| Crystal Tipps |
 Crystal Tipps Nova Slayer
| pinkyfloyd |
 pinkyfloyd Super Spammer
| angryjonny |
 angryjonny World Chat Champion
| SirEdward |
 SirEdward Could Be A Chat Bot
 Posted: 10:53 - 27 Sep 2010 Post subject: |
If there's an idle adjuster, increase it, then start the bike and let it sit till normal t*.
When you turn off the choke, the idle revs should sit in place and engine shouldn't stall - if it does, increase idle speed. If no idle adjuster is avail, keep the revs up 0-15% above your normal idle speed till bike's warmed up.
P.S. Don't be enthusiastic with the starter, or you'll drain the battery.
Post Scriptum 2: 4-stroke non-injected 125 in the winter, now there's the fun. A thing to consider for everyone looking for a commuter. ____________________ "Beyond a critical point within a finite space, freedom diminishes as numbers increase. This is as true of humans as it is of gas molecules in a sealed flask. The human question is not how many can possibly survive within the system, but what kind of existence is possible for those who so survive.
Pardot Kynes in "Appendix I: The Ecology of Dune"" |
| N cee thirty |
 N cee thirty Banned
| stonesie |
 stonesie World Chat Champion
 Posted: 21:45 - 27 Sep 2010 Post subject: |
With full choke on mine it drags so much fuel it will not run at all, handy for priming it though. On CG's the choke does not open the throttle to raise the revs, its almost the definition of basic.
Full choke and a couple of kicks and it tries to fire.
Choke to half
A good kick and she's away.
No lecky start on mine, you posh git  |
| blurredman |
 Posted: 22:20 - 27 Sep 2010 Post subject: |
| stonesie wrote: | With full choke on mine it drags so much fuel it will not run at all, handy for priming it though. On CG's the choke does not open the throttle to raise the revs, its almost the definition of basic.
Choke to half
Really? Mine often starts first kick no choke even in the cold! ____________________ CBT: 12/06/10, Theory: 22/09/10, Module 1: 09/11/10, Module 2: 19/01/11
Current: 1973 MZ ES250/2 - 18k, 1979 Suzuki TS185ER - 10k, 1981 Honda CX500B - 91k, 1987 MZ ETZ250 - 40k, 1989 MZ ETZ251 - 52k. |
| stonesie |
 Posted: 22:58 - 27 Sep 2010 Post subject: |
Mine often does too, surprised my dad the other day when he gave it "just 1 gentle kick" and it fired up, but occasionally it acts up and that little procedure has only failed when numbnuts here forgot to turn the fuel tap to reserve  |
| Crystal Tipps |
 Posted: 08:15 - 29 Sep 2010 Post subject: |
| gager5000 |
 gager5000 Renault 5 Driver
| SirEdward |
 Posted: 18:15 - 30 Sep 2010 Post subject: |
| stonesie |
| Crystal Tipps |
 Posted: 17:20 - 03 Oct 2010 Post subject: |
Thanks again for your tips. I'm just having to be a bit more patient & let it tick over for a bit. On the odd day it still cuts out as soon as it starts, but mostly it will tick over, albeit slowly.
I don't think riding with the clutch still on is the problem, as I've only done that twice, on half choke, for a 5 minute ride, but I'll try not to do it again, and in between my daily 5 minute commutes to work I do take it on random rides & give it the "Italian tune up" treatment, so don't think that's the problem either.
All the other advice I will look into if things don't go according to plan from hereon...thank you  ____________________ First bike: 2002 CG. Now riding lime green 2008 ER6N. |
The last post was made 15 years, 342 days ago. Instead of replying here, would creating a new thread be more useful? |
