Sealing chemical metal (engine cover)
Misc
PostPosted: 18:40 - 28 Sep 2010    Post subject: Sealing chemical metal (engine cover) Reply with quote
Evening,
Patched up an engine cover with Chemical metal & it's done a good job but oil is now starting to soak through, it's not leaking yet tho. Going to take the cover off again but wanting some sort of oil sealant that can withstand the heat. Will apply this over the chemical metal (hopefully)
Any ideas?
Thanks.
Itchy
PostPosted: 18:45 - 28 Sep 2010    Post subject: Reply with quote
Why don't you look for a used one on ebay or davidsilvers or something? If it doesn't hold first time then second time is doubtful. My CBer engine cover was £13 on evilbay. Don't forget £4 for a gasket too.
Misc
PostPosted: 18:57 - 28 Sep 2010    Post subject: Reply with quote
What do you mean by hold? The chemical metal is holding fine, the oil isn't getting through cracks or gaps, just seems to be soaking through.
I've looked a few times for a new cover but prices don't seem to drop below £40, or there's not the side i need.
£13 sounds like a good deal, will keep a look out.
PostPosted: 18:58 - 28 Sep 2010    Post subject: Reply with quote
Not all chemical metals are the same.
JB weld is one of the best.
They used to paint the inside of alloy crankcases with heat resistant enamel paint on some older brit bikes because the alloy was pourous. This would probably work in what you're doing too.
Not sure what modern oilways would make of it if any flaked off though.
You will have great difficulty in getting anything to bond to porous chemical metal soaked in oil. I'd suggest taking it off, degreasing and starting from scratch.
If it's a small hole, you could also put a nut and bolt through it (providing it doesn't foul any moving parts on the inside) with o-rings either side.
Misc
PostPosted: 19:03 - 28 Sep 2010    Post subject: Reply with quote
Interesting, will have a look for this stuff, thanks. Will the old stuff be easy enough to chip away?
Here's the damage (before) it's more of a slit.
https://img101.imageshack.us/img101/9871/dsc00208zu.jpg
Walloper
PostPosted: 19:26 - 28 Sep 2010    Post subject: Reply with quote
Araldite have a metal based glue which works well.#
But JB Weld is a known winner.
You need to ensure the area is completely free of any grease/oil.
Use paint thinners to dry it off. before putting the glue on.
Lean the bike over so the oil can't reach the repair.
Rough up the area to provide a 'key' for the glue to lock into.
Most glues rely on mechanical properties to bond.
It hooks into microscopic surface imperfections between parts.
(Some glues melt the base material and weld on.)
Misc
PostPosted: 20:21 - 28 Sep 2010    Post subject: Reply with quote
Brilliant, thanks.
I'll give this a go. Got a gasket lying around so i might get the glue tomorrow.
Thanks guys.
PostPosted: 20:54 - 28 Sep 2010    Post subject: Reply with quote
It may be worthwhile glueing something over the top of it using the chemical metal. Glues work best at sticking one thing to another rather than just sitting on top of one surface. A wee bit of alloy plate cut and bent to shape for example.
Or you could get it welded.
Another option is lumiweld low temperature aluminium solder, also a permanant fix.
As has been said, degreasing is essential. I use brake cleaner to degrease metal prior to glueing.
Mind you. That a bandit? £50 will get you a pattern engine cover if it is. People are always crashing bandits.
Misc
PostPosted: 21:24 - 28 Sep 2010    Post subject: Reply with quote
Thanks again, excellent info. Smile
(Yup, it's a Bandit. Not keeping it long so don't want to spend out on it really).
ZRX61
Victor Meldrew
PostPosted: 08:24 - 29 Sep 2010    Post subject: Reply with quote
Glyptol. Wink
Casper
PostPosted: 11:29 - 29 Sep 2010    Post subject: Reply with quote
Is that the bandit/teapot gsx engine? Lots of them in brakers. Also join this forum https://forum.oldskoolsuzuki.info/cgi-bin/Yabb/YaBB.pl as there are lots of these engines getting broken for parts as lots of projects being built.
Robby
Dirty Old Man
PostPosted: 12:53 - 29 Sep 2010    Post subject: Reply with quote
For the sake of £50 just change the part. If you're not planning on keeping it long then you'll need to change the part to sell it, no one is going to buy a bike with a crankcase cover held together chemical metal soaked in oil.
evoboy
PostPosted: 13:10 - 29 Sep 2010    Post subject: Reply with quote
Araldite wont let oil through.
Ive used it on the inside of the genny cover on my zx6 after it was worn down till the metal was porus.
Not been a problem in 20k miles.
APT Motorcycles
Gazdaman
I did a trackday!!!
PostPosted: 13:51 - 29 Sep 2010    Post subject: Reply with quote
I bet you could get a solid second hand one of those for a tenner. I went through a couple of those when I had a Bandit.
Gaz
Misc
PostPosted: 18:16 - 29 Sep 2010    Post subject: Reply with quote
Will give this a look, thanks.
£50 is a lot for the price it'll probably be going for. It's not going to be chemical metal soaked in oil, hence this thread. Wink
Will have a read up on this also. Thanks.
Gaz
Doesn't seem like there's any on ebay at the moment (decent used prices) will keep an eye on the forums.
The last post was made 15 years, 343 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.27 - MySQL Queries: 13 - Page Size: 89.77 Kb
