RXS 2 stoke rebuild on non runner, high idle
skeverd
PostPosted: 22:03 - 27 Sep 2010    Post subject: RXS 2 stoke rebuild on non runner, high idle Reply with quote
I completed a rebuild on my Yamaha RXS which i bought as a non runner. I started the bike up and its revving very high to the point where i felt it was necessary to switch of the ignition after less than a second or so.
The rebuild included a carb clean. Also the bore was increased to 1.00 oversize.
I put the engine in, and connected everything up. I started it via encouragement using a small amount of fuel in spark plug hole. Pilot screw is set to 2.5 turns out.
The throttle is adjusted so there is maximum slack on the cable (the cable also fails to return?)
I wondered if anyone has come across anything similar? if so what could be done to rectify the issues?
Thanks. shamen.
Quote Me Happy
PostPosted: 22:14 - 27 Sep 2010    Post subject: Reply with quote
Air leak on the carb side of the engine? Check the carb is seated in the rubber boots correctly and that they aren't cracked. Don't over tighten the clips around them either.
skeverd
PostPosted: 22:23 - 27 Sep 2010    Post subject: Reply with quote
I did have trouble getting the carb in place with the air filter, mainly bc it was dark during re-assembly. i shall check tomorrow and post back asap. any idea about the non returning throttle issue?
PostPosted: 22:39 - 27 Sep 2010    Post subject: Reply with quote
Has it got an Airbox or just a pod filter?
skeverd
PostPosted: 22:49 - 27 Sep 2010    Post subject: Reply with quote
'Just' a pod filter? i thought these hip nd withit people add those on? Laughing nah, just the standard airbox, i want to keep it original, i want it to be a reliable bike - i figured keeping it as close to standard would help me with that?
skeverd
PostPosted: 20:04 - 28 Sep 2010    Post subject: Reply with quote
well its running =D only now it wont idle - and revs take so long to go down also Sad
on the other hand twist grip returns Very Happy
any idea on the 2 problems stated?
Carvel
PostPosted: 20:14 - 28 Sep 2010    Post subject: Reply with quote
Mine did this. Check all your carb rubbers are seated probably, most likely an air leak.
About the tickover, have you tried ajusting the tickover screw up a bit?
skeverd
PostPosted: 20:23 - 28 Sep 2010    Post subject: Reply with quote
ive set the pilot screw to 2 and a half turns out as mentioned above... with this the bike still wont idle regardless of the idle screw position.
it seems like its going to die, so i adjust the tickover and then it chooses to rev up high and take ages to then return to almost dying again. if i leave it it does die...
PostPosted: 20:52 - 28 Sep 2010    Post subject: Reply with quote
This is going to sound a bit crazy but being that the throttle cable doesn't return as well as the high idle...
... Is the throttle slide in the right way around? I know its easily done as I did it meself when I rebuilt my RD350...
SpannerMonkey
PostPosted: 21:52 - 28 Sep 2010    Post subject: Reply with quote
I've done it too on an RXS in fact.
will start first or second kick and rev its knackers off.
the throttle slide is probably in the wrong way. if you look inside the carb where the trottle slide is you'll see there is a stubby bit inside the carb, and a cutout in the slide. Line these up and you're good to go.
skeverd
PostPosted: 22:26 - 28 Sep 2010    Post subject: Reply with quote
haha, yea, this infact was the problem, though i already rectified it Embarassed
but yea, now i just have the inability to idle and the revs not settling... Crying or Very sad
SpannerMonkey
PostPosted: 22:28 - 28 Sep 2010    Post subject: Reply with quote
first of all, Have you fit a new plug? =Pall that running on the main jet will foul a plug in NO time. My rxs got through em once every 2 weeks
skeverd
PostPosted: 23:02 - 28 Sep 2010    Post subject: Reply with quote
no i havnt changed the plug, but it seems fine atm.
Another problem, the clutch seems to be either enguaged or not engaged - theres no in-between! this seems to be a problem with the whole starting thing... Crying or Very sad
Not sure if its normal, but when i kick the engine over without the ignition on, i can feel air coming out of some sort of nipple on the carb? right hand side...
cb1rocket
PostPosted: 13:20 - 29 Sep 2010    Post subject: Reply with quote
Have you adjusted the tickover/idle screw - its not the same as the pilot screw in case you wondered... hence the high idle
27cows
PostPosted: 14:00 - 29 Sep 2010    Post subject: Reply with quote
Idle screw should be around 1 1/4 turns out. 2 1/2 is way too much.
