Bike trailer modification
Gazdaman
I did a trackday!!!
PostPosted: 19:00 - 27 Sep 2010    Post subject: Bike trailer modification Reply with quote
So I picked up this beasty recently, swapped for an iPod touch, got to drag my MX bike around since it's not road legal.
https://www.gaz-racing.co.uk/images/vehicle_1178.JPG
A nice simple design, has leaf spring suspension and plenty of tie down points. Excellent. The only thing that worried me slightly was the gap in between where the front and rear wheels sit. How the hell are you supposed to load the bike?
Anyway, the guy who I bought it off provided me with a big chunk of box section to weld in the gap.
But I when I actually tried loading my KX125 onto it, the wheel wells are a bit far apart, and would only really suit a bike with a longer wheelbase. So my mate Dave and I decided we'd do a bit more modification. So we cut the back plate off the front wheel well, and the tube behind it deciding to fabricate a U section.
https://www.gaz-racing.co.uk/images/vehicle_1180.JPG
Section cut off.
https://www.gaz-racing.co.uk/images/vehicle_1181.JPG
The basis of the new 'U' shaped section behind the front wheel well. Two bits of angle iron, a floor was added afterwards from a piece of sheet steel.
https://www.gaz-racing.co.uk/images/vehicle_1183.JPG
And there it is finished.
The large piece of box section is nicely parallel to the sides of the trailer. But sadly it shows up that everything else is on the piss.
The proof was in the pudding, when I tried to load the KX125 onto the trailer earlier on it took two of us, and we had to pretty much carry it on.
After the modifications, I managed to load the heavier Husqvarna alone. Lovely.
https://www.gaz-racing.co.uk/images/vehicle_1184.JPG
My first go at welding, I was shockingly poor, but getting better.
Gaz
CarlosCBR
PostPosted: 10:18 - 28 Sep 2010    Post subject: Reply with quote
Doesnt look too sturdy. Let us know how it holds up.
Gazdaman
I did a trackday!!!
PostPosted: 12:15 - 28 Sep 2010    Post subject: Reply with quote
It's amazingly sturdy, it weighs about the same as the Severn bridge too.
Tows ok too, bit arsey when it's unladen but that should calm down when it's got some weight on it.
Gaz
delvey91
PostPosted: 17:08 - 28 Sep 2010    Post subject: Reply with quote
No thought has gone into that design at all Laughing
Axle should be much further back or the drawbar should of been extended and the bed moved forwards, I wouldnt trust anything on it
Gazdaman
I did a trackday!!!
PostPosted: 17:10 - 28 Sep 2010    Post subject: Reply with quote
I agree that it is the weirdest design that there ever was! I can't see who the hell makes a bike trailer in the first place that you can't roll a bike onto.
It just seems mental.
Either way, it works pretty well now. And I've still got an angle grinder and a MIG welder should I want to change anything.
Gaz
growler
PostPosted: 17:29 - 28 Sep 2010    Post subject: Reply with quote
that axle needs moving back so the weight of the load is at least balanced better to be front heavy or you run the risk of hitting a pot hole and the hitch letting go!!!!!!
DILLIGAF
mad4it028
PostPosted: 17:48 - 28 Sep 2010    Post subject: Reply with quote
mate that is dangours
1st the axle is too far forward so the weight of the bike is in mid air you should beable to disconect the trailor and wheel it about with a bike on it should balence like a see saw
2nd thats really not how to strap a bike on for 1 it will ruin your seat
2 straps 1 each side from bars to ancer points i normally put 2 on back too but never over the seat
621andy
PostPosted: 17:49 - 28 Sep 2010    Post subject: Reply with quote
Looks a bloody death trap Shocked
Try sticking the towbar on the other end of the trailer Wink
The nose weight must be -50kg!
'93 Africa Twin RD07, C-90,MTX-125,H-100,XL-125, a 125UAG(CG copy!)
Gazdaman
I did a trackday!!!
PostPosted: 17:56 - 28 Sep 2010    Post subject: Reply with quote
I'll likely be whipping the axle off in the coming weeks to give everything a proper paint and change the tyres. So there's always the option to just grind the leaf spring mounts off and move them back to a more suitable position.
And it was only strapped down for the photo. I normally an R&G handlebar strap, the one each side of the subframe, and one over the seat for good measure.
Gaz
robs321
PostPosted: 19:00 - 28 Sep 2010    Post subject: Reply with quote
Just a quick heads up, if your van has commercial insurance I would check that it allows towing a trailer, most dont and they want extra bucks for the privilege.
Gazdaman
I did a trackday!!!
Not my van, the trailer was only popped on there to support it while we loaded the bike.
But I didn't know that, so I've learnt something today.
Gaz
Gazdaman
I did a trackday!!!
PostPosted: 19:05 - 28 Sep 2010    Post subject: Reply with quote
So I figure I'll move the axle back about 18"-2'.
It's only a weld at each end of each leaf spring, so shouldn't cause too many problems.
I ordered two new tyres and tubes today too. So once that's done I could do with fabricating some way of afixing my light board to the back and maybe a way of hooking up the ramp.
That'll be a job for next week.
