Suzuki GP100 compression figure?
cb1rocket
PostPosted: 22:21 - 24 Sep 2010    Post subject: Suzuki GP100 compression figure? Reply with quote
I'm getting the top end rebuilt on my little 2 stroker.
What should the workshop manual say for the compression figure in psi? Does anyone know cheers
hmmmnz
PostPosted: 13:29 - 25 Sep 2010    Post subject: Reply with quote
not sure but i was getting 120psi out of a A100 which i was surprised about,
if you do find the ratio,
times it by 14.7 that will give you a perfect world figure
eg say if your bike was 6.7:1 then the psi would be 98.49psi
realistically it will be alot lower, probably around 85psi
the humans are dead
I kick arse for the lord
cb1rocket
PostPosted: 13:29 - 01 Oct 2010    Post subject: Reply with quote
thanks mate
compression ratio is 9:1 so i take it that would 132.3 psi - sounds pretty low to me still! Was thinking something more like 150psi at least!
PostPosted: 14:05 - 01 Oct 2010    Post subject: Reply with quote
cb1rocket wrote:
thanks mate
KH125 was 124psi after a full rebuild.
Im sure the NSR is around 130ish.
132 sounds high for your machine...but if thats what hmmmnz says is a real world figure, its cool!
cb1rocket
PostPosted: 23:41 - 01 Oct 2010    Post subject: Reply with quote
well I haven't rebuilt the engine yet - still waiting from the reborers to come back with dimensions and costs to the barrell.
Just saw a clip on youtube for the suzuki gp100 compression test and someone has actually done a video of it showing about 140psi so the 133 psi sounds about right Very Happy
lets see what mine turns up to be.
Walloper
PostPosted: 09:30 - 02 Oct 2010    Post subject: Reply with quote
Do you need to oil the bore before testing?
hmmmnz
PostPosted: 11:05 - 02 Oct 2010    Post subject: Reply with quote
no, that would defeat the point Very Happy
when doing a compression test on a 4 stroke,
do a baseline test, if the compression is lower than expected,
put a wee squirt down the barrel, and if the compression rises a considerable amount, then rings are poked, if the compression stays low, then its valve seats that are the problem
the humans are dead
pepperami
PostPosted: 11:13 - 02 Oct 2010    Post subject: Reply with quote
I`ve learnt something today Thumbs Up
hmmmnz
PostPosted: 11:46 - 02 Oct 2010    Post subject: Reply with quote
arhh the joys aye Very Happy
glad i could be of assistance
the humans are dead
satelliteone
PostPosted: 14:51 - 02 Oct 2010    Post subject: Reply with quote
https://i31.photobucket.com/albums/c357/satelliteone/Suzuki%20GP100/IMGP1807.jpg
hope it helps
cb1rocket
PostPosted: 17:19 - 02 Oct 2010    Post subject: Reply with quote
thanks mate seems I got the compression ratio wrong! Thumbs Up
The last post was made 16 years, 7 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.67 - MySQL Queries: 13 - Page Size: 73.05 Kb