Non-returning throttle could be caused by the twist grip being pushed too far onto the bar, or because the inner plastic is damaged or chafing at the end of the bar, or because the cable isn't routed correctly. Small possibility of the throttle slide being round the wrong way but that normally results in hysterical high revs as soon the motor fires up.
You shouldn't have air coming out of the carb when turning over the motor, I don't think Shocked Have you got the various pipes on the right places?
Making an RXS run anything but nicely actually takes a bit of doing in my experience, so look for something pretty obvious Wink
skeverd
PostPosted: 14:42 - 29 Sep 2010    Post subject: Reply with quote
I managed to attain a very high idle when the pilot screw was at 1 1/4 turns, though its so innacurate as it changes if i blip the throttle. the bike still wont calm down. also, i put my finger over that nipple with air coming out whilst it was running, the rpm increased considerably? Confused
The throttle is now returning (worked in some fresh grease). about these pipes, all i have connected on the carb is the thottle cable and the fuel line, would it be possible to maybe explain/ maybe send a pic of what pipes should be in place and there purpose?
thanks.
Oh, forgot to mention, when the bike is turned off from warm that nipple lets out a small amount of smoke? like that of a handgun after firing?
Carvel
PostPosted: 17:17 - 29 Sep 2010    Post subject: Reply with quote
Shocked erm what about the oil line?
Robby
Dirty Old Man
PostPosted: 17:24 - 29 Sep 2010    Post subject: Reply with quote
Stuck float could be a contributing factor. Giving the carb a good solid tap with the back of a screwdriver generally gets them to settle down.
When I have had trouble with the revs dieing down very slowly it has been down to a clogged up mixture circuit - so the pilot screw isn't doing anything, and the idle screw is wound in a lot to compensate.
The solution there is to take the carb out, remove the mixture needle and spring, blast plenty of carb cleaner into its hole (using a long straw on the nozzle) and reassemble. Often caused by rusty water in the tank getting into the carb and blocking this hole, so fit an inline fuel filter if you don't already have one.
skeverd
PostPosted: 18:09 - 29 Sep 2010    Post subject: Reply with quote
Yea, thats a good point, however currently pre mixing the bike for first tankful, just for easier access whilst tinkering with it.
Urm, there is rust in the tank, however i also did clean the carb beforehand with plenty of carb cleaner. I suppose i should do this again at some point, and put a filter in also.
the pilot screw does change the idle though... but its worth a shot. als, this air escaping from the nipple on the carb is concerning me now.
thinking back i remember looking down the reed valve and noticing one of the fins was bent ever-so slightly to the point where there was a small gap? is this a big problem? is there a way i could straighten it?
27cows
PostPosted: 21:26 - 29 Sep 2010    Post subject: Reply with quote
So you're premixing the bike and presumably there's no pipe on the oil intake stub. Could well be the problem.
Unlikely a slightly bent reed petal would cause this problem. I always use the Hy Tech fibre ones myself, though.
skeverd
PostPosted: 21:48 - 29 Sep 2010    Post subject: Reply with quote
Which nipple does the oil feed pipe go to n the carb? is it the one nearest the oil pump on the right hand side just above the float chamber?
i could see why this may be a problem - does the engine have a vacuum effect on the oil feed pipe as well as the pump delivering oil? as I suppose this would mean its effectively an air leak?
27cows
PostPosted: 21:54 - 29 Sep 2010    Post subject: Reply with quote
Yes on both counts. I've never run an RXS premixed or without the oil pipe in place, but I would imagine this is the problem.
skeverd
PostPosted: 22:26 - 29 Sep 2010    Post subject: Reply with quote
Surprised Then your a genious! It seems the most logical problem, thanks! Very Happy
I shall sort it tomorrow and report if its solved the situation.
Another note, the oil pump is set so the end of the cable is in line with the little pin thing on the pump body right?
27cows
PostPosted: 08:51 - 30 Sep 2010    Post subject: Reply with quote
Yep, there's a little circular punch mark on the pump wheel and that has to be lined up with the pin with the throttle fully closed.
skeverd
PostPosted: 13:10 - 30 Sep 2010    Post subject: Reply with quote
So ive found that by placing my finger over the oil inlet on the carb does enable the engine to idle finally Surprised Thanks again Very Happy
However the rpm still take a rather long time to die back down?
and the clutch is still failing to have any sort of slip in it. (by slip i mean it cannot partially engage, its either not engaging - or fully engaging) no matter how slow you release its it still effectively dumping it. Confused
The last post was made 16 years, 8 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.15 Sec - Server Load: 0.67 - MySQL Queries: 13 - Page Size: 130.76 Kb
