| Gazdaman |
 Gazdaman I did a trackday!!!
 Posted: 19:00 - 27 Sep 2010 Post subject: Bike trailer modification |
So I picked up this beasty recently, swapped for an iPod touch, got to drag my MX bike around since it's not road legal.
https://www.gaz-racing.co.uk/images/vehicle_1178.JPG
A nice simple design, has leaf spring suspension and plenty of tie down points. Excellent. The only thing that worried me slightly was the gap in between where the front and rear wheels sit. How the hell are you supposed to load the bike?
Anyway, the guy who I bought it off provided me with a big chunk of box section to weld in the gap.
But I when I actually tried loading my KX125 onto it, the wheel wells are a bit far apart, and would only really suit a bike with a longer wheelbase. So my mate Dave and I decided we'd do a bit more modification. So we cut the back plate off the front wheel well, and the tube behind it deciding to fabricate a U section.
https://www.gaz-racing.co.uk/images/vehicle_1180.JPG
Section cut off.
https://www.gaz-racing.co.uk/images/vehicle_1181.JPG
The basis of the new 'U' shaped section behind the front wheel well. Two bits of angle iron, a floor was added afterwards from a piece of sheet steel.
https://www.gaz-racing.co.uk/images/vehicle_1183.JPG
And there it is finished.
The large piece of box section is nicely parallel to the sides of the trailer. But sadly it shows up that everything else is on the piss.
The proof was in the pudding, when I tried to load the KX125 onto the trailer earlier on it took two of us, and we had to pretty much carry it on.
After the modifications, I managed to load the heavier Husqvarna alone. Lovely.
https://www.gaz-racing.co.uk/images/vehicle_1184.JPG
My first go at welding, I was shockingly poor, but getting better.
Gaz |
| CarlosCBR |
 CarlosCBR World Chat Champion
 Posted: 10:18 - 28 Sep 2010 Post subject: |
| Gazdaman |
| delvey91 |
 delvey91 Crazy Courier
 Posted: 17:08 - 28 Sep 2010 Post subject: |
No thought has gone into that design at all
Axle should be much further back or the drawbar should of been extended and the bed moved forwards, I wouldnt trust anything on it |
| Gazdaman |
| growler |
 growler Traffic Copper
| mad4it028 |
 mad4it028 World Chat Champion
| 621andy |
 621andy Scooby Slapper
 Posted: 17:49 - 28 Sep 2010 Post subject: |
Looks a bloody death trap
Try sticking the towbar on the other end of the trailer
The nose weight must be -50kg! ____________________ '93 Africa Twin RD07, C-90,MTX-125,H-100,XL-125, a 125UAG(CG copy!) |
| Gazdaman |
| robs321 |
 robs321 Could Be A Chat Bot
| Gazdaman |
| Gazdaman |
| Hockeystorm65 |
 Hockeystorm65 Spanner Monkey
 Posted: 19:52 - 28 Sep 2010 Post subject: |
I have actually seen one like that before but what yours is missing is a plywood 'deck with two holes cut in it for the wheels to drop through into the steel channels. The tie down points on the other one were deck lugs that screwed through into the steel mounting points in the frame. They effectively held the deck on to the trailer. I think the point of that design was to make the trailer more multi purpose when it was not transporting bikes.  ____________________ Good judgement comes from experience.....experience comes from bad judgement! |
| Gazdaman |
| Hockeystorm65 |
 Posted: 23:39 - 28 Sep 2010 Post subject: |
...not uglier...just 'personalised'
Sorry to further add to the frustration with this, but that is probably also why it has an asymetric axle. If the deck is plywood sheet or steel mesh then it provides it's own ramp for getting the bike on to it and tied down.. Quite a dinky design really!  ____________________ Good judgement comes from experience.....experience comes from bad judgement! |
| SamJL |
 SamJL Nearly there...
 Posted: 23:49 - 28 Sep 2010 Post subject: |
I agree, the axle is far to far forward!
I have a similar design, at over 50mph it gets very very unstable, and tends to fishtail down the road. I had to cut and weld the axle as it was so bad.
I suggest doing the same, mine got that bad once, I had 2 bikes on it, and 1 of them snapped the straps and got dragged down the road by its handlebars, made quite a mess! Mine is a 3 bike trailer, and with 3 bikes on it, it was an absolute death trap before I adjusted the axle. It was still pretty bad with 1 bike on it. Seriously scary when your going down the motorway, and suddenly the back of the car is all over the place! ____________________ 2009 CBR1000RR
2004 KTM 200SX
2004 KTM 65SX  |
| Gazdaman |
| Hockeystorm65 |
| Gazdaman |
| SamJL |
 Posted: 22:25 - 29 Sep 2010 Post subject: |
My trailer with a similar design is perfect with no bikes on it.
It's as soon as it gets weight on it, it all goes to the back of the trailer, and it gets very very unstable. Towed with a Range Rover, and still unstable.
I really would move the axle back! ____________________ 2009 CBR1000RR
2004 KTM 200SX
2004 KTM 65SX  |
| sickpup |
 sickpup Old Timer
| Gazdaman |
| warped one |
 warped one Banned
| Gazdaman |
 Posted: 18:35 - 30 Sep 2010 Post subject: |
Now that I like! Any chance of mates (since he's your mate) rates?
I did some chopping and welding of the axle today.
Except by that I mean, I tried to cut the lugs off, found that my angle grinder couldn't reach all the areas it needed to cut. So I welded back up the cuts I made.
The only progress I made is that I replaced both tyres and inner tubes.
So now, if I'm going to relocate the axle, I'll either need to fabricate new mounts, or buy a bigger angle grinder to cut these mounts off.
Fabrication is winning atm, then I eliminate the risk of destroying them when removing them too.
Gaz |
| Pedd |
 Pedd World Chat Champion
 Posted: 20:23 - 30 Sep 2010 Post subject: |
why not just cut off the towing hitch bar and put it on the other end of the trailer, alot easier than faffing about shifting the axel. ____________________ Dont Click HERE
Current modes of transport = 125 superdream (in bits atm), 1978 GS750 chop, bandit 600(main one), 1982 bmw r100rs,
cx500 trike (hey its fun) oh and the car to ferry the missus and dogs around  |
The last post was made 15 years, 347 days ago. Instead of replying here, would creating a new thread be more useful? |
