Honda wont start!!
seriousc
PostPosted: 22:17 - 21 Sep 2010    Post subject: Honda wont start!! Reply with quote
hello i had recieved today my streetfighter style headlights and indicators for my honda ns125r, after taking off the frame and attaching the clock to the handlebars ETC, i fitted the the headlights too a postive and a negative for the headlights (there are more for headlights example: flash and high beam which was not installed and compatible for my new headlights). anyway after moving thing around and fitting it all together i started up the bike and all was well, my friend then tapped my engine stop button and then turned back off again (bike cut out at this point).... but now the bike wont start!? i have taken out the spark plug and it has a decent spark from what i can see! it has fuel in there but maybe a little too much?.... Can someone PLEASE HELP!! i need my bike for college and its NEVER gone wrong so far!! Sad
Chalky.
PostPosted: 22:21 - 21 Sep 2010    Post subject: Reply with quote
Sounds like wiring shorting or a fuse
seriousc
PostPosted: 22:25 - 21 Sep 2010    Post subject: Reply with quote
Exactly as i was thinking, it has got too late tonight so i shall carry on looking after college tomorrow (after my 6 mile walk there and back Neutral ) i had fiddled about but yet cant find a solution! is there a possibility that the engine stop has gone wrong down the line? engine stop wiring?
-Savage-
PostPosted: 22:33 - 21 Sep 2010    Post subject: Reply with quote
So you just swapped your lights with a new set?
Does the starter motor turn?
Do the lights/electrics work?
You say your mate flipped the kill switch? Have you had problems with it before? Maybe a short in the switch?
Have you tried to bump start it?
seriousc
PostPosted: 22:39 - 21 Sep 2010    Post subject: Reply with quote
it was a whole new fairing/streetfighter style headlight.
it has compression.
lights, indicators and horn etc works.
bike does not have a electric start due too the year.
i have tried a couple bumps starts in various gears, the bike just does not like me :\
its NEVER had a running problem EVER so far! and was fine until my friend pressed the killswitch and tried starting again with a bit of choke.
has a spark and i left for HOURS too make sure it wasnt just flooded!
PLEASE HELP!
thanks
c-m
PostPosted: 22:41 - 21 Sep 2010    Post subject: Reply with quote
If you have compression and spark then the only thing you are missing is fuel. Otherwise it would start.
If it was the kill switch you would not get a spark
Chalky.
Remove the killswitch and try it then, it could be knackered
Chalky.
PostPosted: 22:42 - 21 Sep 2010    Post subject: Reply with quote
I take it you didn't touch the ignition and the key is turned?
seriousc
PostPosted: 22:45 - 21 Sep 2010    Post subject: Reply with quote
it HAS fuel! there was fuel in the head when i took out the spark plug! and i checked my spark plug against a bit or metal.
i shall have too try the kill switch tomorrow (hoping with fingers crossed) but then like you said.... it shouldnt be sparking if it was the killswitch!? quiet honestly this has baffled me!
and i didnt directly touch the ignition BUT the wires do enter the same loom as the ones which have been moved! all dash lights work for example neutral light
Chalky.
PostPosted: 22:46 - 21 Sep 2010    Post subject: Reply with quote
Ah didnt read it all. Can't be electrical if you have a spark.
Fuel vote.
seriousc
PostPosted: 22:49 - 21 Sep 2010    Post subject: Reply with quote
Fuel vote.
but surely if it has never (since 1988) had a single fuel problem or any other problem up to the second i changed my headlights had a problem cant be a fueling problem? if so what am i looking at?
Welshd1k
PostPosted: 22:53 - 21 Sep 2010    Post subject: Reply with quote
So it has spark yes? it has fuel yes?
try put a smidgen of petrol down the cylinder with the plug out wind the plug in and kick her over.
i higly doubt its anything serious...
if it was fine before kill switch was hit
turn the lights ALLL off etc. does your battery hold charge? as in lights work with jus ignition on?
my ns engine runs with a dead battery just make sure nothing is on when i try to kick it over from fresh.
is your choke jammed on?
