:47 - 11 Sep 2010    Post subject: Re: Project Götter Motorrad Reply with quote
Thumbs Up Wink
Tis easy. Starts with being brought up in inner city Birmingham and ends with a Very good job in Automotive Metrology with a bit of military service in the middle. Kinda funny really, I wanted to be magician when I left school.
Ichy
PostPosted: 21:34 - 12 Sep 2010    Post subject: Reply with quote
Not much done, just started stripping down.
https://i93.photobucket.com/albums/l41/marki_03/GS125/SDC10575.jpg
List of fail keeps growing, rear sprocket was loose, wheel bearings need changing, tank rubbers are missing, best so far is the rear 18" wheel is fitted with a 17" tyre.
I need to find a manual.
CHR15
PostPosted: 21:38 - 12 Sep 2010    Post subject: Reply with quote
I think the only nice bit is the self amalgamating tape on the electrics, courtesy of moi.
Welshd1k
PostPosted: 22:35 - 12 Sep 2010    Post subject: Reply with quote
17" tyre ona 18" WTF... cn i ask why your bothering to spend money or time on it ?? jaja
CHR15
PostPosted: 23:01 - 12 Sep 2010    Post subject: Reply with quote
As the previous keeper is a member of the BCF massive I'll refrain from blaming ALL of the bikes shortcomings on him.
lol.
it was actually in quite nice condition before he got his hands on it.
B10Hazard
PostPosted: 23:09 - 12 Sep 2010    Post subject: Reply with quote
Iv seen the abuse that the bike has ha im suprised its still breathing. .
No longer any socks
Ichy
PostPosted: 23:52 - 12 Sep 2010    Post subject: Reply with quote
Its a challenge and it cost about the same as a rear tyre for my bike Laughing
The majority of faults are superficial. The biggest investment could be time, if I felt like it. Money wise it isn't going to cost much to get it on the road, safely. Having a quick count up I've spent £40 on all the cables,bearings,seals, gaskets, & consumables. £50 -£70 on top of that will cover everything else.
If I get carried away then completely new plastics, seat, shocks, and exhaust only comes to £160.
Frost
PostPosted: 01:42 - 13 Sep 2010    Post subject: Reply with quote
As said above, if you want cosmetics etc, the bike will quickly become a money pit as you'll never get it back in resale value. But if you want a cheap run around, getting to mechanically sorted doesn't cost much if you do it all yourself. At least if it still looks like a dog, no one will nick it Very Happy
FreshAL
Sir Crashalot
PostPosted: 09:57 - 13 Sep 2010    Post subject: Reply with quote
If he's got a good job in automotive whatever it was, I'm guessing he can afford to spend a bit of money on a hobby.
Good on you Marki, this is a restoration thread I will be following Thumbs Up
Chalky.
PostPosted: 10:16 - 13 Sep 2010    Post subject: Reply with quote
It does look pretty cool though!
Good effort mate.
The last post was made 16 years, 42 days ago. Instead of replying here, would creating a new thread be more useful?
Page 1 of 7
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.16 Sec - Server Load: 0.63 - MySQL Queries: 13 - Page Size: 137.52 Kb
