| SpannerMonkey |
 SpannerMonkey World Chat Champion
| SpannerMonkey |
| Kickstart |
 Kickstart The Oracle
 Posted: 18:11 - 30 Sep 2010 Post subject: |
Airbox wasn't part of the any restriction, just seemed to be a poor design and one where people did get half decent gains from a single filter.
Not aware of any ignition restriction.
The real restriction was just in the exhaust, and with a Micron you should have that solved.
The ATAC operating system is missing, but not a major issue. For high revs the chamber should be closed, so you can blank it off if you want. However on the NS I have been told it is blanked off as standard (wasn't on the older MBX125 engine).
| SpannerMonkey |
| Kickstart |
| SpannerMonkey |
| Kickstart |
 Posted: 18:49 - 30 Sep 2010 Post subject: |
Exhaust should be fine then (assuming it isn't seriously coked up).
ATAC chamber is cast into the barrel and head. It should be closed off at high rpm, but UK ones didn't have a mechanism to open / close it. However I have been told they were closed on UK spec ones, so possible someone has opened it up. Without crawling over it not sure what the easiest way to check is, but wouldn't expect a massive difference either way.
Workshop manual lists it as a 110 main jet. Make the mixture too rich and you lose power (make it too lean and you seize the engine).
| SpannerMonkey |
| Kickstart |
| stirlinggaz |
 stirlinggaz World Chat Champion
| SpannerMonkey |
| N cee thirty |
 N cee thirty Banned
| Kickstart |
| G |
 G The Voice of Reason
| SpannerMonkey |
| G |
 Posted: 14:36 - 01 Oct 2010 Post subject: Re: NS125f Performance issues |
Think the best I had indicated on my NS125R was 88 and that was on an airfield (actually was ) lying flat.
So doesn't sounds like yours is too bad in that regards really. |
| MarJay |
 MarJay But it's British!
| Kickstart |
The last post was made 16 years, 8 days ago. Instead of replying here, would creating a new thread be more useful? |