Welshd1k
PostPosted: 22:55 - 21 Sep 2010    Post subject: Reply with quote
also get a new plug just incase . i have had plugs die that spark out of the cylinder and dont under compression easy thing to check.
seriousc
PostPosted: 22:58 - 21 Sep 2010    Post subject: Reply with quote
i shall try tomorrow with the petrol in cylinder!
it was completey fine before. i shall unplug my headlights and indicators and try again tomorrow! it has never had the battery flat and ALWAYS started first try one kick start! always ran on castrol oil and super unleaded!
if choke is jammed on how would i go about solving it?
im kinda thinking maybe its time to let go of the beautiful machine! the fairings are looking shabby! but i still cant see how a machine like this that has NEVER had a problem or been taken apart can just go wrong over something so silly!
Welshd1k
PostPosted: 12:29 - 22 Sep 2010    Post subject: Reply with quote
brilliant bikes mate . just track the cable down to the carb for the choke and makeshure that it isnt jammed up
it wont be much
seriousc
PostPosted: 16:44 - 22 Sep 2010    Post subject: Reply with quote
Tbh i dont have alot of time to sod around! im constantly busy so never have the time. i might jus sell it for say 500 ONO and jus book my full bike test :\
Welshd1k
PostPosted: 17:58 - 22 Sep 2010    Post subject: Reply with quote
non runner streetfigherd £500 ? thats a joke right you'll be lucky for £200
seriousc
PostPosted: 18:04 - 22 Sep 2010    Post subject: Reply with quote
well like we have already discussed it cant be a big problem as 5 seconds before i changed the headlight it was working! and there are plenty of bike around exactly the same as a streetfighter for around 1000, maybe in a lil better condition but still no diffrence apart from im selling cheaper, plus i did say MAYBE and nearest offer
Welshd1k
PostPosted: 18:18 - 22 Sep 2010    Post subject: Reply with quote
find me a 1980's ns125 rk or F that is getting more then £600 in all original bits
https://cgi.ebay.co.uk/1990-HONDA-NS125R-K-RED-/220670842632?pt=UK_Motorcycles&hash=item336101d708
with a £100 micron and a rs125 carb ...
seriousc
PostPosted: 18:59 - 22 Sep 2010    Post subject: Reply with quote
Read what i said^^ i said streetfighter! AND i HAVE all the original PARTS!! EVERYTHING! all fairings and all. they are stored away, so if i was too sell i will be selling it ALL together! streetfighter parts + original!
Welshd1k
PostPosted: 19:08 - 22 Sep 2010    Post subject: Reply with quote
still not worth £500 as a non runner mate. i paid £450 for my MINT ns125 ... that was running a dream. liek i said £300 ish and your lucky
seriousc
PostPosted: 19:12 - 22 Sep 2010    Post subject: Reply with quote
yeh i will probs take 300 lowest tbh mate, i have so much for this bike it has been a dream!
but i have seen several streetfighters go for around 1000, here is one that hasnt sold but an example of the price!
https://cgi.ebay.co.uk/220666491329
Welshd1k
PostPosted: 19:26 - 22 Sep 2010    Post subject: Reply with quote
wonder why it didnt sell why pay that for a ns when you can have a rs.....
also that bike is running and has a clean looking micron on it....
seriousc
PostPosted: 19:29 - 22 Sep 2010    Post subject: Reply with quote
oh yes i no but im saying for an example you can see them for higher prices, tbh im going to agree with the RS quote! if i could go back and do something it would be not too have sold mine Sad
anyway the point stands that i am thinkin of selling for 300 pound
hornetmike
PostPosted: 09:55 - 23 Sep 2010    Post subject: Reply with quote
Don't be a girl fix it
87 Honda CG 125 - 97 ER5 - SR 50 -81 Z250- 96 CBR 600 F- 94 GPX600R 88- GPX 400R- 87 GS 125 - 2006 Honda CB600F- 2003 ER5 - Honda CBF 1000 2009 - Honda CBR 600 RR 2011
Current BMW R1200GS 2010
The last post was made 16 years, 2 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 0.98 - MySQL Queries: 13 - Page Size: 123.43 Kb
