| skeverd |
 skeverd Borekit Bruiser
 ..... Quote Me Happy
| skeverd |
| chris-red |
| skeverd |
 Posted: 22:49 - 27 Sep 2010 Post subject: |
'Just' a pod filter? i thought these hip nd withit people add those on? nah, just the standard airbox, i want to keep it original, i want it to be a reliable bike - i figured keeping it as close to standard would help me with that? |
| skeverd |
 Posted: 20:04 - 28 Sep 2010 Post subject: |
well its running =D only now it wont idle - and revs take so long to go down also
on the other hand twist grip returns
any idea on the 2 problems stated? |
| Carvel |
 Carvel World Chat Champion
| skeverd |
| MarJay |
 MarJay But it's British!
| SpannerMonkey |
 SpannerMonkey World Chat Champion
| skeverd |
 Posted: 22:26 - 28 Sep 2010 Post subject: |
haha, yea, this infact was the problem, though i already rectified it
but yea, now i just have the inability to idle and the revs not settling...  |
| SpannerMonkey |
| skeverd |
 Posted: 23:02 - 28 Sep 2010 Post subject: |
no i havnt changed the plug, but it seems fine atm.
Another problem, the clutch seems to be either enguaged or not engaged - theres no in-between! this seems to be a problem with the whole starting thing...
Not sure if its normal, but when i kick the engine over without the ignition on, i can feel air coming out of some sort of nipple on the carb? right hand side... |
| cb1rocket |
 cb1rocket World Chat Champion
| 27cows |
 27cows World Chat Champion
 Posted: 14:00 - 29 Sep 2010 Post subject: |
Idle screw should be around 1 1/4 turns out. 2 1/2 is way too much.
Non-returning throttle could be caused by the twist grip being pushed too far onto the bar, or because the inner plastic is damaged or chafing at the end of the bar, or because the cable isn't routed correctly. Small possibility of the throttle slide being round the wrong way but that normally results in hysterical high revs as soon the motor fires up.
You shouldn't have air coming out of the carb when turning over the motor, I don't think Have you got the various pipes on the right places?
Making an RXS run anything but nicely actually takes a bit of doing in my experience, so look for something pretty obvious  ____________________ The RXS100: vehicle of choice for Chuck Norris |
| skeverd |
| Carvel |
| Robby |
 Robby Dirty Old Man
| skeverd |
| 27cows |
| skeverd |
| 27cows |
| skeverd |
 Posted: 22:26 - 29 Sep 2010 Post subject: |
Then your a genious! It seems the most logical problem, thanks!
I shall sort it tomorrow and report if its solved the situation.
Another note, the oil pump is set so the end of the cable is in line with the little pin thing on the pump body right? |
| 27cows |
| skeverd |
 Posted: 13:10 - 30 Sep 2010 Post subject: |
So ive found that by placing my finger over the oil inlet on the carb does enable the engine to idle finally Thanks again
However the rpm still take a rather long time to die back down?
and the clutch is still failing to have any sort of slip in it. (by slip i mean it cannot partially engage, its either not engaging - or fully engaging) no matter how slow you release its it still effectively dumping it.  |
The last post was made 16 years, 11 days ago. Instead of replying here, would creating a new thread be more useful? |
