Satnav - wired in
Moo.
PostPosted: 20:20 - 03 Oct 2010    Post subject: Satnav - wired in Reply with quote
Hey guys, i did a search but didnt find much.. basically is it possible to wire a car satnav to be powered off the bike? And will it be able to support the power drain?
And is it a simple case of wiring a lighter socket to it, and plugging it in?
Cheers guys Very Happy
A2 Passed 18/6/10
Faldo
PostPosted: 21:19 - 03 Oct 2010    Post subject: Re: Satnav - wired in Reply with quote
Yes, really simple to do. Buy something like this and you can do it in minutes. I bought a little waterproof box from Maplins and put two sockets into that then just screwed the box in underneath the seat, that way you don't need to go drilling holes in your panels and you can swap the socket(s) from bike to bike in seconds.
Phoenix
Twisted Firestarter
PostPosted: 00:16 - 04 Oct 2010    Post subject: Reply with quote
You only issue is that car sat navs are obviously not waterproof or weatherproof in any way. If you put it inside the clear top of a tank bag then it should be ok though, power drain for a sat nav is miniscule in comparison to other circuits on the bike so there would be no issues there whatsoever unless you left it plugged in overnight or for longer maybe.
2E
PostPosted: 10:31 - 04 Oct 2010    Post subject: Re: Satnav - wired in Reply with quote
I've got a weatherproof/waterproof twin socket one... it doesen't have a fuse... should it? Confused
Bringing Classic Bikes Back Into Fashion
Rides: 1980 Honda CX500
willis1337
PostPosted: 13:45 - 04 Oct 2010    Post subject: Reply with quote
If you have an optimate lead connected to the bike's battery you can get an acessory lead which can be plugged into it with a socket on the end.
DrDonnyBrago
PostPosted: 14:31 - 13 Oct 2010    Post subject: Reply with quote
I bought one of these in HG a few weeks ago:
https://www.hein-gericke.co.uk/shop/product_info.php/cPath/23_150_31/products_id/8434
Wire in a cigarette lighter socket and store the unit in one of these, keeps it water proof. Just strap it your bars with the velcro on the back and all is good Thumbs Up .
Phoenix
Twisted Firestarter
PostPosted: 17:41 - 13 Oct 2010    Post subject: Re: Satnav - wired in Reply with quote
Any wiring directly off the battery should be fused as close to the battery as possible to prevent wiring melting or catching fire should you suffer a short circuit somewhere along the wiring or at the socket. Any item you plug into the 12v socket will have it's own fuse but this doesn't protect the wiring from the battery to the socket.
barnhatter
PostPosted: 20:22 - 13 Oct 2010    Post subject: Reply with quote
Out of interest do car gps units have a socket for external speakers that I could connect to my bikes intercom/helmit speakers.
SirEdward
PostPosted: 21:08 - 13 Oct 2010    Post subject: Reply with quote
Nevermind. Very Happy
"Beyond a critical point within a finite space, freedom diminishes as numbers increase. This is as true of humans as it is of gas molecules in a sealed flask. The human question is not how many can possibly survive within the system, but what kind of existence is possible for those who so survive.
Pardot Kynes in "Appendix I: The Ecology of Dune""
Moo.
PostPosted: 21:24 - 14 Oct 2010    Post subject: Reply with quote
The car one i'll be using doesnt.. but it has bluetooth, so im gunna connect it via that.
Sits quite nicely at a good angle in my tank bag, shall put the clear waterproof thing over it too. Test it out going down to London tomorrow night, good 100 mile odd run.
A2 Passed 18/6/10
duncanpage
PostPosted: 23:41 - 21 Oct 2010    Post subject: Reply with quote
I wired in my car's tomtom XL.
I got a RAM holder £9.95 of some website
Found a website that sold a 12v to USB cable which I wire into the - terminal of the battery and the + cable on the rear brake light so it will only allow power to the satnav when the ignition is on, saves draining the battery by accidentally leaving it on Embarassed
daxo
PostPosted: 13:28 - 18 Dec 2010    Post subject: Reply with quote
Very cleaver..I'll do the same+++
The last post was made 15 years, 319 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 0.99 - MySQL Queries: 13 - Page Size: 73.9 Kb
