DT125 x coolant dumping just after pulling wheelies
scott dt125 x
PostPosted: 21:19 - 28 Sep 2010    Post subject: DT125 x coolant dumping just after pulling wheelies Reply with quote
Has anybody got any ideas why its doing it its not a major problem i just wanna know why...... any help would be appreciated Smile
scott dt125 x
PostPosted: 12:01 - 02 Oct 2010    Post subject: coolant dumping Reply with quote
has nobody helped me with this problem and theres been like 50 veiws am i that much of a turd that nobody wants to help me ! Confused javascript:emoticon('Confused') and the bike is a dt125x
Paxovasa
PostPosted: 12:03 - 02 Oct 2010    Post subject: Reply with quote
Stop pulling wheelies Rolling Eyes Laughing
TUG
PostPosted: 13:02 - 02 Oct 2010    Post subject: Reply with quote
Its normal for coolant to spill out of the bottle, but if you mean u pull a wheelie then next think it pisses out then your probabaly letting air into your sytem some how, faulty rad cap maybe, my friends KTM keeps doing it.
Haz ER-5, innit!
Stowelly
PostPosted: 13:54 - 02 Oct 2010    Post subject: Reply with quote
surely that just means the coolant coming out of the overflow as its tipped back so far?
satelliteone
PostPosted: 14:52 - 02 Oct 2010    Post subject: Reply with quote
the cap has a spring loaded seal. Have u checked this?
scott dt125 x
PostPosted: 20:12 - 02 Oct 2010    Post subject: thanks Reply with quote
for the replys so quickly... it just comes out the overflow pipe at the bottom of the bike i thought it was to do with the bike being tipped back to im not sure i was just wondering if anyone else had experinced this problem it only does it when i start clutching up wheelies can anyone wheelie theres in second i can only do it in first Sad i want to be able to do it in second so i can have more gear to go along with Smile
PostPosted: 20:22 - 02 Oct 2010    Post subject: Re: thanks Reply with quote
Well since it only does it when you wheelie it's probably quite safe to assume it is to do with that.
scott dt125 x
PostPosted: 20:52 - 02 Oct 2010    Post subject: can Reply with quote
anybody give me some tips to tryn get it to come up in second please it mostly de restricted just needs the pipe changing and re jetting Smile im new to this that why i ask all the Yoda,s of biking Smile
Raffles
PostPosted: 21:18 - 02 Oct 2010    Post subject: Re: can Reply with quote
There's a guy on here that reckons that he can get it up in 3rd. I can't remember which forum member that it is but I seem to think that his name is Matt and that he is from somewhere in The UK.
stevo as b4
PostPosted: 23:29 - 02 Oct 2010    Post subject: Reply with quote
TBH if the only way a full power fully working YPVS DTX can wheelie in 1st is using the clutch then id think there is something wrong with it!
I'd suggest that clutching it in second should get it to wheelie fairly easily, but getting it up in first at slow speed and finding the balance point before clicking second should be easier.
satelliteone
PostPosted: 11:44 - 04 Oct 2010    Post subject: Reply with quote
my DTR wheelies up in 1st with out clutch. Mind u, i found it really easy when the monoshock was set to soft. The ass end used to dip alot and the front just came up.
Now i set the shock on the hardest setting, cause iam a fat git, it hates lifting the front. which for me is a lot better green lane-ing.
2nd gear it hopped on the front wheel quite well.. but i had a 17 tooth front sprocket. original gearing would of had the front wheel up.
MaybeGuy
PostPosted: 12:20 - 04 Oct 2010    Post subject: Re: can Reply with quote
reckons he can get it up? I made a video to prove it.
I can clutch my ktm 520 up in 6th gear
scott dt125 x
PostPosted: 09:18 - 05 Oct 2010    Post subject: hey.... Reply with quote
thanks for all the replys guys... lol it power wheelies in first but im more into clutch wheelies its just ive heard its easily done in second but my bike pops up a bit and then goes buuuuuurrrrr.... and drops back down but in first it will just stay there when i blip the throttle but id rather be doing it in second so it goes further with out it screaming like a cat which is being raped.... Smile
MaybeGuy
PostPosted: 09:27 - 05 Oct 2010    Post subject: Reply with quote
so it powers up in first, but you cant clutch up in 2nd, but claim to be clutching up in your earlier post.
i think someones trying to sound more awesome than they are but failing.
just learn to balance it, and if you cant, learn to change gear on 1 wheel
scott dt125 x
PostPosted: 06:40 - 06 Oct 2010    Post subject: it Reply with quote
will power wheelie in first but id rather use the clutch and its shit to do in second it pops up and drops :-/
scott dt125 x
PostPosted: 06:44 - 06 Oct 2010    Post subject: oh Reply with quote
@ matt can i have a link to that vid please Smile
MaybeGuy
PostPosted: 08:37 - 06 Oct 2010    Post subject: Reply with quote
no. mainly because vimeo deleted it, and i dont have the original file. find the thread though. just because most people cant do it on a 1000, me doing it on a 600 was impossible until proven Rolling Eyes
in 2nd if you're running out of revs before its up, you're going too fast, and if you're bogging down you're going too slowly.
i still think you should learn to do it properly in 1st first. i bet your one of these mugs you see hunched over the bars like the cretin you are. try it with your arms locked straight and dont be a fanny about it
TUG
PostPosted: 15:16 - 06 Oct 2010    Post subject: Reply with quote
Dont change gear mid wheelie, if you hit a false one, that shits gunna land harder than the twin towers and because you have no forward force if you wobble its game over.
Haz ER-5, innit!
MaybeGuy
PostPosted: 23:57 - 06 Oct 2010    Post subject: Reply with quote
ignore this clown
The last post was made 15 years, 331 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 0.47 - MySQL Queries: 13 - Page Size: 106.02 Kb
