Could anyone recomend a cheap chain breaking / joing tool?
Stowelly
PostPosted: 21:13 - 15 Sep 2010    Post subject: Could anyone recomend a cheap chain breaking / joing tool? Reply with quote
Ive been looking on ebay and found a few for about 35-40 quid such as this one:
https://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&item=300466324758&ssPageName=STRK:MEWAX:IT
but have also read storys of people breaking the tool before getting the chain apart, and having problems joining the chain, so would like to be able to minimise this difficulty if possible!! its for a gsxr 600 DID chain.
edit: a lot of them say you need to grind the head off the rivet with an angle grinder first, is this really necessary? cant afford a angle grinder as well as the tool and the chain kit!
thanks a lot!
truslack
PostPosted: 23:18 - 15 Sep 2010    Post subject: Reply with quote
Best way to split a chain is purchase a cheap grinder and a set of centre punches.
I don't rivet links myself, so can't comment on that side of things.
PostPosted: 23:30 - 15 Sep 2010    Post subject: Re: Could anyone recomend a cheap chain breaking / joing too Reply with quote
As above; £15 or less for an angle grinder will break the chain fine.
I generally don't grind the head off when using my whale tool (often re-rivet them), but suspect you would have to anyway for cheaper tools.
You'll need to check if it's a hollow or solid rivet.
Pretty much any cheap tool should do the trick for hollow rivets, you'll need a whale tool for solid ones - so if you're short of cash, press the plates on and ride the bike (gently) to your local friendly garage Smile.
DrDonnyBrago
PostPosted: 07:08 - 16 Sep 2010    Post subject: Reply with quote
https://bikespeeduk.com/epages/steer2916.sf/en_GB/?ObjectPath=/Shops/steer2916/Products/CHAINTOOL
I have that one^^^
A thread I've posted in about it recently
https://www.bikechatforums.com/viewtopic.php?t=205127&highlight=chain
And how if you buy a DID chain you 'may' need to slightly modify the tool to fit it perfectly.
https://www.bikechatforums.com/viewtopic.php?t=199399&highlight=press+plate+modify
HTH Thumbs Up
Robby
Dirty Old Man
PostPosted: 07:50 - 16 Sep 2010    Post subject: Reply with quote
I'm not familiar with O ring chains that much, but can you get them supplied endless? If so, I would do that and take the swingarm out to grease the bearings while I'm doing a chain change. Saves buying an expensive tool, or worrying that you didn't peen the links over properly.
Stowelly
PostPosted: 08:16 - 16 Sep 2010    Post subject: Reply with quote
DonnyBrago wrote:
ah cheers for that info, also the link tot the site, as it works out alot cheaper than id previously found, so should be able to get a cheap grinder as well!
DrDonnyBrago
PostPosted: 08:24 - 16 Sep 2010    Post subject: Reply with quote
If the grinder is just to file the pins down on the old chain so you can take it off then assuming you don't wish to reuse it just use something like a hacksaw to cut it in half.
Stowelly
PostPosted: 09:00 - 16 Sep 2010    Post subject: Reply with quote
true, although cutting through the whole chain with a hacksaw seems like it could be an incredible amount of effort!
MarkJ
PostPosted: 09:01 - 16 Sep 2010    Post subject: Reply with quote
Or a £3 file like I use. Takes a bit longer though.
I file my old chain off, fit the new one with a split link then ride to my local garage and let them join the chain with the link that came with the chain.
CarlosCBR
PostPosted: 09:02 - 17 Sep 2010    Post subject: Reply with quote
Are split links safe to use on anything over 125cc?
PostPosted: 09:07 - 17 Sep 2010    Post subject: Reply with quote
Yes.
DrDonnyBrago
PostPosted: 09:36 - 17 Sep 2010    Post subject: Reply with quote
Yes, will never be as good as a properly rivetted link though. I'd be tempted to lockwire them on to stop them flinging off if I did have a split link.
Gazdaman
I did a trackday!!!
PostPosted: 13:23 - 17 Sep 2010    Post subject: Reply with quote
You buy a cheap rivetter, you buy twice.
I bought a £12.50 eBay MX jobby. It did about 3 chains then snapped.
Now I have a £50 jobby from a local bike shop that seems a lot sturdier.
Gaz
DrDonnyBrago
PostPosted: 13:35 - 17 Sep 2010    Post subject: Reply with quote
Gaz
Is your £50 very similar to the £22 one in the link I posted? Most of the ones in bike shops are the same thing but priced higher.
https://www.demon-tweeks.co.uk/images/product/product/bik_hd-chain-tool.jpg
Gazdaman
I did a trackday!!!
PostPosted: 13:39 - 17 Sep 2010    Post subject: Reply with quote
No, mine's this one:
https://www.worldofpower.co.uk//Gallery/product/chain_tool_01Popup.jpg
It's a Motrax one, but it's nicely made tbh, although that one you've posted does look good.
Gaz
Gazdaman
I did a trackday!!!
PostPosted: 13:40 - 17 Sep 2010    Post subject: Reply with quote
And this was the cheapy one I bought and broke.
https://cgi.ebay.co.uk/Challenge-Chain-Breaker-3-4-1-1-4-/370418682364?pt=UK_Motorcycle_Parts&hash=item563eac89fc#ht_1116wt_754
Gaz
truslack
PostPosted: 13:44 - 17 Sep 2010    Post subject: Reply with quote
Gazdaman wrote:
I had one almost identical to that, it pressed out 7 520 pitch rivets (without grinding the ends off) without fault, before I accidentally left it in the sidecar for a couple of months and it went rusty.
Quote Me Happy
PostPosted: 16:19 - 17 Sep 2010    Post subject: Reply with quote
I had a Motrax one and it broke on the third chain. I now have this one and it's going strong three chain later, fingers crossed.
Paxovasa
PostPosted: 16:41 - 17 Sep 2010    Post subject: Reply with quote
Grinder to remove chain and two hammers and a centre punch to fit the rivet link Thumbs Up
c-m
PostPosted: 10:58 - 05 Oct 2010    Post subject: Reply with quote
I need to remove an endless 110 530 pitch chain.
I don't have access to an angle grinder as there is no power socket at my bike's location.
Has anyone ever hacksawed through their chain?
Wondering how long that would take
PostPosted: 11:00 - 05 Oct 2010    Post subject: Reply with quote
Quite a while as it's tough metal. Don't know if it'd work, but I'd be tempted to try bolt croppers.
Gazdaman
I did a trackday!!!
I've hacksawed through a few. It doesn't take long.
Just pick a thin part, where there's only two plates. It'll go straight through them.
Gaz
DrDonnyBrago
PostPosted: 11:03 - 05 Oct 2010    Post subject: Reply with quote
Probably about as long as it took you to turn on your PC and post that question Wink . They aren't hardened or anything as far as I can tell, they cut ok with a decent blade; you could probably bolt cropper it if you really wanted.
EDIT: G beat me to the bolt cropper suggestion.
The last post was made 15 years, 116 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 0.86 - MySQL Queries: 13 - Page Size: 129.12 Kb
