NS125f Performance issues
SpannerMonkey
PostPosted: 00:24 - 30 Sep 2010    Post subject: NS125f Performance issues Reply with quote
Currently riding an NS125f at the moment and It's pretty apparent that while to me it feels like a missile (Not used to anything capable of over 65mph) it's definately restricted. I remember seeing elsewhere a post from Kickstart (on visordown I believe?)
And the content was basically that the ATAC system and anything relating to its existence VANISHED. The airbox is shite... the standard pipe again... is shite (Luckily I have a Micron) and lastly the CDI is about as much use as multi-use toilet roll
Am I missing anything here? I'm not going to fish about for the full power parts but I might find me a compatible CDI and a good second hand air-filter with suitable jets.
SpannerMonkey
PostPosted: 18:06 - 30 Sep 2010    Post subject: Reply with quote
Anyone?
PostPosted: 18:11 - 30 Sep 2010    Post subject: Reply with quote
Airbox wasn't part of the any restriction, just seemed to be a poor design and one where people did get half decent gains from a single filter.
Not aware of any ignition restriction.
The real restriction was just in the exhaust, and with a Micron you should have that solved.
The ATAC operating system is missing, but not a major issue. For high revs the chamber should be closed, so you can blank it off if you want. However on the NS I have been told it is blanked off as standard (wasn't on the older MBX125 engine).
SpannerMonkey
PostPosted: 18:17 - 30 Sep 2010    Post subject: Reply with quote
So this is as good as it gets? =/ bar an air filter?
I seem to recall hearing they can be capable of a good 90mph. Mine seems capable of 80 pushing it on the flat
PostPosted: 18:30 - 30 Sep 2010    Post subject: Reply with quote
Real top speed restricted was in the low 70s, with rather more on the speedo. Didn't take much to get them indicating a lot more than 80.
Is the Micron damaged? Has the jetting been played with? Has someone opened up the ATAC chamber? Is compression reasonable?
SpannerMonkey
PostPosted: 18:39 - 30 Sep 2010    Post subject: Reply with quote
The only damage on the micron is that the end can is corroded... Litterally right at the end where the curved pipe comes out of the silencer
Jetting may well have been played with but not by me. I havent found any carb settings so I dont know whats standard and what's not.
How do i tell if someone has opened up the ATAC chamber? I have no experience or knowledge of the ATAC system.
I havent actually tested the compressin but I'll get right on and check it tomorrow
PostPosted: 18:49 - 30 Sep 2010    Post subject: Reply with quote
Exhaust should be fine then (assuming it isn't seriously coked up).
ATAC chamber is cast into the barrel and head. It should be closed off at high rpm, but UK ones didn't have a mechanism to open / close it. However I have been told they were closed on UK spec ones, so possible someone has opened it up. Without crawling over it not sure what the easiest way to check is, but wouldn't expect a massive difference either way.
Workshop manual lists it as a 110 main jet. Make the mixture too rich and you lose power (make it too lean and you seize the engine).
SpannerMonkey
PostPosted: 18:55 - 30 Sep 2010    Post subject: Reply with quote
Well it feels a little more powerful if I ease off the throttle a tiny bit. and sometimes bogs if I snap open the throttle quickly.
Do you have a copy of the manual available for email? or is it in paper form?
PostPosted: 19:00 - 30 Sep 2010    Post subject: Reply with quote
It is a slide carb and they do not work well if you just ram the throttle open wide. Open it progressively with the revs.
However that it gains power when the throttle is backed off does suggest the jetting is a bit off on full throttle.
stirlinggaz
PostPosted: 19:44 - 30 Sep 2010    Post subject: Reply with quote
hi,
you would be able to tell easilly if the atac had been messed with.
theres 2 blanking cap on side casing & side of cylinder at 90degs to each other., about size of 10p, thats where the atac mechanism (it looks like a thin rod coming out of cylinder & connects to a little lever coming out from gearbox/oil pump drive) would be on the foriegn bikes.
these would need to be drilled open to fit in the atac assembly & its financially not viable. (trust me on that,lol)
the herp chamber (iirc) is the pipe shaped thing on top of cylinder, make sure the little phillips screw is still there & the pipe is tight.
mines used to indicate 90mph with changed sprockets, open air filter & micron.
de-coking makes a huge difference, as does good compression!
might just be needing new rings?
cheers,
GAZ
ps im thinking that you have the standard sized main jet & this needs to be changed?
have you done a plug chop?
SpannerMonkey
PostPosted: 00:15 - 01 Oct 2010    Post subject: Reply with quote
stirlinggaz wrote:
hi,
cheers,
GAZ
I havent done a plug chop. The last plug varied between being dark tan to black and oily each time I took it out. Despite hearing lots about plug chops I have yet to find out how to actually do one haha
PostPosted: 09:48 - 01 Oct 2010    Post subject: Reply with quote
Plug colour will be largely down to the mixture at the revs it was last being used at, and it is quite possible for it to be lean at some revs / throttle positions and rich at others.
PostPosted: 10:25 - 01 Oct 2010    Post subject: Re: NS125f Performance issues Reply with quote
If you get a really long straight and max it out, what speed do you get?
SpannerMonkey
PostPosted: 13:18 - 01 Oct 2010    Post subject: Re: NS125f Performance issues Reply with quote
Well I havent had a MASSIVELY long straight... but it gets to 75 on the speedo, Slowly creeps to about 82... then creeps slower to 85 but by that point I'm at about 9800 revs and my power is dropping off sharply after the 10k mark
PostPosted: 14:36 - 01 Oct 2010    Post subject: Re: NS125f Performance issues Reply with quote
Think the best I had indicated on my NS125R was 88 and that was on an airfield (actually was Razz) lying flat.
So doesn't sounds like yours is too bad in that regards really.
PostPosted: 14:39 - 01 Oct 2010    Post subject: Re: NS125f Performance issues Reply with quote
I could get an indicated 90 out of mine, but I'm not sure that I ever wanted to... it would go into a slow weave at about 80.
PostPosted: 14:47 - 01 Oct 2010    Post subject: Reply with quote
Think an indicated 100 was pretty common (speedos were compulsive liars though).
For comparison my old MBX125 would just squeeze off the end of the speedo (last marking was 90mph, needle would get to were 92 would be). Never had it weaving though even when burried under luggage.
The last post was made 16 years, 7 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.10 Sec - Server Load: 0.42 - MySQL Queries: 13 - Page Size: 105.96 Kb
