yamaha fazer 2002 gearbox
carl_easykart
PostPosted: 17:56 - 26 Sep 2010    Post subject: yamaha fazer 2002 gearbox Reply with quote
hello everyone i picked up my first bike friday got a yamaha fazer i love it but its just the gearbox its realy clonky in first and second gear.. i have read up on this and its normal for the fazers to clonk in first and second but im seeing what all your thoughts are...
somtimes its that clonky it feels like i have not used the clutch and it just being forced into gear. the bike has warranty but i just like to know if this is normal?
thanks carl
carl_easykart
PostPosted: 18:18 - 26 Sep 2010    Post subject: Reply with quote
thanks chris i just need to get used to it i think then, sometimes it changes gears perfect then the next time its a big clonk.
will try and change gear fast like you said next time..
apart from this im loving the bike.
thank you
PostPosted: 19:15 - 26 Sep 2010    Post subject: Re: yamaha fazer 2002 gearbox Reply with quote
thanks carl
I've found with the bikes I've had that have done this that chain tension is usually a factor. If the chain tension is bang on or slightly loose it helps. If the chain is a little tight, it can make the problem worse.
Check your chain tension, and if its bang on then "They all do that, sir".
0l0dom0l0
PostPosted: 23:00 - 26 Sep 2010    Post subject: Reply with quote
i was asking the same question when i first got on my fazer. basically, its normal.
have your cluth lever slightly loose, i found that helped a little!
carl_easykart
PostPosted: 07:51 - 27 Sep 2010    Post subject: Reply with quote
thank you marjay will check my chain..
thanks everyone for the replys glad its just normal..
carl
garth
PostPosted: 13:32 - 27 Sep 2010    Post subject: Reply with quote
Fazer boxes aren't the best. I've however found short shifting 1st to 2nd helps, I find mine is a bit notchy 2nd to 3rd though. Meh! You'll never break it.
Balancing my carbs and sorting my exhaust leak helped the low rev pickup, which in turn helped my gearbox.
Good bikes though!
0l0dom0l0
PostPosted: 14:01 - 27 Sep 2010    Post subject: Reply with quote
Good bikes though!
Yeah, if you change it before about 4k its fine, after that its not great at times!
fazers are fantastic, shame mine is restricted Sad. it sucks big time
angryjonny
PostPosted: 14:21 - 27 Sep 2010    Post subject: Reply with quote
Mine was similar. It used to slip out of 2nd occasionally, under heavy acceleration too. Don't know where it went because it didn't end up in neutral. Just another neutral somewhere. Still shifted up into 3rd.
PostPosted: 14:32 - 27 Sep 2010    Post subject: Reply with quote
It'a a Yamaha thing, my TDM is the same.
TUG
PostPosted: 17:10 - 27 Sep 2010    Post subject: Re: yamaha fazer 2002 gearbox Reply with quote
thanks carl
This is normal for straight cut gears. Almost every bike does it.
Haz ER-5, innit!
PostPosted: 17:17 - 27 Sep 2010    Post subject: Re: yamaha fazer 2002 gearbox Reply with quote
thanks carl
I have found in the bikes I have ridden that Yamahas are worse than most for this though.
TUG
PostPosted: 17:29 - 27 Sep 2010    Post subject: Reply with quote
My honda is just as bad as the yams. makes no difference if it clunks or not. BMW's dont tend to so it with cross cut gears.
Haz ER-5, innit!
carl_easykart
PostPosted: 19:55 - 27 Sep 2010    Post subject: Reply with quote
thanks everyone.. feel better now.
one more question does my bike have fuel reserve tank if so where do i swop this over?
thanks carl
carl_easykart
PostPosted: 07:48 - 28 Sep 2010    Post subject: Reply with quote
thanks chris.
just i read on the net that when the light comes on that means put it over to reserve.
carl
TUG
PostPosted: 19:29 - 28 Sep 2010    Post subject: Reply with quote
CHR15 wrote:
there is no reserve function.
when the light comes on find a petrol station... quickly.
And when your friend has been told before you set off he "Must take the short way round and i need fuel!" he won't listen to just hit a station when u can pronto.
He knows who he is, PIEMON Laughing
Haz ER-5, innit!
The last post was made 16 years ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 0.55 - MySQL Queries: 13 - Page Size: 89.94 Kb