Gaz
Hockeystorm65
PostPosted: 19:52 - 28 Sep 2010    Post subject: Reply with quote
I have actually seen one like that before but what yours is missing is a plywood 'deck with two holes cut in it for the wheels to drop through into the steel channels. The tie down points on the other one were deck lugs that screwed through into the steel mounting points in the frame. They effectively held the deck on to the trailer. I think the point of that design was to make the trailer more multi purpose when it was not transporting bikes. Confused
Good judgement comes from experience.....experience comes from bad judgement!
Gazdaman
I did a trackday!!!
PostPosted: 22:45 - 28 Sep 2010    Post subject: Reply with quote
Ah that makes sense. Thanks for that Thumbs Up
So it's now both uglier and less practical! Excellent.
Hockeystorm65
PostPosted: 23:39 - 28 Sep 2010    Post subject: Reply with quote
...not uglier...just 'personalised'
Sorry to further add to the frustration with this, but that is probably also why it has an asymetric axle. If the deck is plywood sheet or steel mesh then it provides it's own ramp for getting the bike on to it and tied down.. Quite a dinky design really! Laughing
SamJL
PostPosted: 23:49 - 28 Sep 2010    Post subject: Reply with quote
I agree, the axle is far to far forward!
I have a similar design, at over 50mph it gets very very unstable, and tends to fishtail down the road. I had to cut and weld the axle as it was so bad.
I suggest doing the same, mine got that bad once, I had 2 bikes on it, and 1 of them snapped the straps and got dragged down the road by its handlebars, made quite a mess! Mine is a 3 bike trailer, and with 3 bikes on it, it was an absolute death trap before I adjusted the axle. It was still pretty bad with 1 bike on it. Seriously scary when your going down the motorway, and suddenly the back of the car is all over the place!
2009 CBR1000RR
2004 KTM 200SX
2004 KTM 65SX Very Happy
Gazdaman
I did a trackday!!!
PostPosted: 13:49 - 29 Sep 2010    Post subject: Reply with quote
Yeah this seemed to tow fine, and from past experience, unladen trailers aren't too keen at the best of times. But this sat at 60 without any troubles. It did resonate slightly and bounced up and down a little bit, but certainly no fish tailing.
I wonder if my welding skills are up to relocating the axle, load bearing weld etc.
Gaz
Hockeystorm65
PostPosted: 21:51 - 29 Sep 2010    Post subject: Reply with quote
Gaz
...you don't need to change the axle position?...that forms the ramp. If there is no fishtailing and the trailer is stable I would try it loaded and if OK leave as is.
Gazdaman
I did a trackday!!!
PostPosted: 22:19 - 29 Sep 2010    Post subject: Reply with quote
I certainly would like to leave it as it is! But I was reading some websites and it says the axle should be about 60/40 towards the back of the load bed.
And as a poster listed above, it would make the nose weight of the trailer a negative I would think. Not by a lot but still not ideal. But then again, I do have a big heavy car, and a single motorbike.
Maybe I'll try it and see if it's ok without moving it.
It doesn't seem particularly difficult, but I would worry slightly about my welding skills.
Gaz
SamJL
PostPosted: 22:25 - 29 Sep 2010    Post subject: Reply with quote
My trailer with a similar design is perfect with no bikes on it.
It's as soon as it gets weight on it, it all goes to the back of the trailer, and it gets very very unstable. Towed with a Range Rover, and still unstable.
I really would move the axle back!
2009 CBR1000RR
2004 KTM 200SX
sickpup
Old Timer
PostPosted: 01:54 - 30 Sep 2010    Post subject: Reply with quote
Gaz
Regardless you could well be prosecuted for carrying an unsafe load.
You need a front wheel stop and support or the bike can move and will move in the event of an accident or emergency stop not to mention the nose wight problem.
Gazdaman
I did a trackday!!!
PostPosted: 11:44 - 30 Sep 2010    Post subject: Reply with quote
sickpup wrote:
Gaz
Both wheels are sat in quite deep wells. I may weld a stop in front of the front well but its certainly more than secure when tied down properly. The rear wheel is held on both sides of it.
Ideally inn the future i may cut out the entire central part of the trailer, fit a single channel down the middle and fit one of those front wheel anchoring devices that you roll over.
But for the time being, this is more than capable.
Gazdaman
I did a trackday!!!
PostPosted: 18:35 - 30 Sep 2010    Post subject: Reply with quote
warped one wrote:
Now that I like! Any chance of mates (since he's your mate) rates?
I did some chopping and welding of the axle today.
Except by that I mean, I tried to cut the lugs off, found that my angle grinder couldn't reach all the areas it needed to cut. So I welded back up the cuts I made.
The only progress I made is that I replaced both tyres and inner tubes.
So now, if I'm going to relocate the axle, I'll either need to fabricate new mounts, or buy a bigger angle grinder to cut these mounts off.
Fabrication is winning atm, then I eliminate the risk of destroying them when removing them too.
Gaz
Pedd
PostPosted: 20:23 - 30 Sep 2010    Post subject: Reply with quote
why not just cut off the towing hitch bar and put it on the other end of the trailer, alot easier than faffing about shifting the axel.
Dont Click HERE
Current modes of transport = 125 superdream (in bits atm), 1978 GS750 chop, bandit 600(main one), 1982 bmw r100rs,
cx500 trike (hey its fun) oh and the car to ferry the missus and dogs around Smile
The last post was made 15 years, 349 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.12 Sec - Server Load: 0.59 - MySQL Queries: 13 - Page Size: 135.61 Kb
